Go Back   ninjette.org > Marketplace > Motorcycle-related
Old October 20th, 2011, 10:09 AM   #241
jdoucet93
jdoucet93's Avatar
Motorcycle(s): 2009 R6
Originally Posted by Phil7153 View Post
Well if you do, id sure appreciated it. As im sure a lot of other members would as well. Damn kawasaki and their ****** gauge clusters. Why cant they just and a temp gauge and gear indicator?
AMEN! haha but then again... it's only a $4000 bike...
jdoucet93 is offline   Reply With Quote
Old October 20th, 2011, 10:18 AM   #242
jdoucet93
jdoucet93's Avatar
$4000 plus maybe $20 extra on their part. Id gladly pay $100 more for those features.
Good point. Well I just ordered the ebay indicator. I'll take some good pictures and put together a good DIY for you guys as soon as it comes in.
Old October 20th, 2011, 10:19 AM   #243
gadgetguy1288
Coastie Tweet
gadgetguy1288's Avatar
Motorcycle(s): 2011 250R Ebony, 2012 BMW F800R White
You rock!
Randy
USCG
Air Station Elizabeth City
gadgetguy1288 is offline   Reply With Quote
Old October 20th, 2011, 10:26 AM   #244
jdoucet93
jdoucet93's Avatar
Originally Posted by gadgetguy1288 View Post
You rock!
haha thanks. Just trying to help out some fellow riders. Paying it forward.
Old October 20th, 2011, 10:39 AM   #245
wellcraft
wellcraft's Avatar
Motorcycle(s): Ninja 250R
First of all, let me say that I'm jealous. I've been wanting to get one of those gauges. Probably will at some point in the near future.
Anyway... It should be the blue wire coming from the harness on the koso gauge.
If it isn't that one, I'm not sure. If you have a multimeter, you can always start randomly testing wires by putting the bike in gear, start testing wires until you find one that doesn't read a 12v signal, then wile still touching that wire, shift back into neutral. If the voltage jumps to around 12v, You've found your neutral line.
EDIT: Not sure if you have an RX-2 or and RX-2N. The RX-2N neutral wire is blue, the RX-2 neutral wire is white.
Thanks man, I was trying that and surprisingly I couldn't a signal from any of the wires. The koso I have is the rx2, super nice gauge. If I connect the white wire from the gear indicator directly to the battery (+) should the gauge change to neutral?
wellcraft is offline   Reply With Quote
Old October 20th, 2011, 11:29 AM   #246
wellcraft
wellcraft's Avatar
I disconnected the light green wire from the bike plug which is the white wire on the koso gauge and no signal on the koso gauge, this means I have the correct wire. No when I do the test with the tester it doesn't do anything and I hooked up the gear indicator and it doesn't do anything either. I'm guessing the gear indicator isn't working properly.
Old October 20th, 2011, 11:34 AM   #247
jdoucet93
jdoucet93's Avatar
Yes, if you hook the white wire from the gauge straight to the battery the gauge should read neutral. If not, then there is a chance that the indicator is malfunctioning.
Old October 20th, 2011, 11:40 AM   #248
wellcraft
wellcraft's Avatar
That's what I thought, I did that and it doesn't change. This sucks
Old October 20th, 2011, 12:18 PM   #249
wellcraft
wellcraft's Avatar
Just found out that if I touch the negative pole in the battery with the white wire the gauge change to neutral. So the gauge is good. I just need to find the sweet spot.
Old October 20th, 2011, 12:37 PM   #250
wellcraft
wellcraft's Avatar
This thing is alive and works real nice, so far worth the $28. You guys just need to Fab some brackets to put the sensors and one for the magnet.
Is the light green wire the one needed to connect the wite wire from the gear indicator. White from the koso gauge side.
Old October 20th, 2011, 12:52 PM   #251
headshrink
headshrink's Avatar
Originally Posted by wellcraft View Post
I ended up buying the ebay one, installed yesterday and works great. I had to fabricate a bracket to work on this bike but works nicely.
Only problem I have is that I dont know where to hook up the white wire from the gauge and get a neutral signal.
How can I do it. I go through all the gears but I'm just missing the neutral.
Thanks for any help.
Any chance you can put up some pictures of the switch/mount you fabricated?
Old October 20th, 2011, 03:04 PM   #252
jdoucet93
jdoucet93's Avatar
AWESOME! Well thats definitely some good news.
Old October 20th, 2011, 03:13 PM   #253
pilotgeorge747
pilotgeorge747's Avatar
Motorcycle(s): 08 Ninja 250r 03 Yamaha R6 (Project bike)
Yes please do! I installed my ebay gear indicator a few weeks back and just mounts the senors on the sprocket cover and let's just say its pretty useless. I placed the magnets on the shifter and it did work for awhile after stationary testing but as soon as I went for a ride it displays just about every gear BUT the gear you are actually in lol.
pilotgeorge747 is offline   Reply With Quote
Old October 20th, 2011, 05:12 PM   #254
wellcraft
wellcraft's Avatar
Sure Bob.
Old October 20th, 2011, 05:24 PM   #255
wellcraft
wellcraft's Avatar
Some pics of the bracket. This was a test fit so I'm fabing another one tomorrow and paint it. The fits 3 pics is the bracket with the sensors and the last 2 is the bracket with the magnet.
Installation was simple after I figured out the neutral issue. After everything is installed it takes quite sometime to adjust the magnet. I still need to work on that tomorrow because I'm having a small false reading with first gear. Just need some more adjustment. I b.believe I can correct this by adding an additional magnet, getting some tomorrow.
Old October 20th, 2011, 05:31 PM   #256
headshrink
headshrink's Avatar
Not the prettiest thing, but well done with what we have to work with. I'm thinking some double-sided sticky tape, or similar, could be good to use on the switches until you get the placement perfect.... then bolt them down.
Old October 20th, 2011, 05:32 PM   #257
wellcraft
wellcraft's Avatar
A few more of the gauge installed. Planning on incorporate the gauge somehow to the koso bezel. Will be working on this in a few weeks.
Any question guys, feel free to ask. I will try to answer theme the best I can. English is my second language so sometimes is hard for me to use the right words.
I would love to do a DIY but I think I could be kind of confusing for you guys to understand me.
I could try if it helps in any way.
Old October 20th, 2011, 05:38 PM   #258
headshrink
headshrink's Avatar
Your "cockpit" is amazing looking, great job!
When I compare your pics of the magnetic switched to the pics on ebay, they are mounted differently. It appears they flip one switch upside down, where you turned yours around.
I don't know if that makes any difference functionally, but thought I would point it out in case it helps.
Old October 20th, 2011, 05:38 PM   #259
wellcraft
wellcraft's Avatar
That's why I'm doing a second one, that was a test fit. I used some double tape (automotive type not the 3m) on them but they weren't holding the sensors to well and that's why i used the tie raps.
Whanted to make sure everything was going to work.
I'll post some pics when I have the new bracket.
Old October 20th, 2011, 05:47 PM   #260
wellcraft
wellcraft's Avatar
Thanks for the kind words.
The reason I put the sensors that way is because I when I was doing the bracket I use a piece of aluminium that I had laying around and was to short, so I had put it up side down. I don't think it hurts but you have to take in consideration the wiring since is up side down. I connected severing and whn I was down shifting the gauge as giving me the wrong gears. So I had to check my wiring and then everything was good to go.
Right now is working good, just need to fine tune it and fine the sweet spot.
Old October 21st, 2011, 06:45 PM   #261
Magz
Magz's Avatar
Motorcycle(s): '06 Ninja 250
I have one of these on the way as well. Hopefully they'll last. It's good to see that they at least can be successfully installed.
Behind every great man is a woman rolling her eyes.
- Jim Carrey
Magz is offline   Reply With Quote
Old October 21st, 2011, 07:00 PM   #262
wellcraft
wellcraft's Avatar
I didn't use the bike today, but tested the bike on the stand, went though all the gears (up/down shifting) a few times and worked very nice. Didn't miss any gear. I think I found the sweet spot when adjusting the magnet.
Old October 29th, 2011, 08:17 PM   #263
wellcraft
wellcraft's Avatar
Rode the bike the whole week and put about 400 miles on it and the gear indicator worked perfect.
Old October 30th, 2011, 01:21 AM   #264
Are you kidding? You are easier to understand than the vast majority!
Old October 30th, 2011, 07:19 PM   #265
pilotgeorge747
Thanks for the pics Wellcraft! Using them I was able to actually get my gauge to work properly.
Old November 8th, 2011, 07:22 PM   #266
jdoucet93
jdoucet93's Avatar
Alright guys, my indicator showed up today and I have the day off from work tomorrow. So, if all goes well, I should be able to get a good write-up done and posted by thursday. So be on the lookout if interested.
Old November 8th, 2011, 09:20 PM   #267
headshrink
headshrink's Avatar
Sweet. How long did it take to get to you?
Old November 8th, 2011, 09:25 PM   #268
jdoucet93
jdoucet93's Avatar
About 3 and a half weeks. I ordered it on the 20th.
Old November 14th, 2011, 06:45 PM   #269
jdoucet93
jdoucet93's Avatar
Finally got this done guys. Sorry for the delay, I've been really busy with work.
But here you go: DIY: Ebay universal gear indicator
Hope this helps some of you out!
Old November 20th, 2011, 03:48 PM   #270
headshrink
headshrink's Avatar
wellcraft: How did the final fabrication of the switch-holding plate go? Did you use sheet metal?
Old November 20th, 2011, 06:09 PM   #271
wellcraft
wellcraft's Avatar
It's holding great. I think I already put about 800 miles since installation. I used aluminum, can't remember what gauge I used but it wasn't anything to thick. I was going to make a new one just for looks because this one was going to be more for a test fit, but since it take a while to get the perfect spot and is working great I decided to keep what I have, at least for now, maybe I might try during the winter.
Any other question, please don't hesitate to ask, I would like to help in any way.
Best regards.
Old November 20th, 2011, 11:58 PM   #272
headshrink
headshrink's Avatar
Best regards.
Sounds good, I may want to bounce a few things around. Let's continue this aspect of our discussion in the DIY: Ebay universal gear indicator thread, so we don't detract from KC's design. http://www.ninjette.org/forums/showthread.php?t=91040
Old November 26th, 2011, 09:30 PM   #273
headshrink
headshrink's Avatar
OK... KC, I've been thinking about you for the past two days, which is not a good thing. I'm about to go into the ER with some $hite in my eye.... hopefully it is just a scratch, but I'm really scared. I had a "phone appointment" (good job Kaiser... how ironic), and they don't seem too concerned because it apparently doesn't sound as bad is it is "supposed to be," but it isn't going away two days later..... I cried in front of my wife and young children. I'm not ashamed of crying, but don't want to scare them. I'm really freaked. At least the Mrs. agreed to get naked first.... I guess I'm not dying.......... although it feels like it. **braceing for all the "baby" remarks.**
Old November 26th, 2011, 10:33 PM   #274
What type of "$hite" in your eye? Did it happen while on your ninjette? Eyes are pretty resilient, so hopefully all turns out well as soon as they get out whatever needs to get out.
Old November 27th, 2011, 01:47 PM   #275
headshrink
headshrink's Avatar
I'm not sure... I was in my garage, and think it was airborne, because it happened as I leaned over to empty my shop-vac. There are some metal filings on the work bench, so hopefully it wasn't that (probably wasn't). I ended up going to er last night, and dr didn't find anything in there, but said I have a scratched cornea. I was a pretty anxious patient, and begging for drugs didn't get me anywhere. The cool thing is I just walked straight in, and the place was EMPTY.... it's funny how that still takes a couple hours though.
Old January 10th, 2012, 06:16 AM   #276
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Casey, your switch is a clever solution - well done
Old January 10th, 2012, 03:32 PM   #277
headshrink
headshrink's Avatar
Is this project currently dead?
If not, I want to give up my space to someone else who may be eagerly waiting to get on the list.
Old February 4th, 2012, 11:25 PM   #278
SlowBoyRacing
SlowBoyRacing's Avatar
Motorcycle(s): ZX6-R and etc.
If there is interest, I can put together a kit to have the best gear indicators on the market work on Ninja 250's.
Check out the thread: http://www.ninjette.org/forums/showt...541#post435541
SlowBoyRacing is offline   Reply With Quote
Anyone use a gear indicator? Ducati999 General Motorcycling Discussion 34 March 15th, 2014 09:12 PM
Shift Light, Gear Indicator, Temp Gauge - WHERE ARE YOU???!!! 2013 kawi girl 2013 - 2017 Ninja 300 General Discussion 14 October 21st, 2012 12:00 AM
Gauging Interest: Gear Indicators (one with shift light, one without shiftlight) SlowBoyRacing Motorcycle-related 13 March 2nd, 2012 11:27 PM
WTB: Rear OEM 2008+ Ninja250 Tail Light/Brake Light FerociousNINJA Items Wanted 5 March 29th, 2010 08:52 AM
