Old August 28th, 2013, 06:57 AM   #401
allanoue
allanoue's Avatar
MOTM - Sep '14
Originally Posted by Koreo View Post
Im trying to find a map for my bike.. Well 2 actually. One for right now though is just LV slip on and KN filter. Where can I find one?
I do not think you will get one from AP for a LV
Old August 28th, 2013, 07:14 AM   #402
Koreo
general slip on map...
Koreo is offline   Reply With Quote
Old August 28th, 2013, 07:41 AM   #403
kbryant
Area P
kbryant's Avatar
If you have our FI Micro Programmer, simply contact us at sales@areapnolimits.com for support.
Old August 28th, 2013, 08:31 AM   #404
Koreo
email sent. thanks kerry
Old September 1st, 2013, 11:22 AM   #405
allanoue
allanoue's Avatar
MOTM - Sep '14
When I installed the AP I am hitting the limiter a lot more. Before the install I would hit it maybe once a month and now I hit it weekly.
I think it is because when i felt the power start to drop off I would change gears and with the AP I am not getting that feedback. Is anyone else having the same experience?
Old September 1st, 2013, 11:40 AM   #406
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
I don't think I've hit the rev limiter once. Just make sure to shift at 12.5k. That's what that big tach is for.
Old September 1st, 2013, 01:28 PM   #407
allanoue
allanoue's Avatar
MOTM - Sep '14
Never needed to look before. Now I do and I would rather be looking at the road.
Last futzed with by allanoue; September 2nd, 2013 at 05:31 AM.
Old October 22nd, 2013, 10:15 AM   #408
allanoue
allanoue's Avatar
MOTM - Sep '14
Originally Posted by Yakaru View Post
I've been riding 2 days now with the Pod filter + Area P + Pod Tune and it's been quite nice but I have noticed that, particularly when cold, if I close the throttle at speed and engine brake I get some 'popping' that sounds like a backfire. Could I need to have my tune dialed in more? Maybe some part of my install needs to be rechecked?
Is it popping? Did you change anything?
Old October 28th, 2013, 07:20 AM   #409
allanoue
allanoue's Avatar
MOTM - Sep '14
It has been in the 30s and 40s the last couple of weeks and my mileage is worse by 4 or 5 MPG . this morning it was 28 degrees.and I noticed my top end speed is down.
Not a lot but...
Do I need a different map for the winter.
@kbryant
Old October 28th, 2013, 11:49 AM   #410
kbryant
Area P
kbryant's Avatar
Not a lot but...
@kbryant
The short answer is no, I would not recommend another map at this time. Obviously that does not mean changes can't be made for improvements during those brutal riding conditions (), but there is enough flexibility within the fuel model you already have. To explain further -
The FI system on the 300 (and most Japanese bikes) is a speed density system which means fuel delivery is based on modeled airflow. Basically it uses various sensors to calculate specific air density, specifically IAT (intake air temp) X MAP (manifold absolute pressure). Once air mass is established the ECU refers to various lookup tables to calculate fuel delivery. Because IAT, ET (engine temp), and MAP are constantly changing the ECU is making calculations/adjustments many times per second. The Micro Programmer Map/Tune simply adds a +/- correction to the injector signal. One question would be the ECU's accuracy at controlling the mixture from one extreme to the other (i.e 30F-105F degrees) and in most cases it is very accurate in this regard. It has to have passed a wide range of EPA/EU standardized testing. The bigger factor is very likely the amount of time the motor takes to get up to full operating temp, and maintain the most efficient operating temp, when temps get that low for performance and fuel mileage.
Old October 28th, 2013, 12:41 PM   #411
allanoue
allanoue's Avatar
MOTM - Sep '14
Sounds good. It was not much of a drop in speed but I thought I would ask.
Thank you
Old October 28th, 2013, 06:35 PM   #412
Al, if the issue is the engine getting up to temp like Kerry suggests, have you considered installing a thermobob in the 300? Should be the same process as the install in a 250
Old October 28th, 2013, 07:15 PM   #413
allanoue
allanoue's Avatar
MOTM - Sep '14
I do think that would help now that you say but warm up is not near as much a problem as with the carb 250 in the cold. Performance is still better then when it was stock and my only race is getting to work before I run out of body BTUs
Old October 29th, 2013, 06:10 PM   #414
slickrick
slickrick's Avatar
Motorcycle(s): Ninja 300
Would I need an updated map if I changed the stock gearing, because it changes the rpm at different speeds? Or would I not because it wouldn't affect the fuel/air in any way?
slickrick is offline   Reply With Quote
Old October 29th, 2013, 06:14 PM   #415
allanoue
allanoue's Avatar
MOTM - Sep '14
I don't know much but this I do know.
No you do not need a new map for the reason you gave.
Old October 30th, 2013, 09:27 AM   #416
kbryant
Area P
kbryant's Avatar
Correct!
Old October 30th, 2013, 05:18 PM   #417
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
I need a new map... A Lewis an Clark version or is that just a new to me map?
Old October 31st, 2013, 11:28 AM   #418
Loadthis
Loadthis's Avatar
Motorcycle(s): '13 Ninja 300
Just got off the phone with Area P, got my full ultra high mount carbon system on the way. To say I am excited is an understatment!
Loadthis is offline   Reply With Quote
Old October 31st, 2013, 04:40 PM   #419
allanoue
allanoue's Avatar
MOTM - Sep '14
Did you get it with the microtuner?
Old October 31st, 2013, 05:55 PM   #420
Loadthis
Loadthis's Avatar
I installed the Fuel Moto a couple weeks ago. It made a noticeable difference by itself so I'm eager to get the exhaust on.
Old October 31st, 2013, 05:59 PM   #421
JohnnyBravo
Good stuff Evan
Old October 31st, 2013, 06:08 PM   #422
allanoue
allanoue's Avatar
MOTM - Sep '14
Old October 31st, 2013, 06:10 PM   #423
ninjamunky85
Que Buenos Son!!!
MOTM - Nov '14
Area-p exhaust + tuner + K&N + snorkel delete = awesome!
Old October 31st, 2013, 07:42 PM   #424
Loadthis
Loadthis's Avatar
Originally Posted by JohnnyBravo View Post
Good stuff Evan
The bike is fun as hell but I think everyone can use an extra 6hp. Plus, at 4200ft MSL I need all the help I can get.
The list of upgrades is long but I'm knocking it out.
Old November 10th, 2013, 06:47 AM   #425
pratik06
Motorcycle(s): Yamaha R15, Kawasaki Ninja 300
I have just installed the AreaP Micro Programmer on my bike. I am little confused with the red status light. Is the light suppose to stay on while the bike is running?
pratik06 is offline   Reply With Quote
Old November 10th, 2013, 07:34 AM   #426
Loadthis
Loadthis's Avatar
Yep. I was a little confused as well because red usually means bad. Your FI tuner is working fine!
Last futzed with by Loadthis; November 10th, 2013 at 09:31 AM.
Old November 11th, 2013, 05:09 AM   #427
pratik06
^^^ Thanks for the reply . I emailed to Kerry and got the same reply.
Old November 12th, 2013, 11:34 AM   #428
Loadthis
Loadthis's Avatar
So I finally got my exhaust installed and am loving it! The boost in HP is definitely noticeable. I accidentally got the front wheel off the ground from a start then popped it up a bit on the upshift to 2nd. Badass! The sound is also pretty awesome. It has a throaty, deep tone at the lower rpms and a nice growling roar up high.
Now I'm trying to work out the map tune for my altitude. I've been in contact with Kerry and he's given me some pointers on how to lean the mixture a bit. I'm riding at 4200ft above sea level and the air is much thinner and so requires a leaner mix. It's a case of trial and error and fine tuning at this point. I imagine I could really work it out on a dyno if I could find someone locally and the price is right.
Anyway, bottom line, I love the system.
Old November 12th, 2013, 12:33 PM   #429
kbryant
Area P
kbryant's Avatar
Thank you for the comments Evan. Between the adjustments we've discussed, and the new Map sent to you this morning to try, we'll get you dialed in at 4200'
FS: Area-P solo exhaust bracket for Ninja 300 w/stock exhaust c-dog Motorcycle-related 2 September 12th, 2014 10:48 AM
