Old March 23rd, 2012, 12:33 PM   #1
0-60 Challenge: Why My 250 is Potentially Faster Than Your 250!
As many of you know, n4mwd and I kinda threadjacked nickjpass's thread about the 2012 CBR250R while talking about 0-60 times.
SOOOOO and idea came to me. If we're wondering the differences in times from classic 250 to new 250, why not get the whole forum involved? That way we can get definitive numbers (and many trials) to show that either one generation is better, or as I suspect, that they're nearly identical
Rules for taking part in this 0-60 challenge
  • Complete a 0-60 test only when it is safe to do so. I am in no way, shape, or form advocating riding like a caffeinated monkey with a hernia.
  • I don't want to see any top speed videos posted for this. I don't want anyone getting pulled over, or worse, injured because I have a fun science experiment. See rule number 1
  • You must come to a complete stop before taking off
  • Run numbers on gearing commander, or this (for classic 250 guys) so you know what corrected speed will be 60 mph actual speed. We want this to be 0-60, not 0-57
  • Try to do this on level ground. We want this "experiment" to be as repeatable as possible
  • Record your times and post the video so we can prove each trial is valid.
  • Don't do this in traffic, if possible. See rule number 1.
  • Of course time slips from the drag strip count! If you've got them, post them!!
  • Have fun and be safe! Learn about your bike, and get out and ride!
  • If there's any tidbits of info that you learn from one run that would help others out, feel free to share them.
  • Assumed error for times is ±1/2 a second.
  • If you feel like including things like headwinds, temps, bad jetting, not enough time on the treadmill lately, etc. go for it. They do make a difference, but I'm not that worried about it. We'll just average them out in the end. This is a "real world" test.
  • If possible, go through your video frame by frame to get a more exact number for start and end times of your 0-60 test.
I'll go first:
helpful tips:
  • When launching at 9k or above, clutch control is going to be the hard part, hence the wheelette in the second attempt. My launch at 6k was much more successful, although was likely slower than a WOT launch with proper clutch usage.
  • Clutchless shifting is easy, and faster. Try it.
  • Shifting at 12.5-13k seem gets you right back into the power band when you start in the next gear. Waiting until red-line just takes longer.
Last futzed with by choneofakind; March 25th, 2012 at 03:18 PM.
Old March 23rd, 2012, 12:34 PM   #2
6k? 9K? WOT!!!
side note- its not valid unless you have a gps
Old March 23rd, 2012, 12:40 PM   #3
EsrTek
EsrTek's Avatar
Motorcycle(s): '13 300
You didn't get your wheel up between 1st and 2nd.. plz go out and repeat!
Old March 23rd, 2012, 12:41 PM   #4
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
How about timing slips from the drag strip?
Old March 23rd, 2012, 12:43 PM   #5
Those count too! post 'em!
Old March 23rd, 2012, 12:52 PM   #6
6k? 9K? WOT!!!
That's why I said to compensate for the speedo error. Not all of us have GPS's, but we all have speedo's, and as long as you compensate, it will be close enough. They're all built to the same tolerance.
for me, 130/90 Rear, 100/90 front, 14/47 gearing, 60 is indicated as 63 mph @12,070 rpm in 3rd gear. By reviewing my video frame by frame, that gave me 2 ques to be accurate enough in my timing; the tach and the speedo.
Old March 23rd, 2012, 12:54 PM   #7
Racer x
Racer x's Avatar
For those with a Koso dash the power test feature will record 0-60 time.
Old March 23rd, 2012, 01:45 PM   #8
That's not what I've seen. They seem to vary a good bit, and there's no way to compensate accurately without a known speed standard. That's either a radar gun or GPS for most of us.
The problem is that the tach has just as much error margin as the speedo, so it doesn't really buy much when you're trying to be precise within a mph or 2. Also, the gearing won't affect anything on the speedometer, that's only affected by front wheel size. Gearing changes will affect how to use the tach readings, but that still doesn't make it terribly accurate.
None of this makes it a useless exercise, and whether it's 62 mph or 66 mph won't change the world, but it does mean that the times are also effectively variable by .5 - 1.0 seconds IMO.
Old March 23rd, 2012, 01:49 PM   #9
Well, me stating the gearing was so that alex could to to the site and use the same inputs. I know it has nothing to do with the speedo. That's off the front wheel.
So now we just have a margin of error to consider also. Times are now + or - 0.5 seconds.
Old March 23rd, 2012, 02:02 PM   #10
That works.
Old March 23rd, 2012, 02:06 PM   #11
ninja250r81
ninja250r81's Avatar
Motorcycle(s): 2012 ninja 250r se
pay for a dyno run.
you can setup the dyno for 1/4 mile run and get the figures off that.
bonus = no fine, speeding, loss of licence etc
ninja250r81 is offline   Reply With Quote
Old March 23rd, 2012, 02:40 PM   #12
can i post my speeding ticket for doing 103mph in a 50 on the ninja250? it was lidar.
Old March 23rd, 2012, 02:55 PM   #13
Originally Posted by ninja250r81 View Post
pay for a dyno run.
Didn't realize they could time you on that. I thought they just gave hp and AFR numbers. Good tip though!
While impressive, no. This is a 0-60 thread
hang on, where's @Jiggles, and @n4mwd? they have videos that would work well here.
Old March 23rd, 2012, 05:03 PM   #14
n4mwd
n4mwd's Avatar
Yep, here's mine...
I'm using oversized tires (90 aspect ratio) but that makes the speedo more accurate.
Also, my runs are slower because of a bad carb and poor shifting.
My Ninja Blog
Old March 23rd, 2012, 05:25 PM   #15
Ramen
Frak It
Ramen's Avatar
You'd think there would be a 0-60 app for Android somewhere.
Ramen is offline   Reply With Quote
Old March 23rd, 2012, 05:44 PM   #16
same, but my 14/47 gearing averages out to the same as 80 profile tires
I was having the same issues. My needles could use another washer. We'll see if that makes any difference. I think the biggest thing for getting faster time was making more than one run. The more runs I made, the faster I got. that, and shifting without the clutch right at 13,000rpm
Old March 23rd, 2012, 06:00 PM   #17
gt_turbo
gt_turbo's Avatar
Motorcycle(s): '09 250R, '13 CBR500R
where are the new gen vids at? wish i had a gopro.
gt_turbo is offline   Reply With Quote
Old March 23rd, 2012, 06:04 PM   #18
Borrow one!!!
Jiggles has a video, and I know @massacremasses has a gopro. So does @Kevin2109 (but he BETTER USE HIS 250!! )
Old March 23rd, 2012, 06:37 PM   #19
n4mwd
n4mwd's Avatar
Borrow one!!!
Video cameras are pretty cheap these days. A goPro is probably one of the best, but a cheapie like this one for $40 also works well.
The main thing is that you need a good mount. This is what I used.
My Ninja Blog
Old March 23rd, 2012, 07:02 PM   #20
lc86
lc86's Avatar
Motorcycle(s): 2010 Ninja 250r (RIP)
I ordered the suction mount thing, I never thought to just use my camera as a video cam, so now I just need to find somewhere I can do it. I know of plenty of roads around here, just none that are straight and flat with no traffic. I guess I can always do it on a freeway entrance or something worse case.
lc86 is offline   Reply With Quote
Old March 23rd, 2012, 08:47 PM   #21
Here's what I got. Had to cut the end off cuz the pregen tank is so short that it was bonking the keys.
But it works on the newgen without modification
Old March 23rd, 2012, 09:02 PM   #22
massacremasses
Avid Kitteh Poster
massacremasses's Avatar
Motorcycle(s): 2006 Yamaha TTR 50 SUCK IT
ill do it tomorrow.
I powdercoat stuff Help me pay for my addiction
I say funny stuff. http://twitter.com/JustinPWNSyou sometimes...
I write like a 12 year old too, http://justinpwnsyou.wordpress.com/
massacremasses is offline   Reply With Quote
Old March 23rd, 2012, 10:51 PM   #23
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
I'll do some more runs on monday. Since I got my valve adjustment my bike has been running better, maybe I can shave off a few tenths of a second
AFM #676
Supersports are for n00bs
Old March 23rd, 2012, 11:12 PM   #24
I don't have a smart phone. Too expensive
Old March 23rd, 2012, 11:50 PM   #25
I'll sit this one out. Mine has the infamous variable tach syndrome and a heavy rider
Old March 24th, 2012, 12:06 AM   #26
jdoucet93
jdoucet93's Avatar
Motorcycle(s): 2009 R6
They do. It's called "UlyseeSpeedometer". It's quite useful.
And on a side-note, can I enter the contest with my new bike?
SOLD MY NINJETTE and got THIS
jdoucet93 is offline   Reply With Quote
Old March 24th, 2012, 02:32 AM   #27
cuong-nutz
cuong-nutz's Avatar
I shall join in on the fun!
HalfFast Racing Team
Old March 24th, 2012, 07:14 AM   #28
greg737
Motorcycle(s): -
I'm interested also, but for slightly different reasons.
The analysis software that I use for my FI system (MegaLogViewer is the name. Is it just my 4th-grader potty-humor mentality or is that a funny name?) includes the ability to estimate the vehicle's horsepower during the analysis of your riding datalogs if you input a list of parameters into it like rear tire cirumference, final drive ratio, gearbox ratio, displacement per cylinder, number of cylinders, etc.
When properly set up the MegaLogViewer software becomes a "poor man's" dyno. You have to go out and datalog some max-power runs, like the 0-60 mph testing you guys are doing here on this thread. Then you go home and input the datalog to the MegaLogViewer software and run it run several times over, changing the gearbox ratio for each of the bike's gears.
It doesn't produce a single sheet of paper printout result like a dyno session does, but through the process I've described above you can cobble together a pretty accurate idea of the bike's true horsepower.
This 0-60 thread is my new inspiration to do this testing, now all I have to do is find the time.
Old March 24th, 2012, 09:55 AM   #29
At 60 mph the bike is moving at a rate of 88 feet/second.
Maybe we could get a more accurate comparison just by chrono'ing a known distance in feet.
Google Earth allows to measure the distance of your test very accurately.
Being the great physics guy that you are choneofakind, you can calculate a standard distance at which your Ninjette has reached more or less 60 mph.
Less time covering that distance wins, and we can calculate mean hard numbers using the media acceleration obtained for each model.
Just an idea, of course.
Old March 24th, 2012, 10:30 AM   #30
sorry mate, no. This is to start/decide a fun contest betwixt generations to see which bike is "better". It's well documented that 600's can do 60 in less than 4 seconds. 250's are somewhat debated because the numbers vary so much based on rider weight.
but if you want to practice some 0-60 times and record them on your own, (still post them somewhere. you know I'll watch them ) that would be good also. Launches are a good skill for a rider to have. They're also a skill I'm no good at and would like to improve upon.
Hey glad I can help! As the thread starter/officiator, I can't choose sides (go classic 250's!) but at least it will help with your personal data gathering on hp. My completely unbacked hypothesis is your hp is about the same as carbs with pods, but you'll have more torque.
megalogviewer. hmmm. They can sell that without requiring you to be 18?
Yeah we could to that. I could go set a "standard" distance, then the competition would be who can be the fastest person from a dead stop to that distance (which the rider would be going roughly 60 mph) But that would take a second person to record accurate times. That would also require more calculations on my part because inevitably, someone would mess up the numbers. We're kinda doing a simple experiment.
Good suggestion though. That was one thing I never really thought about when I went out and did my 0-60 times
Old March 24th, 2012, 01:18 PM   #31
n4mwd
n4mwd's Avatar
I'd be curious how well the FI bike does on these runs. It should do better, but you never know....
Rider weight...
Good point. I'm probably 230# with all the gear so that is another reason my times were off.
My Ninja Blog
Old March 24th, 2012, 01:53 PM   #32
Kevin2109
KThanksBye
Kevin2109's Avatar
Motorcycle(s): 2006 zx636r
Borrow one!!!
I have a 250?!
----> My Youtube! <----
Old March 24th, 2012, 02:30 PM   #33
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Originally Posted by Kevin2109 View Post
I have a 250?!
U can use mine
AFM #676
Old March 24th, 2012, 03:18 PM   #34
I have a 250?!
yeppers!
at least you keep telling me you still have it
Old March 24th, 2012, 04:04 PM   #35
greg737
Motorcycle(s): -
Okay, so today I got the camera mounted, got the netbook computer connected to the FI system's Microsquirt ECU for datalogging of the event and went out for some 0 to 60 runs.
You know what I learned? I learned I don't like that sort of riding. Something about it bothers me. I got the job done (I think), but I didn't enjoy it.
Working on the video now.
*Edit*
Okay, I've spent a few minutes getting an initial look at the video I shot. I have to say I don't launch the bike very well (I only did about 5 runs before I had to admit 0 to 60 timetrials riding wasn't for me and headed back home).
Conservative estimate of the video so far (not trying to shave it at all in the analysis of the tape), I'd say 7.21 is the best I did.
... and now that I've watched myself a bit more I'm realizing I don't shift very well either. All I can say is that so far this 0 to 60 testing thing has been a real eye-opening experience for me with regard to watching myself ride the bike on video and not particularly liking what I'm seeing.
Going to a friend's house now to drink some beer. Maybe I'll post some video of the whole thing here on the thread tomorrow.
Old March 24th, 2012, 05:26 PM   #36
n4mwd
n4mwd's Avatar
I have a 250?!
Pull two plug wires off the ZX6 and it should be a fair comparison.
My Ninja Blog
Old March 24th, 2012, 05:39 PM   #37
hey Greg that's ok! you're following this rule:
Riding is all about learning. That's what we're all here for.
Launching is a great skill to have, and I bet that you know a whole lot more about it now than you did before you started today, making your attempts worthwhile. Not to mention, the data you gained will be helpful in your diagnostics of your FI setup.
Old March 24th, 2012, 05:43 PM   #38
leed
leed's Avatar
Motorcycle(s): Time will tell
Hmmm.. I will have to try this when the weather is nice. But I have no camera.. I suppose I'll have to borrow/use my phone as GPS instead.
Old March 24th, 2012, 06:37 PM   #39
n4mwd
n4mwd's Avatar
Most digital cameras have a video function. You can use that. I've seen video on even those little $20 keychain cameras at Wall Mart.
My Ninja Blog
Old March 24th, 2012, 07:05 PM   #40
leed
leed's Avatar
I don't have a trustworthy way to mount my a DSLR, otherwise I would!
2012 TTP Racing 250 Challenge TTPRacing Ninjettes At Speed 37 August 1st, 2012 09:19 PM
AFM Round 4 @ Sonoma Raceway FLAP 250 Challenge KazMan Videos 2 July 9th, 2012 12:18 PM
[faster and faster] - KTM announces M32 engine for Moto3, sports 250 streetbike to fo Ninjette Newsbot General Motorcycling Discussion 4 October 8th, 2011 08:23 AM
[faster and faster] - Scomadi Turismo Leggera 250 runs wild… Ninjette Newsbot Motorcycling News 0 March 24th, 2010 09:30 PM
[faster and faster] - Suzuki Gemma 250 goes on sale in Japan Ninjette Newsbot Motorcycling News 0 July 2nd, 2008 12:00 PM
