Old March 29th, 2010, 02:46 AM   #81
I didn't modify the runners at all. I can't remember the ribs, but I do use grease at all the joints for a better seal to insure against leaks.
Old March 29th, 2010, 04:06 AM   #82
wayanlam
wayanlam's Avatar
Motorcycle(s): 2014 Z250
ah... grease, i need to get me a tub of that stuff, keep needing it, and then i keep forgetting to buy it. i could have sworn that i bought some last year, but ist gone missing from the house
ive just slid the sucker in, and the two rubber surfaces seem to adjust to the shape, and i cant hear any sounds indicating that its leaking.
ive noticed that you actually stuck the rubber runners all the way in, which would give an even better seal, but your filter is a bigger version than mine, and if i would have stuck it that deep the mouth of the runners would have been sitting on the inside wall of the filter, and im sure it would have restricted the air flow.
i decided to add another 2 cable ties to the extension pipes, cos im afraid that gravity might get the best of me and pull the filter off the carbs.
initially had a tricky time to make it all stay together after i tightened it all up. so i feel better with the added safety ties
thanks for the greasy tip
Kawasaki Z250, Bored up to 300cc with 12.8 CR, 41hp at wheel 27nm torque, Two bros full exhaust with DB killer
Dynojet Power Commander V, KnN Open filter, intake and exhaust ported, Puig Windshield
wayanlam is offline   Reply With Quote
Old March 29th, 2010, 11:50 AM   #83
what model of K&N is that and why didn't you just order a r-0990?
Old March 29th, 2010, 05:58 PM   #84
wayanlam
wayanlam's Avatar
RC - 2370
got this one cos this is whats available here. the only options to choose from was the plastic, or metal cap cover, and the metal one looks neat, so i went with that.
im glad that i extended the runners cause the wire mesh was already starting to wear down after just one day.
now that ive had a couple rides on the bike, i am noticing quite a difference, the bike pulls a lot harder once its in the upper rev range. much more than it used to~!
im also getting used to the raspy sound from the new filter... although i noticed that now its REALLY hard to talk over the sound of the exhaust/carbs/wind when im riding with my gf... d-oh!
any reason why i should have gone with the r-0990? they look bigger, so i assume they have an even bigger air flow?
i probably would have gone with the r-0990 if i had the choice; bigger is better right?
really curious to see the dyno result!
Old March 29th, 2010, 07:23 PM   #85
I mention the 0990 filter only because others have used it and it seems to work w/o surprises you find, like with your filter.
Yes, bigger is better.
I'm curious to see your dyno numbers, too. If possible, try runs w/ one size larger and one size smaller mains than what's presently in the bike.
GL
Old March 29th, 2010, 07:49 PM   #86
wayanlam
wayanlam's Avatar
i would have to buy the other mains, which is another umm... 25 bucks... i guess i could do that. isn't an insane amount to invest into fine tuning the bike. i would be a little annoyed to find that the current set up is just right tho, ha ha.
gonna order the other mains then
Old March 29th, 2010, 08:26 PM   #87
If you read on how to tune the mains, you keep changing them out till you find the set that gives you the most HP. That you're using a dyno takes out the "butt dyno" so you will at least have proof of what mains give you the most power.
Don't do it on my account if money is an issue, but if a dyno were available to me, you can be assured that's how I would tune for max HP.
Old March 29th, 2010, 09:31 PM   #88
wayanlam
wayanlam's Avatar
nah, $25 isnt a big deal, and one dyno run is like $5 here, might end up spending $15~25 for them to run the bike a couple times with the various main jets and needle position to fine tune it. so a total of around $50 is bearable and worth it if i am able to perfect the jetting on the bike.
my greatest fear is for them to thread a screw or something stupid like that while opening and closing the carbs like 5 times
with the air box delete, its a lot more spacious to get to the carbs tho, so im quite happy about that.
id be so tempted to get the BRT tis while im there as well, lol
it would be almost the ultimate performance you can get out of the ninjette without rebuilding the entire engine
Old June 22nd, 2010, 05:47 AM   #89
sixstring
Motorcycle(s): 09 EX250 LE
So I just finished pulling my air box. As I'm putting the mud flap back on, I notice that theres a small gap between the frame and the mud flap on the left side of the bike. Did I miss a washer or something or is this normal?
Another question. Where exactly does the brake light wire get threaded into the mud flap? I dug up some pictures and it seems its supposed to hang off a small hook below the right passenger foot peg but where does it go from there? I currently have it sorta pinched between the mud flap and the frame...
sixstring is offline   Reply With Quote
Old June 22nd, 2010, 07:28 AM   #90
dubojr1
dubojr1's Avatar
Check out the original DIY by Vex. Look at "Step #7" The pic shows the brake wiring running up the side of the flap and how it is secured with the "bendable" metal fastener. It comes back in near the brake assembly. I guess the gap you speak of could be where this wiring is running. Depends on which side of the bike you mean when you say "left"
Here's a pic I found on another thread that will show how it comes back to the brake light assembly.
Last futzed with by dubojr1; June 22nd, 2010 at 10:18 AM. Reason: Added a picture
Old September 18th, 2010, 06:36 PM   #91
egutierrez90
Eddie
egutierrez90's Avatar
Motorcycle(s): None.
hey Vex, GREAT DIY..I have a question..whats the diameter/size of the breather you used?
Thanks in advance..
egutierrez90 is offline   Reply With Quote
Old September 20th, 2010, 01:23 AM   #92
wayanlam
wayanlam's Avatar
by the way, if you remove the brake reserve, and the back wheel, i am almost certain that the air box can be removed completely through the back end. without having to crack it open.
i was a hairline off giving up and taking the back wheel off to try it when i was trying to take the air box out, but then gave it one last shot and managed to bend that metal mesh and slide the box apart while in that confined space.
if i had to do it again i would remove the back wheel and try that approach from the start, lol. has anyone tried it this way?
Old September 23rd, 2010, 03:10 PM   #93
headshrink
headshrink's Avatar
Questions:
1.0) Can the air box be removed w/o damaging or bending the metal mesh inside?
1.5) Is it difficult to get the air box back IN w/o damaging the metal mesh?
2.0) I see a few different methods used with and w/o the runners. Is there a GENERAL consensus on this (predictable performance, most often used method)?
Old September 28th, 2010, 08:40 PM   #94
wayanlam
wayanlam's Avatar
Originally Posted by headshrink View Post
Questions:
i think i almost answered question 1 above. i have yet to see someone posting a DIY without cracking the air filter in two and bending the metal mesh. try removing the back wheel and the rear brake reservoir and pulling it out the back. you will need to remove the carburetor too, so you can rotate the air box around to find the best angle of attack
i almost took the back wheel off cos i was getting so frustrated with the air box and the metal mesh inside, lol... i was hoping to get the metal mesh out without bending it, but there was no way around it.
if you can get the air box out through the back tire space, then it should be easy to put it back in. IF that doesnt work, then i wouldnt think that you can get he airbox back in without warping the metal mesh again... meaning that its gonna be a PITA to get it reassembled in that small space with the metal mesh. that would also mean that they install the air filter BEFORE they install the engine block... lol! go figure
i believe that if you dont use the original air filter runner, the K&N filter will get damaged on a piece of metal that used to hold the original air-filter-box. that piece sticking out of the body tubing to the right of the two red circles that i squiggled in.
this was a pic i took after i added the runner. i only had the filter in for one day without the runners and i noticed that the metal ring was denting the filter mesh. you can see the dent forming on the right side of the filter.
a friend of mine who added the K&N filter but didnt bother adding the runner has a hole going right through the mesh now! basically a gaping hole in the air filter
hope that helps, hehe
Old September 30th, 2010, 09:13 PM   #95
scotty
scotty's Avatar
Motorcycle(s): Yahama v star 650 classic
Anyone doing this mod- Im in the middle of it now =/ I found its easier to just take the rear wheel off and you can slid the whole air box out with out taking all thoses 8-10 screws out. Saves a few min. on the job.
scotty is offline   Reply With Quote
Old October 1st, 2010, 01:26 AM   #96
wayanlam
wayanlam's Avatar
ah!! i thought that it would work, but i was being stubborn and in a way i was half way into cracking the box in two when i noticed that it might be possible to get it out the back once you take the wheel out. but at that point i just bent the mesh and yanked it out!
good to know for all the people that still want to do this mod, and great to know in case we need to put the box back in!
thanks for going where no one has gone before!
Old October 1st, 2010, 07:29 AM   #97
scotty
scotty's Avatar
Haha, don't thank me, it was my wife who thought it!!
Old October 1st, 2010, 09:14 AM   #98
scotty
scotty's Avatar
I need help!! Lol 1st, do you have to put new jets in with this mod? Shimming just is'nt enuff? 2nd, that vac hose that was on top of the airbox, what do you do wit it? Pic below to show what one.
I did this and the bike runs like poo when you give it a little throttle. =(
Old October 1st, 2010, 12:59 PM   #99
main jets need to be changed to larger 112.5 or 110 Keihin sized jets.
a better pic of the hose would help.
Old October 1st, 2010, 01:05 PM   #100
scotty
scotty's Avatar
I got the hose thing figured out. lol Where can I buy these jets at? Im having a hard time finding just jets.
Old October 1st, 2010, 01:07 PM   #101
http://www.jetsrus.com/
Old October 1st, 2010, 01:14 PM   #102
scotty
scotty's Avatar
Your my ninjette hero . Will just replacing the jets be fine? Will a 200 work?! lol JK 110 or a 112? What would you recomend?
Old October 1st, 2010, 01:18 PM   #103
take your time to peruse the jetting database. find someone who has a similar setup as you and use their info as a base to start your jetting from. there is no one right answer as every bike and location requires different settings to make it run well/best.
http://www.ninjette.org/forums/showthread.php?t=10208
Old October 1st, 2010, 01:20 PM   #104
scotty
scotty's Avatar
True, I will look that over! Thanks again!
Old October 1st, 2010, 09:44 PM   #105
dlres
Motorcycle(s): my lovely and cute Asuka 250R and my 125cc honda moped
really?!
I just installed R 0990 on my bike and yes, I dented the filter at the same place when I struggling to install the filter.
but after installed, there is actually enough room between the filter and the metal ring for the carb and the filter to move around.
dlres is offline   Reply With Quote
Old October 1st, 2010, 11:24 PM   #106
wayanlam
wayanlam's Avatar
Originally Posted by dlres View Post
really?!
ah, then maybe the 0990s dont have the clearance issue that i had with mine. i have a different model K&N filter:
Old October 2nd, 2010, 01:01 AM   #107
dlres
this 2 are commonly used K&N filters for 250r here
RC-2370
Product Style: Dual Flange Oval Universal Air Filter
Flange Center to Center: 2.625 in (67 mm)
Flange Inside Diameter: 2 in (51 mm)
Flange Length: 0.625 in (16 mm)
Flange Type: Offset
Height: 2 in (51 mm)
Outside Length: 6.25 in (159 mm)
Outside Width: 4 in (102 mm)
Top Style: Metal
Top Material/Finish: Chrome
Filter Material: Cotton Gauze
Base Outside Length: 6.25 in (159 mm)
Base Outside Width: 4 in (102 mm)
Filter Re-Oiling Amount: 0.3 oz (9 ml)
Flange Offset: 0.25 in (6 mm)
Footnote 1: Offset is vertical
Top Outside Length: 6.25 in (159 mm)
Top Outside Width: 4 in (102 mm)
Weight: 1 lb (0.5 kg)
R-0990
Flange Inside Diameter: 1.875 in (48 mm)
Flange Type: Offset
Height: 3 in (76 mm)
Outside Length: 6.125 in (156 mm)
Outside Width: 3.875 in (98 mm)
Top Style: Rubber
Top Material/Finish: None
Base Outside Length: 6.125 in (156 mm)
Base Outside Width: 3.875 in (98 mm)
Filter Re-Oiling Amount: 0.57 oz (17 ml)
Flange Offset: 0.375 in (10 mm)
Footnote 1: Offset is horizontal
Top Outside Length: 6.125 in (156 mm)
Top Outside Width: 3.875 in (98 mm)
as you can see that RC 2370 is wider than R 0990. thats why the R 0990 has more clearance
I will post a picture when I got the chance
and the flange diameter for R 0990 is tighter than RC 2370. thats why R 0990 is tougher to install
Old October 2nd, 2010, 08:28 AM   #108
rwheelz
Moroccan Gold Imports
Motorcycle(s): '03 ZX9R, '03 ZX7R & wife's '09 250R
Is there a different K&N filter version of the 0990 that has filter, as opposed to a plastic cap, at the top/end of the filter? I know their car filters come in a variety of options, with a velocity stack on the end, metal or plastic cap, or just more filter material.
MOROCCAN GOLD IMPORTS
Where Excess Meets Extreme
rwheelz is offline   Reply With Quote
Old October 2nd, 2010, 09:39 AM   #109
egutierrez90
Eddie
Don't know if its too late for you Scott, but I too needed to purchase main jets (my ninjette also runs like "poo" after removing the airbox)
i purchased from these guys, cuts the price in half i believe
http://www.psep.biz/index.htm
Old October 2nd, 2010, 09:45 AM   #110
scotty
scotty's Avatar
Yeah I bought some yesterday though jetsrus.com. How much did they charge you? I paided 19$ shipped.
Old October 2nd, 2010, 10:17 AM   #111
egutierrez90
Eddie
I paid 23.75 shipped for 2 sets of main jets..the Keihen 110's and 112's
Old October 2nd, 2010, 10:36 AM   #112
scotty
scotty's Avatar
Wow, thats not a bad deal! I only got a set of 110's Thats good info for anyone who needs to buy new jets for this mod.
Old October 2nd, 2010, 12:04 PM   #113
be aware there is a price difference (and quality difference) between genuine Keihin jets and copies made by other companies that produce jets... roughly half the price of the genuine pieces.
Old October 2nd, 2010, 12:10 PM   #114
scotty
scotty's Avatar
Kkim, you make a good point. You sometimes get, "what you pay for"
Old October 2nd, 2010, 12:25 PM   #115
egutierrez90
Eddie
thats what I was worried about it, when something seems to good to be true..it probably is xP
I will see how these do..if theyre not worth it, I will DEFINITELY be purchasing genuine brand..
make sure you tell me how yours turn out Scott
i will be looking forward to your feedback
Old October 2nd, 2010, 01:04 PM   #116
In my experience working on other Keihin carbs, I've found the brass to be of a different hardness and have broken jets (twisted off at the base) while installing them. When I checked, they were not genuine Keihin jets but aftermarket jets I had bought from the local motorcycle shops around here.
Upon closer inspection, I noticed that the aftermarket jets mar or misshape easier than the genuine Keihin jets I also had in my jet case that I've built up over the years.
With finding that, I have to wonder of the quality control of the holes they drill for the jets. Are they really the correct size or might they be off from what they should be?
In any case, I now purchase only Keihin jets when I have a choice.
Keep in mind, the jets I talk about have been installed and removed numerous times, so if you work on your jetting only a few times, you may be okay w/ aftermarket jets. Just be really careful when removing and installing them. I now make sure I always use the proper sized box wrenches and screwdrivers when rejetting my carbs.
Old October 2nd, 2010, 01:07 PM   #117
scotty
scotty's Avatar
Will do, they said 5-7 days to get to me. So I hope to be up and running by next weekend. So I post up feed back asap!!
What do I do now with no bike to ride???? O well, good time to do other stuff to it I guess.
Old October 17th, 2010, 10:16 PM   #118
egutierrez90
Eddie
So Scotty, how's your ninjette running? I had received my jets a while ago but I can't install them because for some reason they are SUPER long! >_< haha, after installing the main jet in the carburetor, i was unable to place the cap back onto the carbs to seal the bottom portion of the carbs shut -.-
Are the jets you ordered working good? Is your ninjette running smoothly now?
Look forward for your reply
Old October 18th, 2010, 12:30 PM   #119
scotty
scotty's Avatar
O man, i'm sorry. I forgot to give feed back! My life is crazy rite now. Lol
But yes! I did get my main jets in. I ordered two 110's. Installing them was a snap. Just held the outside part of the jet with a 8mm(no idea what its called) and I unscrewd the jet itself with a screw driver. Bike runs great with them.
Did you install the rite jet in the rite location? Rite jet? Here is a pic of the main jet.
Old October 18th, 2010, 12:47 PM   #120
egutierrez90
Eddie
Hmm yea, looks good, yea i installed the jet in the right spot, but the reason why i couldn't screw the bottom cap back on was because the jets i ordered were SUPER long, so they stuck outward ridiculously..so when it came time to screw the cap back on the main jet kept the cap from closing..there was like 1/3 gap between the carbs and the cap o_0 so I just put everything back and am now just gonna order from the website recommended by Kkim..
a few questions..did your bike go out of sync? did you re-sync it?
and do you have an aftermarket f/s or s/o exhaust?
DIY- Removing the Kleen Air System Hoses and Plugging the Holes on a 08 250R kkim 2008 - 2012 Ninja 250R Tech Talk 152 March 15th, 2019 07:37 PM
K&N air filter to stock air box Graugaard 2008 - 2012 Ninja 250R Tech Talk 29 July 28th, 2012 06:33 AM
Air Filter Box Question Little Green Machine 2008 - 2012 Ninja 250R Tech Talk 7 July 14th, 2012 06:25 AM
