June 29th, 2010, 04:45 PM | #1 |
READ this before Shimming Needles - Might save a lot of pain
Many first time Ninjette Shimmers are "screwing up" the heads of the JIS screws that retain the carb tops, which need to be removed to get to the needles for shimming.
All those phillips screws on the 250R are NOT Phillips screws. Here are bits (JIS) which can be used in the MOS tool (See below), which works great for those hard to reach screws. The following quote is from VeX "I assure you this tool is going to get brought up in a lot of these DIY's, so do yourself a favor and buy one... DO it! (Milwaukee Offset Screwdriver with a ratcheting screwdriver handle)" The following link is for JIS screwdrivers, with handles: http://www.centralhobbies.com/Tools/jis.html If you want to see the difference between phillips screws and JIS screws, check out the following: http://www.rjrcooltools.com/jis.cfm If you follow my recommendation and VeX's, you will have fewer headaches, while improving your bike's performance. |
July 2nd, 2010, 10:09 PM | #2 |
Join Date: Jun 2009 Motorcycle(s): 09 EX250 LE Posts: 117
I just replaced the stock philips screws with hex screws. If you don't like hex screws you can always go flat head or something else. Anything is better than a philips-like screw head imo.
If you do manage to screw mess up your screws, you can always use a screw extractor |
July 22nd, 2010, 11:40 AM | #3 |
would like to thank Sam for the info on the JIS screwdrivers.
My head is harder than most... well, maybe all, and have been working on my carbs with a #2 Phillips, but being sure to apply plenty of downward pressure (forcing, actually) before applying sidewards motion. It's worked for me and hell... what did I need JIS screwdrivers for??? HA!!! A few weeks ago, I purchased a set of JIS screwdrivers from Central Hobbies and threw it in my tool kit for the day that I'd need to work on the ninja's carbs again. Recently, I've been doing a lot of rejetting on the dirt bikes with Keihin carbs. The setup is very different from the CV Keihins on the 250 and one of the screws that they use to secure an actuating pin for the needle would always strip when removing it. Last night, when I needed to shim the needle by another washer, lo and behold, what did I find but that telltale "dot" on that screw that indicates it's a JIS screw. Whip out the Central Hobbies JIS screwdrivers and wow... the difference in holding on that screw is amazing. Never the feeling like it's trying to "crawl" out of the screw head while turning it. So, I check all the screws on the carb and I'll be damned if they all aren't JIS screws. Makes working on carbs a lot easier and a much less daunting task than without them. Mahalo, Sam... for pounding in the fact that the JIS screws need the proper tool to remove them. See??? You can teach an old dog new tricks. |
July 22nd, 2010, 01:18 PM | #4 |
Thanks Sam. I just ordered a set of the bits. Great find.
July 22nd, 2010, 01:27 PM | #5 | |
July 22nd, 2010, 01:30 PM | #6 | |
Last futzed with by g21-30; July 23rd, 2010 at 03:38 AM. |
October 20th, 2010, 07:10 AM | #7 |
still managed to strip the screws even with these $9 bits.......
Used a dremel to reslot them and take them out...... replaced them with hex screws |
October 20th, 2010, 12:44 PM | #8 |
Join Date: Apr 2010 Motorcycle(s): 2009 Honda CBR600RR Posts: 633
I had no problems using a regular phillips screw driver.. guess I was lucky. I didn't take the carbs off the bike.. but I did have a screw driver that was long enough to do the job right. I also applied firm pressure down before just twisting it.
"Riding a motorcycle is like playing sports, not everyone is cut out for it." - WVNinja |
October 20th, 2010, 01:03 PM | #9 |
Getting good access goes a LONG LONG way.
I took my carbs out and had zero problems with the screws. It was well worth the effort. I went straight to rejetting instead of shimming... which can be done with the carbs in place, but it's just SO much easier to work if you've got the thing sitting in your lap. |
October 20th, 2010, 04:43 PM | #10 | |
Ramen Rider
Join Date: Jan 2009 Motorcycle(s): 2015 BMW R1200R, 08 Honda VFR800A (sold), 09 Ninja 250R (sold) Posts: A lot.
October 23rd, 2010, 10:15 PM | #11 |
Join Date: Apr 2010 Motorcycle(s): 2009 Ninja 250r SE, 2007 Daytona 675 Posts: 95
Can someone tell me where they purchased this tool from? I've been looking around and can't find anything resembling the picture, might be because of bad picture angles. Or is the screwdriver even still in production?
October 23rd, 2010, 10:36 PM | #12 | |
the screws stripped like they are made of lead.... replacing them with SS hex heads was the best thing to do. use the offset ratchetting attachment with the proper hex bit is beyond simple. |
October 23rd, 2010, 11:09 PM | #13 | |
October 24th, 2010, 01:33 AM | #14 |
Ramen Rider
this is the one i got:
http://www.amazon.com/gp/product/B00...M1R14YCEPTVV3Y i have had it for many years and these offset screwdrivers are great for getting to hard to reach spots. will even go where the stubby screwdrivers can't fit. |
December 13th, 2010, 06:56 PM | #15 |
seeking twisties
Join Date: Nov 2010 Motorcycle(s): '07 Ninja 650R, '09 250R special edition Posts: 199
About replacing the screws with hex head screws, does anyone know what thread diameter and pitch they are? And the approx. length? I'd like to get them (and everything else I need)before starting the project.
Bill |
December 14th, 2010, 12:31 PM | #16 |
Join Date: May 2010 Motorcycle(s): 2010 Kawasaki Ninja EX250 Special Edition Red/Black Posts: 455
I was wondering the exact same thing... anyone know what size screws we need.
'10 Ninja 250R SE Red/Blk Mods: Projekt D FE, Protons, HB Blk Windscreen, HIDs, TBR Blk Series Slip-On, Shogun Sliders, Solo Cowl, Integrated Tail Light, Gls Blk Rear Fender, Red Accents |
December 14th, 2010, 07:17 PM | #17 |
"Hey, That's My Bike"
Join Date: Jul 2009 Motorcycle(s): 88 Honda ZB50, 01 Honda Monkey, 07 CRF50, Honda CBR 600RR Phoenix Edition Posts: 188
December 14th, 2010, 07:22 PM | #18 |
Thanks for posting this g21-30!
December 14th, 2010, 08:19 PM | #19 |
The thing that bugs me is that the screwdrivers included in the OEM toolkit can't even seem to grip the screws holding on the side panels covers or the brake fluid reservoir. Did they not include a JIS/Metric toolkit with a JIS/Metric bike?!
December 14th, 2010, 08:32 PM | #20 |
the tool kit included with the bike was never meant to do work on the carbs or brakes, but included as a general tool kit to work on other things that you might need to work on, which the tools do fit. Besides, I've never seen a tool kit come with a bike that had any type of quality tools included. They seem more like a use once, throw away type of quality... from ANY manufacturer, not only Kawasaki.
I'm with you on the side panels though... seems they could have used a #2 Phillips head instead of that #3 that is required. I take it you have some pretty sorry looking Phillips head screws at this point? |
December 14th, 2010, 08:53 PM | #21 | |
April 16th, 2011, 03:26 PM | #22 |
CVMA/AFM #72
Join Date: Oct 2009 Motorcycle(s): 2009 Ninja 250r (Racebike), 2015 FZ-07(Tourer), 2001 KX65(LOL bike) Posts: A lot.
Anyone have any idea where I can still get these as bits? I can find them a lot of places online as full size screwdrivers, but I can't find bits to put in the offset screwdriver head anywhere :/
On a side note, it pleases me to know that the reason I strip so many screws isn't JUST because I suck |
April 16th, 2011, 07:42 PM | #23 |
Join Date: Sep 2010 Motorcycle(s): TR7, Trident, SuperIII, BMW, HD, Duc, Vespa, MP3 Posts: 83
I got a 3 Piece SHORT 1/4" Hex Drive DIN 5260 JIS Phillips Bit Set - #2, #1 & #0) from rjrcooltools, and a 12" #2 JIS screwdriver stanleysupplyservices.com.
http://www.stanleysupplyservices.com...=7899&pn=8-212 http://www.rjrcooltools.com/vessel.cfm I'd contact rjrcooltools and see if the short ones are back in stock for the right angle driver. They are very handy for not screwing up Mikuni or Keihin carbs, regardless of bike make, and getting to band clamps and such on the ninjette. The really fit well and make a huge difference over sticking a phillips on a JIS screw.
2010 Ninja 250R SE - I got this bike for my wife. It was a good trade. Last futzed with by red; April 17th, 2011 at 11:12 AM. |
April 16th, 2011, 07:43 PM | #24 |
links to those parts?
April 16th, 2011, 08:26 PM | #25 |
Or, make the short trip to Home Depot and pick up a couple of the smaller sized Drywall driver bits. Oddly enough, the bit profile on Drywall bits is almost identical to JIS bits.
They fit so tightly in the JIS screwheads that when you get it unscrewed from the carb you often have to "pop" the screw off the end of the Drywall bit with your fingers. I've never had a JIS screwhead strip or "cam out" while using a Drywall bit on it. |
April 16th, 2011, 08:57 PM | #26 | |
http://forums.ninja250.org/viewtopic...7b8c7f5#817115
2010 Ninja 250R SE - I got this bike for my wife. It was a good trade. |
April 17th, 2011, 11:12 AM | #27 |
I also had an email exchange with Jim Davis, a bike enthusiast and owner of Eastern Beaver (easternbeaver.com) which is based in Japan. For those that may not know, EB is a great source for high quality electrical bits and kits and similar that I can never find in the US. Really good quality stuff and priced right. He's going to start carrying JIS stuff in the next month or so.
Chapman Mfg, a US company that makes trick little screwdriver and hex sets I have had in my box for years, also expressed interest in making a JIS add-on set (www.chapmanmfg.com). The Harley people got 'em to make an add-on for their T27 needs, so ping/email them and maybe JIS is next. They are very responsive and a small US company that makes their own stuff.
April 17th, 2011, 09:29 PM | #28 |
CVMA/AFM #72
Cool thanks! I sent them an email, so hopefully they'll get back to me relatively quickly. Otherwise I'll probably end up trying out those drywall bits. There are few things I hate more than starting to pull my bike apart, only to realize I don't have the proper tools I need for the job >_<
April 17th, 2011, 09:45 PM | #29 |
Would it be easier to swap out the screws with allenheads the next time you're in there? I use the Milwaukee offset screwdriver Vex always writes about and it works really well for me when helping others take the screws out their first time.
April 17th, 2011, 09:54 PM | #30 |
CVMA/AFM #72
Yeah, I'm going to do that this time. I don't want to go through the trouble of removing the entire carburetor again to change out the jets (Largely- or rather entirely- because it is SUCH a bitch to put back in), so I was hoping having the proper tool with the proper heads could make it easier to work on while it's still attached. But yeah, definitely going to match some allen key bolts to replace them after this, regardless of whether this works out or not. That'd just be much easier to work with overall, I'd imagine.
April 17th, 2011, 10:00 PM | #31 |
If you're gonna replace jets without removing the carbs, I definitely recommend getting the offset screwdriver adapter then.
http://www.homedepot.com/h_d1/N-5yc1...1&ddkey=Search Makes it a lot easier to remove the float bowls from underneath the bike. I'm also able to remove them with a ratchet and bit adapter, but the two screws on the inside are tough because of the angle. |
April 17th, 2011, 10:14 PM | #32 |
CVMA/AFM #72
Yep, I just got one of those since it seems to be a popular tool, and I've been poking around in parts of the bike I probably shouldn't be Slowly but surely my toolbox is getting pretty fleshed out.
Now I just need the bits to actually put in it, and I figured since I'm getting all these specialty tools, I may as well get bits to actually do it right. Unfortunately, however, they're much harder to find than they should be. But I'd do pretty much anything to not have to try to reconnect those goddamn airbox hoses everytime I need to make some changes >_< |
April 21st, 2011, 07:59 PM | #33 |
Join Date: Feb 2011 Motorcycle(s): Ninja EX250R Posts: 80
If you succeed in pulling them out once, either replace them with real #2 phillips screws or allen keys screws. I couldn't find the right size in hex head, so I had to go with phillips, and still an amazing difference in how easy they are to get out with an 8" phillips #2 screw driver.
April 21st, 2011, 08:20 PM | #34 |
metric #2 phillips head screws? where did you find those?
April 24th, 2011, 01:04 PM | #35 |
Local hardware store, Lowes to be exact. They were in the metric section by the allen head bolts, which they didn't have the right size of, so I picked phillips up instead.
June 7th, 2011, 07:50 PM | #36 |
Join Date: Apr 2011 Motorcycle(s): '09 250R, '13 CBR500R Posts: 709
is there anywhere else to buy JIS bits as shown in the picture above. rjrcooltools seems to be out of stock on the short JIS bits. thanks!
June 7th, 2011, 07:58 PM | #37 |
http://www.ikaswebshop.com/hojisscset4d.html
or McMaster has JIS screwdrivers I have no buying experience with either.
June 7th, 2011, 08:44 PM | #38 | |
June 8th, 2011, 04:51 AM | #39 | |
June 21st, 2011, 01:00 PM | #40 |
Perpetual Newb
Join Date: Mar 2011 Motorcycle(s): 2010 MIB Ninja 250R [sold]; 2006 CBR600RR [sold]; 2013 Triumph Street Triple R Posts: 782
bump for this.... I'm in the same situation as gt_turbo.
I find it hard to believe that RJR Cool Tools has the monopoly on JIS bits. I got the Offset driver but it's pretty useless w/o the JIS bits. I already attempted to shim the needles once trying to be careful w/a standard Phillips and started chewing up 3 of the 8 screws so I stopped until I can get the JIS bits. Now I can't find the JIS bits anywhere. Already sent RJR an email but have yet to get a response. |
Shimming the Carb Needles... Is it for You? | kkim | 2008 - 2012 Ninja 250R Tech Talk | 93 | June 10th, 2018 05:25 PM |
Shimming same with Jetkit Needles? | vmax | 2008 - 2012 Ninja 250R Tech Talk | 4 | August 1st, 2013 11:49 PM |
DJ Needles instead of shimming | mxman38 | 2008 - 2012 Ninja 250R Tech Talk | 7 | May 30th, 2012 07:09 PM |
Shimming Needles @ NYC | keeyu | 2008 - 2012 Ninja 250R Tech Talk | 25 | August 17th, 2010 12:14 PM |
Shimming the needles question | Tubesock | 2008 - 2012 Ninja 250R Tech Talk | 20 | August 15th, 2009 12:17 PM |
