Old September 24th, 2012, 01:51 PM   #481
geeker
geeker's Avatar
Motorcycle(s): 2022 Honda CRF300L Rally, 2015 Ninja ZX6R 636, 2014 Ninja 1000, 2013 Ninja 300 (sold), 2011 Ninja 250R (sold)
Originally Posted by Jiggles View Post
I use old motor oil for cooking.
That's why mexican food causes the runs.
geeker is offline   Reply With Quote
Old September 25th, 2012, 05:28 PM   #482
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
just changed my oil in my bike. Pretty simple only thing that bothered me was the large O-ring doesn't lay flat because of it being jammed in the small oil filter box so i just had to kind of assume that it got seated correctly as it got screwed in.
No leaks though so all is well.
Old October 19th, 2012, 08:31 PM   #483
Dazo
Motorcycle(s): 09 Ninja 250
Just changed my oil today, the DIY was very helpful.
Dazo is offline   Reply With Quote
Old January 24th, 2013, 01:59 PM   #484
LNasty
Daily Jap rider
LNasty's Avatar
Question drain plug
Does the 2012 come from the factory with a magnetic oil drain plug? Is it wise to get one if not?
Old February 7th, 2013, 12:14 PM   #485
sLick415
It should be okay if Im at the minimum line right?... Im all out of oil.
sLick415 is offline   Reply With Quote
Old February 7th, 2013, 12:15 PM   #486
As long as you keep a close eye on it and stop riding if it drops at all.
Old February 7th, 2013, 12:17 PM   #487
It doesn't. Your choice. I had to complete my break in without one because the dealer didn't have the right size and my odometer jumped from 2 miles to over 680 miles the very next day.
Old February 7th, 2013, 12:31 PM   #488
sLick415
Yeah ran it a couple times. Definitely not below the line.
Old March 11th, 2014, 09:59 PM   #489
GearMonkey
GearMonkey's Avatar
Nice DIY, helped me do my own oil change today!
One problem I ran into, well one of a few, was that the small o-ring that came with the K&N filter would NOT fit with the base plate. I just could not get the plate to get over the o-ring and flush with the base of the center tube. This happened on both K&N filters I tried (the inner rubber seal of the first filter ripped in 2 when trying to press it on the center tube, yes everything was well coated with oil and was still too tight a fit). I chose to keep the old (~2500 miles) small o-ring on there, and it still clicked when I pressed the plate on, so I think the seal will be good.
Does anyone have advice for next time or know why the o-rings were so freakin tough?
GearMonkey is offline   Reply With Quote
Old July 15th, 2014, 10:55 AM   #490
salcuta88
salcuta88's Avatar
Motorcycle(s): 2011 Ninja 250R (Sold), 2015 Rocky Mountain Soul (Runs on fat)
What about the small o ring rubber?
salcuta88 is offline   Reply With Quote
Old July 15th, 2014, 11:49 AM   #491
dubojr1
dubojr1's Avatar
What about it?
Old July 15th, 2014, 11:52 AM   #492
salcuta88
salcuta88's Avatar
Originally Posted by dubojr1 View Post
What about it?
Where do you put it? I haven't seen where he had put it in the pics.
Old July 15th, 2014, 11:58 AM   #493
dubojr1
dubojr1's Avatar
This is from an earlier post. It should help you.
Old May 4th, 2015, 08:10 AM   #494
Proteus
Daily Ninjette Rider
Proteus's Avatar
Motorcycle(s): 2012 Ninja 250R, 2015 Vespa GTS 300 IE Super, 1989 Honda Elite 80 (SOLD)
I changed my oil for the first time last weekend using this DIY. Very helpful, thanks!
My filter from Napa only came with the large O-ring, so I re-used the small one. Also re-used the crush washer as they didn't have the right size, and no leaks.
Check out my music at http://www.proteusmusic.com
Proteus is offline   Reply With Quote
Old September 14th, 2015, 09:23 PM   #495
MetaOrbit
Sorry to bring this back from the dead - but I had n00b question -
Just did my first oil change on my new-to-me Ninjette. I filled the oil level to just under the upper fill line in the sight glass - except I had it on the rear stand at the time.
Put it down completely on the ground and looked at it again - sight glass appears completely full. I'm assuming I overfilled it, right? Solution is to drain from the bottom again until the level comes back down (and check the level with both tires on the ground)?
Thanks!
MetaOrbit is offline   Reply With Quote
Old September 14th, 2015, 09:48 PM   #496
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Maybe overfilled it a tad. If it's that close, I wouldn't worry about it. The problem with that slight overfill is that now you can't see if you have a fuel leak into the oil sump.
I shoot for the middle of the sight glass for oil level.
If you're a masochist, you could snake a small diameter tygon tube (or whatever material, because it's only going to be in there for a few minutes) down the fill hole into the crankcase and siphon out a little oil. But I wouldn't worry about it: chalk it up to a noob learning experience.
Last futzed with by dcj13; September 14th, 2015 at 10:31 PM. Reason: Added siphon blurb.
Old September 15th, 2015, 06:55 AM   #497
Put it down completely on the ground and looked at it again - sight glass appears completely full. I'm assuming I overfilled it, right? Solution is to drain from the bottom again until the level comes back down (and check the level with both tires on the ground)? If not, when you do, the level will drop significantly.
Thanks!
When you changed the oil and filled it did you run the engine to warm and circulate the oil and fill the filter (assuming you changed the filter also)?
To properly check the level you should run the engine for a couple of minutes to warm and circulate the oil, then turn it off and wait 3 minutes to check the level. With the cycle completely level, check that the oil level is between the high and low marks, then top it off to just under the high mark. Being on the center stand shouldn't matter as long as the ground is level in both directions.
You need to keep and eye on the oil level because the Ninja will pump some oil into the airbox from the crankcase breather when running at high RPMs (like most of the time).
What oil did you use?
Old September 15th, 2015, 07:37 AM   #498
MetaOrbit
Thanks guys. I did try to go by the directions in the wiki and kept running the engine and topping off until I got to just under the full mark. It was only after I took it off the rear stand that the oil looked to be beyond the full line.
As for oil, I used synthetic Rotella T6, 5w-40.
I may drain a little bit of oil just to be safe. For what it's worth, it appeared that the previous owner had it overfilled as well. Sigh.
Old September 15th, 2015, 08:15 AM   #499
You could drain a bit out, but if it's pretty close you should be fine. Chances are you will lose a little over time.
Most likely the bike was not completely level either on the stand or off. If you have level ground the center stand it the easiest way to get a good look at the sight-glass.
T6 is a good choice for the Ninja IMO.
Old March 1st, 2019, 09:31 AM   #500
MrMushroom86
MrMushroom86's Avatar
Motorcycle(s): 1994 Kawasaki Ninja 250R, 2009 Kawasaki Ninja 250R Limited Edition
The STP SMO12 has been replaced by STP S6012 just in case anyone was wondering
MrMushroom86 is offline   Reply With Quote
Is it normal for oil to increase a bit in the crankcase after an oil change? cadd 2008 - 2012 Ninja 250R Tech Talk 10 May 15th, 2014 08:38 PM
Synthetic oil at 300 mile oil change? anacron 2013 - 2017 Ninja 300 Tech Talk 14 July 29th, 2013 04:58 PM
Not a DIY OIL Change just a view and some info Surferboy120 2013 - 2017 Ninja 300 Tech Talk 4 October 8th, 2012 11:44 PM
Oil drain plug gasket for oil change. tsdexter 2008 - 2012 Ninja 250R Tech Talk 8 July 10th, 2012 01:00 PM
change oil filter, without draining oil? peter330 2008 - 2012 Ninja 250R Tech Talk 5 May 30th, 2010 01:08 PM
