July 31st, 2013, 08:13 PM | #1 |
Shimming same with Jetkit Needles?
Hi all,
I just want to know is Shimming needles same with replace jetkit needles, cause from what I read both action to raise a needles. I want to make sure this cause I want to buy FP for my 2012 ninja. And how about gas mile?. For your info my bike running stock with slip on muffler, bike running great, smooth when I rev from low, but seems very light when I twist or roll on throtle from bottom. There is why I want to buy FP jetkit or shimming to make power on low end. |
August 1st, 2013, 05:46 AM | #2 |
dirty boy
MOTM - Apr '14
Shimming with washers and adjusting the clip on the FP needles is basically the same thing. The FP needles will give you a little more range of adjustment as well as slightly finer adjustment. Plus you get the FP needle which has a different taper to it which makes getting the jetting right a little easier IMO.
not sure what you mean by "light" if you bike is rich it will bog down
August 1st, 2013, 08:16 AM | #3 | |
HiSubxero, Thanks for your info, but how about mpg?. light mean when you roll on thortle not heavy. |
August 1st, 2013, 08:22 AM | #4 |
Raising the needle height mainly affects 1/4-3/4 throttle range (starts about 3k as the slides start to rise). Gas mileage decrease is tiny in this range. However keep in mind any time you add more fuel into combustion or twist the throttle more, MPG drops off.
http://www.motorcyclecarbs.com/carbs101.pdf |
August 1st, 2013, 11:49 PM | #5 | |
Thanks DaBlue, so I will try to raise my needles to see improvement |
WTB aftermarket needles or jetkit | kavo | Items Wanted | 0 | June 25th, 2012 05:37 PM |
question about shimming those needles | fizzer914 | 2008 - 2012 Ninja 250R Tech Talk | 6 | June 11th, 2012 03:12 AM |
DJ Needles instead of shimming | mxman38 | 2008 - 2012 Ninja 250R Tech Talk | 7 | May 30th, 2012 07:09 PM |
Need help on shimming carb needles | RedNinja21 | 2008 - 2012 Ninja 250R Tech Talk | 6 | October 27th, 2011 10:16 AM |
Shimming Needles @ NYC | keeyu | 2008 - 2012 Ninja 250R Tech Talk | 25 | August 17th, 2010 12:14 PM |
