Old January 25th, 2011, 07:27 PM   #161
MiniCog
MiniCog's Avatar
Motorcycle(s): Past: 2007 250 Ninja 2005 XR650R 2003 KLX400R
Originally Posted by Yasko View Post
Can you post photos of the levers???
Yes, but it will have to wait until Sunday night/Monday because I go home on the weekends and keep the bikes there.
I cut part of them off because I don't like all 4 finger on the clutch lever, there's room for 3 finger, but it's long enough I can use 2 fingers and it won't hit my other 2 fingers.
When life throws turns at you, aim for the apex.
MiniCog is offline   Reply With Quote
Old January 25th, 2011, 07:36 PM   #162
mikesova
Motorcycle(s): 2002 XR200r
Photos of my 12v power supply...Anyone have a better spot for the mount???
I use one that is a 12 volt ext. cord with the male end cut off. The female end I just loosely ziptied to the left fork down below the fairing. It worked fine and was out of sight.
mikesova is offline   Reply With Quote
Old January 25th, 2011, 08:33 PM   #163
MiniCog
MiniCog's Avatar
I like that, good idea!
Old January 25th, 2011, 09:49 PM   #164
Yasko
Texas Newbie
Yasko's Avatar
Motorcycle(s): 07 Ninja EX250, 07 FZ6
Yes...That does sound like a good spot for it...
Yasko is offline   Reply With Quote
Old January 29th, 2011, 01:37 PM   #165
coondog
coondog's Avatar
Motorcycle(s): 2005 ninja 250 street fighter, 2008 street fighter ninja 500, 2001 nsr 125
Took both girls out onto the I for 15 minutes until civilization ended, got on the Beeline Hwy. and did them both up; full throttle to redline through all gears out to old Moroso motorcycle track and came home. Glorious, simply glorious.
coondog is offline   Reply With Quote
Old January 29th, 2011, 03:57 PM   #166
gfloyd2002
User Title Free Since '12
gfloyd2002's Avatar
MOTM - Feb '12
Changed from stock grips to ProGrip 719 gels; switched out the stock silver handlebar bolts for black; put on legally required front license plate using windscreen bolts. Had to drill and bend the plate to make it work, but happy to get it on without the need to drill new holes into my ninjette or mount a bracket. Went for a 50 mile ride to test it out. The gel grips, combined with a bit of extra tightening of the new handlebar bolts worked great to resolve a hand buzzing problem I'd been having. The plate catches some wind underneath it, need to shape it more - heading out with ball peen hammer now.
As an aside, here's how I changed the grips: slid a small, soap-covered screwdriver under the old grips to break up the bit of glue holding the grips on out of the factory and deliver the soap. Pulled out the screwdriver and the grips slid right off with a bit of a twist. I cleaned off the soap, then put hairspray onto the bars and the new grips slid on pretty easy with the wet hairspray. When the hairspray dried, it dried tacky and new grips don't move around at all now. Would have been an easy job but for some stripping of the phillips head bolt holding the bar end on the throttle side - luckily I'd anticipated and ordered a backup bolt.
Old January 29th, 2011, 06:03 PM   #167
Yasko
Texas Newbie
Yasko's Avatar
Did you have to remove the bar ends?
Old January 29th, 2011, 06:09 PM   #168
DaBlue1
DaBlue1's Avatar
Put on some new levers. Also stopped by Cycle Gear a got a hi-viz Bravo Victor vest for $24.99. http://www.cyclegear.com/spgm.cfm?L1...em=URI_BVYELSM
Old January 29th, 2011, 06:44 PM   #169
gfloyd2002
gfloyd2002's Avatar
MOTM - Feb '12
Yeah. I couldn't get under the grips to break the friction with the bar ends on.
Old January 29th, 2011, 09:15 PM   #170
MiniCog
MiniCog's Avatar
Nothing special, I just but the ball ends off (and then some) and ground the leaves down.
Click for bigger pictures...
Old January 29th, 2011, 09:26 PM   #171
Yasko
Texas Newbie
Yasko's Avatar
MiniCog...That looks very comfortable...
It's not so comfortable for me to cover the front break at all time... It looks like that would help...
Old January 29th, 2011, 10:21 PM   #172
MiniCog
MiniCog's Avatar
I made the clutch lever short enough that I can 2 finger it easier. The brake lever didn't really matter, but they had to match.
I just wanted something different, you know? I also ground my gas cap lip down.
Old January 30th, 2011, 03:08 AM   #173
Yasko
Texas Newbie
Yasko's Avatar
Kool...I hope to get better at ridding this spring, and maybe we can ride together this summer???
Old January 30th, 2011, 11:40 AM   #174
MiniCog
MiniCog's Avatar
Maybe, I don't ride in Dallas, I go to the house in Pittsburg on the weekends. But we usually go on a short trip 1 or 2 times in the summer.
Old January 30th, 2011, 05:54 PM   #175
mikesova
MiniCog, You do know why those balls were on the end of the levers, right?
Old January 30th, 2011, 08:03 PM   #176
MiniCog
MiniCog's Avatar
So it won't poke through you in a crash.
I know, less safe, but if I crash at speed, I have a few other things to worry about. But I made sure the tips were round and blunt, I didn't want to make little daggers.
Old February 5th, 2011, 07:52 AM   #177
TrueFaith
TrueFaith's Avatar
Motorcycle(s): 2011 Honda CBR250R
I just got some new gel Pro-Grips in red & black from Motorcycle Superstore. With 3' of snow on the ground here, futzing with your bike is the only cure for Cabin Fever.
TrueFaith is offline   Reply With Quote
Old February 5th, 2011, 08:40 AM   #178
MiniCog
MiniCog's Avatar
Nothing, I didn't go home this weekend because of the weather. I'll be sure to make it home next week!
Old February 5th, 2011, 08:44 AM   #179
Yasko
Texas Newbie
Yasko's Avatar
I was thinking the same on gel grips today...
Old February 5th, 2011, 10:35 AM   #180
coondog
coondog's Avatar
Originally Posted by KURT View Post
I started this thread, on another Ninja forum, and it's been pretty popular.
Killed a dove with it! Er... actually killed it with the padded shoulder of my jacket. The wife and I rode up to Wickenburg for breakfast. I had just cranked the throttle, coming out of a turn, when the flying rat nailed me. He did not survive.
She has put about 200 miles, on her new BT-003's, and loves them. ( Smoother ride, less stress.)
Went over 100mph on both of them, road to myself, thanking the Lord for feeling of "freedom."
Old February 5th, 2011, 12:57 PM   #181
Yasko
Texas Newbie
Yasko's Avatar
Amen to that brother... I'm a new man since I got my bike...Thank you God for making it a 250...
Old February 5th, 2011, 04:43 PM   #182
Luxodave
Luxodave's Avatar
Motorcycle(s): 2009 Yamaha FZ6
It is snowing here, so I did not do anything to it. But, I parked my new truck next to it.
Luxodave is offline   Reply With Quote
Old February 5th, 2011, 05:12 PM   #183
KURT
Resident Old Guy
KURT's Avatar
Motorcycle(s): sold
Pulled out the bikes, and warmed them up this afternoon. Maybe take 'em out for a ride tomorrow.
KURT is offline   Reply With Quote
Old February 5th, 2011, 05:51 PM   #184
Animal78
Motorcycle(s): 08 Ninja 250(sold) 2000 Ninja 250 (sold) 2012 Ninja 250r 2020 Harley Sportster (rarely ridden)
I finished raising my bike back to stock height and took it for a ride around town. It was a good day. Thinking about riding it to church tomorrow.
Animal78 is offline   Reply With Quote
Old February 5th, 2011, 11:22 PM   #185
MiniCog
MiniCog's Avatar
What did you get?
Old February 5th, 2011, 11:28 PM   #186
Luxodave
Luxodave's Avatar
What did you get?
Pro 4X Frontier. Handles the snow really well.
Old February 6th, 2011, 10:49 AM   #187
slolane
Motorcyclist
slolane's Avatar
Motorcycle(s): 2014 Ninja 300 ABS
Tested my Scorpio SR-i1100 rLink alarm with the GPS part since it's in the lower 40's here in MD and I finally got the bike out for a short ride.
slolane is offline   Reply With Quote
Old February 6th, 2011, 08:26 PM   #188
gogoKawi
gogoKawi's Avatar
Motorcycle(s): 2014 Ninja 300, 2008 ZX6, 2011 Ninja 1000
It was in the mid 40s today, so took the 250 out for a spin. Tomorrow, lube chain and decide on what tires to get. Probably the BT-45s.
gogoKawi is offline   Reply With Quote
Old February 6th, 2011, 10:19 PM   #189
MiniCog
MiniCog's Avatar
Aww man, that's a cool truck!
Old February 6th, 2011, 10:30 PM   #190
Yasko
Texas Newbie
Yasko's Avatar
All the ice is gone, so I was able to get the bike out for a short ride...
Old February 6th, 2011, 10:33 PM   #191
Luxodave
Luxodave's Avatar
Thanks.
Old February 6th, 2011, 10:35 PM   #192
bluesinorbit
bluesinorbit's Avatar
For the first time since I picked up the 250 a month ago, I took my bike out just to ride. Between work and a bad cold, this was literally the first time I took it out for no other reason than to ride. I got to Pacific Coast Highway, 20 minutes away from the apartment, and headed south.
And it was... awesome. With the Ninja as my only mode of transportation, I've been riding it everyday, point A to point B. It's a totally different feeling to let the road take you to... wherever, and the view of the Pacific Ocean didn't hurt either. There was a ton of other riders out too, all very friendly, except a few stoic Harley riders. I haven't gotten a middle-finger salute back for waving yet.
We need to get a 250 group together...
bluesinorbit is offline   Reply With Quote
Old February 7th, 2011, 03:21 AM   #193
gfloyd2002
gfloyd2002's Avatar
MOTM - Feb '12
I've got total envy over the white SE.
Old February 7th, 2011, 07:33 AM   #194
Animal78
Yesterday I changed the oil and filter. Rode the neighborhood for a few minutes then back to the garage with it. Still need to clean and lube the chain up. Lot's of goop built up on there. Then on to the tires!
Old February 13th, 2011, 12:38 PM   #195
coondog
coondog's Avatar
Took out my 500 streetfighter with the new D&D 4 into 1 and went up along A!A which is like floridas pacific coast hwy. in areas. Went way farther than I thought and came back on hwy. think it was all subliminal cause I had the I to myself and just cranked her like she loves, aaaaaaaall the way home. Damn, what it's like to ride. Bless and keep y'all.
Old February 13th, 2011, 01:45 PM   #196
bluesinorbit
Man, I wish I had the Ninja five years ago when I lived in Fort Lauderdale. Do me a favor and stop by Las Paradas off of Fort Lauderdale by the Sea. If you haven't hit that spot already, you gotta. Best hoagies ever.
Old February 13th, 2011, 02:04 PM   #197
Cab305
Cab305's Avatar
Motorcycle(s): Blue 10 250r
The ole chain clean and lube!
Cab305 is offline   Reply With Quote
Old February 13th, 2011, 03:01 PM   #198
ahenthus
ahenthus's Avatar
Motorcycle(s): 2008 Ninja 250R, 1994 HD Sportster, 1975 Yamaha XS650B and many works in progress.
I rode today for the first time in months. After a thorough pre ride check and airing up of my tires I took off for about 30 miles of backroads riding. I never got over 60 and really enjoyed the brisk air. I never got uncomfortable but it was a little chilly when the sun hid behind a cloud. Fortunately, there weren't many clouds. It was my first opportunity to begin breaking in my new Corbin saddle and new look. In the last couple of months I've cleaned up the tailcone with a cowl in place of the passenger seat and fabricated a very professional (IMHO) looking license plate holder with LEDs. I haven't gotten to any mechanical upgrades yet, but I may eventually. At most it'll probably only be a modest rejetting and K&N or something like that. All in all a very fun afternoon.
ahenthus is offline   Reply With Quote
Old February 14th, 2011, 06:14 PM   #199
eddiekay
eddiekay's Avatar
Motorcycle(s): 300, WeeStrom
Did the sprocket swap to 15 and 41
35mph @ 10k....50+ @ 10k....didnt get any further because it started to rain but I can see already it's exactly what I wanted for the riding I do.
Old February 14th, 2011, 06:37 PM   #200
MiniCog
MiniCog's Avatar
What gear were you in doing 50?
Discovered something scary about my Ninjette today... kjohng General Motorcycling Discussion 28 October 15th, 2021 01:40 PM
Sold the 2006 Ninjette today :( Renner General Motorcycling Discussion 31 October 16th, 2014 11:46 PM
Today I Gave My Ninjette Wings! BlueHairSar Pictures 5 June 20th, 2013 07:38 AM
my bro went down today on his ninjette richierich781 !%@*#$%!)@#&!%@ I crashed! 46 January 18th, 2013 11:59 AM
Ninjette. org hacked today CC Cowboy Off-Topic 9 April 3rd, 2011 08:55 AM
