Old August 18th, 2010, 12:48 PM   #41
GeneJunkie
GeneJunkie's Avatar
Kind of a dumb question... do you need to rejet after doing this mod?
GeneJunkie is offline   Reply With Quote
Old August 18th, 2010, 12:56 PM   #42
no
Old August 18th, 2010, 08:05 PM   #43
MikeCG23
Ride this!
MikeCG23's Avatar
Am I going to have to do this if I just get a slip on?
MikeCG23 is offline   Reply With Quote
Old August 18th, 2010, 08:34 PM   #44
if it pops on decel after you install it, yes.
the most accurate answer is... most likely.
Old August 18th, 2010, 08:41 PM   #45
MikeCG23
Ride this!
MikeCG23's Avatar
Awww crap. That looks complicated
Old August 18th, 2010, 08:44 PM   #46
it's not, really. if you get stuck, post up your problem and I'm sure someone will be able to help you sort it out.
btw, you don't have to do this mod if you add a slip on. you can just live w/ the popping... some people even like it that way.
Old August 23rd, 2010, 01:37 AM   #47
HorizonXP
Motorcycle(s): 09 Ninja 250 SE Lime Green/Diablo Black
What if I have popping on decel with my stock exhaust? Haven't touched the carbs or snorkle. My exhaust valves are apparently too tight though...
HorizonXP is offline   Reply With Quote
Old August 23rd, 2010, 02:01 AM   #48
how do you know that?
Old August 23rd, 2010, 02:30 AM   #49
HorizonXP
Doing my 12,000 km valve adjustment today. I need to take better measurements (my feeler gauges suck, the values jump from 0.15mm to 0.18mm to 0.20mm), but they're definitely between 0.20mm and 0.23mm.
Old August 23rd, 2010, 08:28 AM   #50
spooph
spooph's Avatar
Motorcycle(s): '08 Ninja 250R
MOTM - Oct '15
Great write up Kim! But I'm wondering if I'm wrong here.
I thought the kleen air system was designed to vent valve-train pressures and vaporized oil to the airbox and thus get burned through the engine, instead of venting to the atmosphere. I thought the extra oil in the air/fuel mixture is what caused the popping in the exhaust?
I didn't realize it injected air into the exhaust system? I thought the valve train was sealed from the combustion chamber? Isn't that what the valve seats are designed to do? And I haven't seen a port leading to the "chimney" on the valve cover from the exhaust ports. What am I getting wrong here?
I removed mine a while ago, simply because it makes maintenance easier. I then put one of those little K&N breather filters on there, and I think it makes it sound awesome. Valve train noise is a little louder, and it makes the thing sound like a machine.
Old August 23rd, 2010, 09:48 AM   #51
from Sport Rider magazine...
KLEEN(tm) (Kawasaki Low Exhaust Emission) System
* Helps keep exhaust emissions environmentally friendly
* KCA (Kawasaki Clean Air) system routes fresh air to the exhaust ports for reduced exhaust emissions
http://www.sportrider.com/bikes/2004...res/index.html
Old March 23rd, 2011, 04:15 PM   #52
Vip3rV333
Vip3rV333's Avatar
Name: 01010010 01101111 01101101 01100001 01101110
Motorcycle(s): 08 Ninja 250r
If I just clamp the big tube leading to the air box will it have the same effect? I want to just test the effects out w/o removing everything for now. I have way to much popping on throttle let off with my slip on. Used to sound cool now it just gets annoying as it causes way to much attention. (thats bad?! )
Vip3rV333 is offline   Reply With Quote
Old March 23rd, 2011, 07:20 PM   #53
wayanlam
wayanlam's Avatar
Motorcycle(s): 2014 Z250
i believe it might have the same effect, i saw a bike at the mechanics that did that. the mechanic told me that the owner was too conservative to take it all out, and opted to just plug the big pipe that used to plug into the air filter.
try it out and when you find that it has eliminated the backfire, buy this cap and close it off for good
nice and tidy under the fuel tank now. and a little lighter
Kawasaki Z250, Bored up to 300cc with 12.8 CR, 41hp at wheel 27nm torque, Two bros full exhaust with DB killer
Dynojet Power Commander V, KnN Open filter, intake and exhaust ported, Puig Windshield
wayanlam is offline   Reply With Quote
Old March 30th, 2011, 06:37 PM   #54
Momaru
Momaru's Avatar
Looks good Wayan. Alternatively, you can DIY a blockoff cap for almost free using some spare thick-ish sheet metal (think it was 16 gauge) and using the OEM breather valve (what the blockoff plate replaces) as a pattern.
Proud member of the Blue Army
Old March 31st, 2011, 06:17 PM   #55
wayanlam
wayanlam's Avatar
yeah, i researched it a little over here after i got this bit. and i found that i could get a sheet thats 200 x 100 x 0.6 cm of billet aluminium and get almost 500 of these from that one sheet, making the material cost roughly 50 cents, lol
labor cost to cut them out (manualy at a metal lathe place, not CNC) would cost another 2.5 buks. so theoretically i could make them for $3. but thats just too much work and too many pieces, haha... unless someone wants to buy the other 490~ bits!
Old April 1st, 2011, 04:09 PM   #56
Momaru
Momaru's Avatar
I'm sure you could probably sell at least half of 'em to forum members. I know my little dremel-cut blockoff plate took a lot longer to get looking decent than I wanted it to; time I could've spent doing other things like riding.
Old April 1st, 2011, 06:19 PM   #57
Boosted139
Motorcycle(s): 2009 Ninja 250R SE, 2009 Triumph Daytona 675
I just removed the kleen air system and I just plugged both ends. I purchased the block off plate, but when i removed the oem plate, i noticed it had a gasket while the new plate did not. Just wanted to double check that is how it's supposed to be. I assume it's fine, but nothing wrong with double checking
Boosted139 is offline   Reply With Quote
Old April 1st, 2011, 06:23 PM   #58
if the oem plate uses a gasket, I would advise to use a gasket with the new plate... or at least some sort of gasket sealer type of material. last thing you would want is an air leak there.
Old April 1st, 2011, 06:34 PM   #59
wayanlam
wayanlam's Avatar
hey justin, the gasket (rubber block with a metal spring valve) sometimes sticks to the OEM plate. all you need to do is pull it off, and put it back in the hole (the right way round).
in my case the rubber gasket stayed in the bike, i took it out, and cleaned it up before putting it back in and closing it up with the new block off plate.
Old April 1st, 2011, 06:57 PM   #60
Boosted139
Makes sense, thanks!
Old April 2nd, 2011, 10:01 AM   #61
Momaru
Momaru's Avatar
Same deal for me; it stayed in there when I pulled my breather valve off, but I pulled it cleaned & replaced it. Also put a little high-temp gasket sealer around the outside metal rim, just to be sure.
Old April 2nd, 2011, 11:28 AM   #62
DR1300R
DR1300R's Avatar
Motorcycle(s): 2000 Hayabusa 2009 Ninja 250R
My question as well?
busastampede.com
DR1300R is offline   Reply With Quote
Old April 2nd, 2011, 11:28 AM   #63
DR1300R
DR1300R's Avatar
And answered..
busastampede.com
Old April 21st, 2011, 04:41 PM   #64
Jojah17
Jojah17's Avatar
Motorcycle(s): 2008 Honja
Sorry to revive this DIY but I gots a question for y'all. I've got PODs and the Kleen air system removed from my bike (shop installed when I took in for an initial checkup/rundown). Finally decided to take a peek at this today and I've got a question. Instead of blocking off the hole in the cylinder head I've got a tube that runs back to another hole under the carb assembly ontop of the case (possibly the crank case vent-port right next to the VIN?). Is this a horrible idea? Should I remedy this ASAP? Am i going to blow myself up? Should I stop drinking so much? Thanks in advance!
Edit: Just went and looked...this is definitely whats going on.
Ninja Edit 2: stolen from another forum...sounds like its not a big deal:
"By tying the two hoses together air can't go anywhere. Hence the valves don't open (and air doesn't flow into the exhaust). Block off plates accomplish the exact same thing and like you said, it looks cleaner.
What you're talking about with the crankcase vent is referred to as "Crankcase evacuation".
Normally you don't want crankcase pressure building so any positive crankcase pressure is pulled into the intake tract and burninated. The mod in question ties the crankcase vent to the clean air system. So the reed valves STILL function, but instead of pulling in fresh air (and causing popping on decel) you're pulling in that ****** crankcase air (which doesn't go "pop"). This vacuum causes negative pressure in the crankcase which in turn causes the rings to expand (creating a better seal). So in turn you have a little more cylinder pressure and you make a bit more power.
It's probably hardly noticeable in this application, but if anything it's "free" horsepower, so why not. The only drawback with crankcase evacuation is faster cylinder wall and ring wear (not very extreme in this application), and in certain car engine applications can starve the valvetrain of oil."
...maybe i'll leave it
Jojah17 is offline   Reply With Quote
Old April 21st, 2011, 08:48 PM   #65
why would you want to?
Old April 22nd, 2011, 05:54 AM   #66
Jojah17
Jojah17's Avatar
Because "Crankcase Evacuation" sounds awesome??
Seriously though, I'll probably end up going with a block off plate/breather on the crankcase vent but its good to know that its not the most uncommon thing in the world.
Old May 1st, 2011, 12:12 PM   #67
Jojah17
Jojah17's Avatar
Update: decided to slap on a block off plate and run a regular crankcase breather. Bike looks cleaner, seems to warm up faster and have a bit more throttle response. Not sure if its in my head but glad I did it.
Total time:
Installing block off plate and breather- 7 mins
Shake down run around the block- 5 mins
Running out of gas on way back home, going to get gas- 35 mins
Having the gas tube pop off of the canister and go directly into my gas tank- 2 secs
Getting the damn thing out- 1 hr...
Im awesome!
Old May 5th, 2011, 06:05 AM   #68
NicoleH28
NicoleH28's Avatar
Motorcycle(s): 2011 Ninja 250r Special Edition White & 2006 Suzuki GSXR 600
I have a hose that Im not sure where it goes...it's coming up right out of the middle of the carburetor? Does that come off?
NicoleH28 is offline   Reply With Quote
Old May 5th, 2011, 06:09 AM   #69
NicoleH28
NicoleH28's Avatar
So, I have Kleen Air System off however, I have an extra tube. It was coming up right between the carbs...can that be remove?
Old May 5th, 2011, 06:10 AM   #70
Jojah17
Jojah17's Avatar
Where does it run to? Sounds like the vacuum line for the petcock.
Old May 5th, 2011, 06:15 AM   #71
nattygirl
nattygirl's Avatar
Motorcycle(s): 2010 Kawasaki Ninja EX250 Special Edition Red/Black
Does the other end of that tube plug into this?
Or is it a Skinner, thinner tube? If so, jojah's probably right. When you put your tank back on, you plug that tube back into the peacock that's under the gas tank.
'10 Ninja 250R SE Red/Blk
Mods: Projekt D FE, Protons, HB Blk Windscreen, HIDs, TBR Blk Series Slip-On, Shogun Sliders, Solo Cowl, Integrated Tail Light, Gls Blk Rear Fender, Red Accents
nattygirl is offline   Reply With Quote
Old May 5th, 2011, 06:25 AM   #72
NicoleH28
NicoleH28's Avatar
Here are the hoses the extra one I am confused about is the bottom one
And here is where it was connected...
Old May 5th, 2011, 06:34 AM   #73
nattygirl
nattygirl's Avatar
Take a look at kkims picture in my previous post. Do you have that long tube that is running down the middle and goes down the back? I'm pretty sure that's where it goes. One end connects to the carbs and the other end remains open. I think its for overflow. Can someone please confirm?
Old May 5th, 2011, 06:35 AM   #74
NicoleH28
NicoleH28's Avatar
Yeah it wasn't connected to anything at all on the other end...so it just hangs there for air flow?
Old May 5th, 2011, 06:53 AM   #75
nattygirl
nattygirl's Avatar
Its not for air flow... I'm pretty sure its for excess fluid/gas in the carbs. So they don't get flooded. Any excess just drips down to the bottom. There should be some mounted loopholes that you slide that tube through. It helps hold them in place. My bike has two tubes that just hang through there. But I think cause mine is a Cali model.
Old May 5th, 2011, 07:40 AM   #76
NicoleH28
NicoleH28's Avatar
I figured it out and the bike it back together and running! Woohoo!
Old May 5th, 2011, 09:38 AM   #77
nattygirl
nattygirl's Avatar
Have you rode your bike yet? Did it take away your popping with the two bros exhaust?
Old May 5th, 2011, 10:05 AM   #78
NicoleH28
NicoleH28's Avatar
Nope, started raining here...
Posted via Mobile Device
Old May 5th, 2011, 10:14 AM   #79
shawn57187
shawn57187's Avatar
I was looking at another DIY for removing the kleen air system and saw this comment. I'm wondering what you guys think about it? The poster seems to think the popping sound means we need better carb tuning.
The Clean Air System operates by using the carburetor intake manifold vacuum through the vacuum switch valve to create negative pressure in the crankcase. It then carries the crankcase / cylinder vapors to the combustion chamber to be burned. The vacuum switch valve of the clean air system also serves to function as a pressure relief point for crankcase / cylinder head vapors, in the event of an internal engine malfunction (much like the PCV system on a car). If this occurs, excess vapors are vented through vacuum switch valve into the air cleaner. One symptom of crankcase vapors flowing into the vacuum switch valve is oil residue in the air filter housing.
When the engine is running, a certain amount of combustion gas escapes past the rings into the crankcase; this is normal. When the engine is at idle, vacuum overcomes the spring tension of the check valve and causes it to move inward and restrict vapor flow into the intake. When the bike is cruising and vacuum is lower, the spring tension moves the check valve away from the seat, allowing higher flow of crankcase vapors into the intake. Control of crankcase vapor flow is used to prevent excessive amounts of vapors into the intake at idle speed. This could cause rough idle or incorrect idle speeds.
The air suction valve is on top of the valve cover and is attached by hose to the vacuum switch valve. The position of the air suction valve allows it to pull vapors from inside the engine without sucking oil from the crankcase (reeds on the underside of the air suction valve deflect and help separate droplets of oil from the blow by vapors). A hose connects the vacuum switch valve to a vacuum port on the air cleaner housing. This allows the vapors to be siphoned directly into the engine without gumming up the throttle body or carburetor.
Because the clean air system pulls air and blow by gases into the intake manifold, it has the same effect on the air/fuel mixture as a vacuum leak. This is compensated for by the calibration of the carburetor or fuel injection system. Consequently, the clean air system has no net effect on fuel economy, emissions or engine performance -- provided everything is working correctly. Combustion gases consist mostly of carbon dioxide and water vapor, but do contain small amounts of unburned fuel and other contaminants. Water and fuel vapors in the crankcase can react to rapidly break down and shorten the life of engine oil. In addition, these vapors contribute to the formation of sludge in the crankcase. The worst case scenario if the Clean Air System is plugged or blocked is blown seals, blue exhaust smoke, power loss, poor drivability, excessive carbon build up in the combustion chamber & possible head damage.
WARNING: Removing or disconnecting the clean air system in an attempt to improve engine performance, gains nothingand is illegal. EPA rules prohibit tampering with any emission control device. Disabling or disconnecting the clean air system can also allow moisture to accumulate in the crankcase, which will reduce oil life and promote the formation of engine-damaging sludge.
Backfire, popping, knocking, crackles...etc. is caused by a too rich or too lean carb. The amount of crankcase vapor on the carb and combustion system is nill, because of the calibration of the carb and the vacuum switch valve. Hope this has helped somebody.
shawn57187 is offline   Reply With Quote
Old May 5th, 2011, 10:37 AM   #80
NicoleH28
NicoleH28's Avatar
Yikes, hope we don't ruin our bikes by taking off the kleen air system
For Sale: Kleen Air System Jiggles Motorcycle-related 23 February 10th, 2014 07:07 AM
Removing the Kleen Air System on a stock bike oblivion007 2008 - 2012 Ninja 250R Tech Talk 3 January 25th, 2014 04:28 PM
Kleen Air System - Breather Filter DmbShn41 2008 - 2012 Ninja 250R Tech Talk 3 October 20th, 2013 07:51 AM
Who's taken off their Kleen Air System? walty87 2008 - 2012 Ninja 250R Tech Talk 10 January 29th, 2012 10:37 AM
Kleen Air system mxnello 2008 - 2012 Ninja 250R Tech Talk 6 April 13th, 2009 01:32 PM
