Old April 12th, 2014, 11:00 AM   #1
drc84
Motorcycle(s): 2004 EX250
2004 EX250 Leaking Coolant After Change
Hello everyone!
A few weeks ago, I changed the coolant in my 2004 EX 250. I used the guide featured on faq.ninja250.org.
When I finished changing it, I didn't notice the fluid leaking. However, as soon as the next day of driving to work, when I'd arrive at work or arrive back home, the bike would slowly leak coolant, as featured in this video:
https://www.youtube.com/watch?v=bhsA..._KvnsbKWPfByBA
As you can see, it doesn't leak much. It's been doing this since I changed the coolant, and I guess it hasn't run out of coolant yet. I checked the bolts that I loosened to change it and they all seem to be tight.
What should I do?
Thanks for taking the time to read this, and for any help you can give me!
drc84 is offline   Reply With Quote
Old April 12th, 2014, 06:01 PM   #2
You need to solve that problem as soon as possible !!!
A lack of coolant around the cylinder head can be catastrophic for these engines.
It seems to be coming from the drain plug or from a crack in the body of the pump or connectors to the hose.
The high pressure in the system makes it leak more when hot.
Old April 12th, 2014, 06:18 PM   #3
Ninjinsky
Ninjinsky's Avatar
One thing I had recently was coolant dripping there. It's the water pump and there's 2 'o' ringed pipes, the drain plug and the gasket. So natch you assume that is where the leak must be.
I went through them all, draining and refitting refitting twice! Still leaking
Turned out the leak was at 'O' ring on the main union that goes into the top of cylinder head.
It trickles right down the back of the engine, across to the left and down over the water pump
Fooled me completely
Old April 12th, 2014, 06:22 PM   #4
http://faq.ninja250.org/wiki/Hints_%...g_coolant_pipe
Old April 19th, 2014, 02:21 PM   #5
drc84
Okay, everyone. Thanks for the quick and informative replies! I haven't been able to figure out where the leak is coming from yet, but I did notice that the amount of coolant that leaks out each day has slowed down considerably.
Today, I got the chance to get out there with the bottle of coolant and refill it. I was expecting to refill it nearly the whole way; however, it only took a little bit of coolant before it was full again.
The reserve tank under my side panel was empty, so I refilled it all the way.
Why did it seem like so much had leaked out? Any ideas?
Old April 19th, 2014, 02:53 PM   #6
Ninjinsky
Ninjinsky's Avatar
Hi DRC84. Just pointing out that under the side panel is the 'expansion' tank not a 'reserve' tank. As the engine heats up the level will go up then, as the engine cools down, coolant is drawn back into the engine so you will see levels fall. It will fluctuate over a range of maybe 1/2 inch between cold engine in winter and hot engine in summer. The key when checking for leakage is to always compare levels in the same conditions.
Old April 20th, 2014, 09:19 AM   #7
quarterliter
Motorcycle(s): 2004 Ninja 250
I'm having that exact same issue.
Old May 21st, 2014, 01:11 PM   #8
drc84
I'm bumping this with a video:
This is getting worse and I think it's going to cause a problem soon. Anyone have a recommendation of a guide to use to diagnose the problem or something?
Old May 21st, 2014, 02:32 PM   #9
DaBlue1
DaBlue1's Avatar
You will need to take the fairing off so you can see exactly where the leak is. If coolant is leaking from the top of the engine, it is most likely leaking from the coolant pipe attached to the head (just above the carbs). There is an o-ring that seals the connection.
If it is leaking below and all the bolts are tight it's either leaking at the water pump gasket or the coolant pipe o-ring
Old May 21st, 2014, 03:11 PM   #10
replace the crush washers on the coolant drain plugs?
Coolant leaking into oil and oil leaking out of somewhere. Monkeytofu 1986 - 2007 Ninja 250R Tech Talk 31 May 25th, 2013 04:09 PM
Why you should change your coolant before 3 years tubarney 2008 - 2012 Ninja 250R Tech Talk 24 April 28th, 2013 05:14 PM
Coolant leaking from the top of the engine... LoneRonin 2008 - 2012 Ninja 250R Tech Talk 9 April 16th, 2013 06:56 PM
Leaking coolant Chuffmonkey 2008 - 2012 Ninja 250R Tech Talk 5 May 30th, 2012 11:47 PM
radiator hose burst :( leaking coolant h0yitsdom 1986 - 2007 Ninja 250R Tech Talk 11 June 3rd, 2011 11:06 PM
