May 7th, 2009, 09:25 AM | #1 |
Join Date: Dec 2008 Motorcycle(s): 2009 SE Ninja 250R Posts: 796
Semi-DIY - Convert stock signals to flushmount
So here's a semi-DIY on how to convert your stock front turn signals into flushmounts. There are plenty of flushmounts out there that you can buy now but they're usually hard to see from the front and range from $30-$100. Total cost for this project - $5 or free if you already have some automotive sealant lying around...
This is a semi-DIY because I took the pictures after-the-fact but the entire process is pretty straight forward. I have to give credit to beeline12000 from the other forum for the original idea. Some people have decided to make modifications to the fairing to flushmount it, but I wanted something that could be reversible and brought back to stock if/when I sold it. First remove the screw holding the signal to the fairing. Then with a hearty pull, the wires will come undone and the signal should come right out. EDIT: Or, instead of pulling the wires off, you can unscrew the signal open (see further down) and unplug them by hand Once that's off, have a look on the back and remove the screw to open up the signals. This is what's inside: Take the clear and chrome piece and set the rest aside. Have a look at the back of the chrome piece as you'll need to put it back together. I have the memory of an 80 year old so I can't remember which wire goes where... IIRC green goes to the pin on the right. But test it out with the wires to make sure it lights up... then you'll know for sure. When you put it back together too, it might be a good idea to wrap the connections with electrical tape in case some moisture manages to find its way inside. But I've ridden in light and heavy rain already and have no problems to report. Just watch out where you aim when you wash the bike... Now with a file, file down the underside of the chrome piece where indicated. File it enough so that it sits snug when you put it back into the fairing and not rocking from side to side. It won't snap right in or anything but that's ok. We're going to seal/glue it down later. Once you're satisfied with the finish. Get some clear automotive sealant/adhesive and follow the directions to glue the signal down into the fairing. Secure it with some ducttape or green masking tape and let it cure as per the directions. After a day of curing, apply some sealant onto the outer rim of the chrome piece to glue on the clear piece. Repeat steps to cure. This stuff is good because it seals/secures but can also peel off quite easily if you need to remove the signals again (i.e. return to stock, replace bulbs). And your done! Kinda... you'll still notice some gaps on the sides of the finished product. I had some black sealant rubber lying around so I wrapped it around the edges and secured it with the sealant/adhesive. And finally here are some closeups of the finished product Front Side Front both sides. Easily visible. Last futzed with by Nemy; May 15th, 2009 at 08:21 AM. |
May 7th, 2009, 09:34 AM | #2 |
Nice job! Linked to this thread in DIY index...
May 7th, 2009, 09:35 AM | #3 |
Ms. Personality
Looks good. Worth the trouble?
May 7th, 2009, 09:35 AM | #4 |
Join Date: Nov 2008 Motorcycle(s): 2008 WR250R, 2006 Ural Raven (Sold), 2009 Versys Green (Sold), 2008 Ninja 250R Green (Sold) Posts: A lot.
Very resourceful.
May 7th, 2009, 09:41 AM | #5 |
It is if you're like me and hate the stockers. First mods I knew I would have to do were to chop the fender and replace the lights... But you also have to be cheap like me and not want to pay for flushmounts
Thanks for the comments guys. |
May 7th, 2009, 09:42 AM | #6 |
Ms. Personality
Oh!! Can you still change bulbs and stuff?
May 7th, 2009, 09:46 AM | #7 |
ya the sealant can peel right off if you wanted it to. Change the bulb, seal it back up and you're good to go! Easier said than done lol so I'm honestly hoping to not have to go through that hassle for awhile
May 7th, 2009, 02:43 PM | #8 |
Join Date: Apr 2009 Motorcycle(s): 08 black 250r (sold); '09 black zx6r Posts: 903
nice job...
May 7th, 2009, 02:48 PM | #9 |
Very clean looking. Great for tight budgets like mine.
May 7th, 2009, 06:42 PM | #10 |
Fighting Texas Aggie '05
that looks really nice - good job
May 7th, 2009, 09:22 PM | #11 |
Thanks. It'd be nice if someone could think up a way to flushmount the stock rears too :P
May 7th, 2009, 10:47 PM | #12 |
忍者
Join Date: Dec 2008 Motorcycle(s): None Now - Used to have an '08 Ninja 250R Candy Blue Posts: 151
good job man! too bad I swapped mine for flushmounts quite a while ago otherwise I would have done this!
May 7th, 2009, 10:49 PM | #13 |
I like this better than the flushmounts - awesome!
May 7th, 2009, 11:50 PM | #14 |
Join Date: May 2009 Motorcycle(s): 2009 Kawasaki Ninja 250r se Posts: 169
Very Kewl Nice Job!!!
May 8th, 2009, 11:42 AM | #15 |
WOW. Amazing.
Practically free. Better than spending $100 on them protons and they look better IMO. I'm confused about where the black piece that's between the fairings and the signals themselves come from? (The black piece that's in the finished pictures, but not the DIY steps pics) |
May 8th, 2009, 01:05 PM | #16 | |
May 8th, 2009, 01:13 PM | #17 |
The Grand Royal
Join Date: Dec 2008 Motorcycle(s): 2009 Ninja 250R Posts: 258
I wish I would have read this before I bought the Protons. :P
May 8th, 2009, 02:42 PM | #18 | |
like what does it look like if I were to walk into home depot/lowe's to buy some? |
May 8th, 2009, 03:40 PM | #19 |
Join Date: Mar 2009 Motorcycle(s): '08 blue 250R [sold]. '09 lime ZX-6R [stolen :( ]. '06 blue 636. Posts: 918
ingenious! can people in front of you see them pretty well when you signal?
May 8th, 2009, 06:52 PM | #20 | |
http://www.marcorubber.com/sizingchart.htm You might even be able to find colors that match your bike, if it's not black! |
May 8th, 2009, 08:58 PM | #21 |
Join Date: Jan 2009 Motorcycle(s): 2009 Kawasaki Ninja 250R Posts: 83
Good job Tim! looks really nice.
May 9th, 2009, 07:25 PM | #22 |
Join Date: Feb 2009 Motorcycle(s): 2008 Ninja 250 Posts: 24
May 10th, 2009, 12:02 AM | #23 |
i just did this mod
nice and easy made a mess of the silicone sealant so i'm after some rubber striping to clean up the mounting point great idea! |
May 10th, 2009, 04:10 PM | #24 |
sorry for the late reply but ya something like an oring material would be perfect - just soft rubber that can be used to stretch around the base... and hide the gap/sealant.
lol glad it turned out for you too. I found that if you use a toothpick you can mould the adhesive/sealant better and be more accurate. And even when it dries up you can use it to rub spots off or push it into the gap and away from sight. |
May 10th, 2009, 04:15 PM | #25 | |
But, even if they didn't, I never understood the argument that it's unsafe if oncoming traffic can't see your front signals. Worst comes to worst, a cage would assume you were going straight so they still wouldn't turn left into you etc... |
May 18th, 2009, 04:44 PM | #26 |
Join Date: May 2009 Motorcycle(s): 2009 Kawasaki Ninja 250r Posts: 69
I have a question, I'm doing the exact same thing based on this DIY, my question is when you put the stock blinkers in did the curve in the plastic of it and the fairing require you to cover a lot of holes with sealant/adhesive?
"When I die I want mud on my jump boots, magazine empty, and barrel hot." |
May 18th, 2009, 04:45 PM | #27 |
Oh and Nemy I thought of a way to flushmount the rear sigs, I'll let you know how it turns out when I'm finished!
May 19th, 2009, 09:39 AM | #28 | |
Nice, I think a bunch of us would be interested to see how it turns out |
May 19th, 2009, 01:19 PM | #29 |
Yea I tried it today, the idea is good but I'm having problems finding something that produces a strong enough bond, more to follow in a couple of days.
"When I die I want mud on my jump boots, magazine empty, and barrel hot." Last futzed with by Tubesock; May 19th, 2009 at 07:51 PM. |
May 19th, 2009, 09:36 PM | #30 |
What are you trying to use right now? Any of the auto sealant/adhesives should be good. Just make sure you follow the adhesive version of the instructions and allow it to cure properly while taped down.
May 20th, 2009, 07:35 AM | #31 |
Yea I tried something my friend said might work(last time I listen to him) and they came off on the ride home. I'm letting the same sealant/adhesive I used for your project dry on them right now and if that doesn't work I'm going to try something else I had lying around the house. Oh and I tried to use something called Mighty Mend I've never heard of it but my friend said the stuff was good.
May 20th, 2009, 09:29 AM | #32 |
Join Date: Jan 2009 Motorcycle(s): 08 Ninja 250 "Wasabi", 82 Yamaha xj650j Posts: A lot.
Looks good Tim.
May 20th, 2009, 12:31 PM | #33 | |
Thanks joe! |
May 20th, 2009, 05:42 PM | #34 |
Bike Thrasher
Join Date: Apr 2009 Motorcycle(s): 2008 EX250r Posts: 334
i vote nemy for forum member of the year
Intuitive Sliders, Aftermarket pegs, Custom Paint, Seat Cowl, Tinted Screen, Aftermarket flush mounts, Wheel Tape, Fender Chopped, Stock Shortie Exhaust and Woodcraft ClipOns |
May 21st, 2009, 11:40 PM | #35 |
May 22nd, 2009, 02:24 PM | #36 |
also a note for all doing this
1. electrical tape the connections to the housing, they can come out otherwise 2. duct tape the inside of the fairing to stop water getting in 3. secure your wire inside the fairing as you've got a few inches of slack now after re-positioning the connection point the procecure: 1. keep a big bucket of water nearby to clean up your silicone job after smoothing it out 2. get your hands dirty and use your thumb and/or pinky finger to smooth out the join 3. bring lots of microfiber cloths (any will do, i use a cheap $2.50 for 30 brand) enjoy! |
June 14th, 2009, 10:42 PM | #37 |
Join Date: Jun 2009 Motorcycle(s): (sold)--2008 250 ninja currently 2008 zx6r Posts: 7
thanks for the rep buddy!!!
just a few things i did a bit diff though to really make it more flush. 1--trim around the chrome part not just the back part so it will fit snug inside the clear part. 2--when putting the sealant to the clear part while trying to make it stick to the fairing...hold down ( or flush) the signal with strong duct tape or gorilla tape for about 1 day or so while the sealant dried up nice and good 3--if you have excess silicone sealant use a box cutter style razor to remove the excess. |
June 14th, 2009, 10:51 PM | #38 |
June 14th, 2009, 10:53 PM | #39 |
June 15th, 2009, 09:27 AM | #40 | |
DIY: Shorten stock turn signals | Gorilla25 | 2008 - 2012 Ninja 250R Farkles | 4 | November 1st, 2011 02:26 AM |
Flushmount turn signals. | Jacobson94 | 1986 - 2007 Ninja 250R Tech Talk | 1 | July 19th, 2011 11:02 AM |
Why flushmount turn signals? | mikesova | 1986 - 2007 Ninja 250R Farkles | 27 | June 1st, 2011 03:14 AM |
proton flushmount turn signals help | sherjay | 2008 - 2012 Ninja 250R Farkles | 5 | July 6th, 2010 04:14 PM |
Semi-DIY $0 flush mount FAIL! (Need Help) | 00v_Lucky | 2008 - 2012 Ninja 250R Farkles | 19 | July 11th, 2009 01:13 PM |
