Old June 16th, 2016, 07:48 AM   #121
tyfmorgan
Motorcycle(s): 89 ninja 250
Please help with diode.
I made the diode myself exactly as the instructions were online. (Both this site and the another). Mt bike is an 89, so they don't sell a "Plug in" kit for it. I'm just wondering if there is something odd about certain years or something that would make mine not work. I did notice that there are some slight differences in switch gear on certain years. This really has me going insane. I have a basic knowledge of wiring and have wired complete motorcycles in the past. I followed the instructions to the letter in making the diode (It's pretty simple).
Thanks for any help or advice
tyfmorgan is offline   Reply With Quote
Old June 16th, 2016, 09:53 AM   #122
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
The "kit" linked in the OP is just the diodes and some lead wires soldered together. It will work on any bike. It's the section from the red to blue in my diagram. (There is a PnP kit using OEM plugs for the NewGen.)
The only thing I can think of is you wired the diodes backwards, which would cause the indicator to not work at all but should still stop the blinkers from bleeding over to the other side.
This really is a very simple thing (just made slightly confusing by the way the OEM setup is*).
  1. Cut the green and gray wires going to the indicator.
  2. Add diodes to the green and gray wires coming from the bike. The stripe should be toward the indicator, not the bike. That would be the red wires in the OP's kit.
  3. Connect the striped end of the diodes together. This is the blue wire in the kit.
  4. Connect that to one of the indicator's wires (green in my diagram). That's now the + wire for the indicator.
  5. Connect the other indicator wire to ground. That's now the - wire for the indicator.
The junction allows either the green or gray wire to power the indicator. The diodes keep each side's power from being able to get to the other side via the junction.
*The stock setup uses the other side's blinkers to complete the indicator circuit. The inefficiency of the bulbs means the little bit of power coming through isn't enough to light them up. When you switch to LEDs, that little bit of power is enough for them to light up. It's always happening in the stock setup, but you can only see it with LEDs.
Old June 17th, 2016, 07:30 AM   #123
tyfmorgan
Help with Diode
I'm going to get a kit and try this. I really appreciate your reply and your help.
Old July 2nd, 2016, 12:32 PM   #124
Did it work?
Old April 30th, 2019, 02:12 PM   #125
Red Good
Motorcycle(s): lots , all genres
Is it possible to put the diodes in backwards . ? I found it , must have diodes seperate on the harness side to work correct . Good info here . Thanks .
Last futzed with by Red Good; April 30th, 2019 at 03:21 PM.
Red Good is offline   Reply With Quote
Old April 30th, 2019, 03:44 PM   #126
Yes, don’t get the diodes reversed or else it won’t work.
Old November 9th, 2021, 12:13 PM   #127
shspvr
Motorcycle(s): 07 Kawasaki Ninja 250
In case any of you folks want to change out there Dash Cluster Gauge to Led Wedge Bulbs look for bulb size T5 37 58 70 73 74 2721
shspvr is offline   Reply With Quote
Need wiring help for new turn signals Insane Pie 2008 - 2012 Ninja 250R Tech Talk 15 May 24th, 2014 02:26 PM
wiring for flush mount front turn signals for 07 ninja 250 james250ninja 1986 - 2007 Ninja 250R Tech Talk 2 October 4th, 2013 01:35 PM
Wiring LED strips as brake lights, turn signals, and "day-time lights" blackninja18 2008 - 2012 Ninja 250R Farkles 32 August 7th, 2013 03:41 PM
Wiring things to turn on/off with the key karlosdajackal 2008 - 2012 Ninja 250R Tech Talk 10 August 16th, 2010 11:49 PM
