Old June 20th, 2010, 11:13 AM   #1
crankinaway
Shogun frame slider frame bolt question
So I purchased the kit and upon inspection realized the new frame bolts that secure the cross brace to the frame are just mild steel threaded rod with a nut welded on one end.
I have yet to pull my fairings off but could somebody tell me what the head markings look like on the original bolts? I use to work for a bolt manufacturer so I would like to determine if I would be better off using alloy rod instead which is closer to a grade 5 spec bolt instead of the grade 2 supplied.
crankinaway is offline   Reply With Quote
Old June 20th, 2010, 03:44 PM   #2
randomwalk101
self wrencher
randomwalk101's Avatar
stock bolt is mild grade steel but without the welded nut like Shogun. I originally thought shoGun was a little flipsy so went to the hardware store and bought a pair of bolts of similar length to replace it....well that's when I was working 7 on 7 off...oh so much time...now just 9-5 m-f...only weekends off..no time for anything..boo!
Old June 20th, 2010, 08:33 PM   #3
crankinaway
So you did replace them with a higher grade bolt? I suspect the lower grade has a little more flex before snapping, but last time I checked cars and trucks used grade 8 bolts for engine mounts.
I guess if the bolts that come out are mild steel, then Shoguns spray galvanized redi rod should be okay. I am still thinking of at least going to nylocks, plus if I switch to nylocks on both ends I think I can just bang the original bolt out with the redi rod without jacking the motor.
Old June 21st, 2010, 05:56 AM   #4
Banzai
Psychic war veteran
Banzai's Avatar
Originally Posted by Banzai View Post
As I've posted before here:
...........As a technical note, make sure that your engine mount bolts (upper and lower) that you replace and/or retorque are as free floating as you can get them on installation. A little binding is expected, and somewhat normal, but if you had to force them in and then torqued them with the weight of the engine on them, be aware that you MAY NOT have gotten proper torque on the bolt, ESPECIALLY with the Shogun kit. With the full weight of the engine assembly on the bolt before torquing, sometimes the bolt won't strech properly, and subesquent road vibration and heat/cold cycles will allow the whole assembly to settle and equalize the load on the bolt. Retorquing will often reveal that the nut will turn somewhat, indicating that it was not torqued properly initially. This is very common in the Shogun kit, as the replacement upper engine mount bolt is assembled from threaded rod that has a nut welded onto one end to form the 'bolt head'. The threaded rod is of a (sufficient) but lower grade than the factory bolt, and stretches more on initial torque. Oh, and you might want to put a spot of black paint on the thing, too, to prevent corrosion, if you're given to care about things like that. About 6 inches of the bolt is exposed at the front of the engine case, and will get all of the road water and dirt on it that your front tire kicks up. Touch up black on the bolt head and nut will ensure that you won't have to worry much about rusted tight components should you ever need to remove them later in life.
Old June 21st, 2010, 07:37 AM   #5
randomwalk101
self wrencher
Yes I banged it out with another bolt.
Posted via Mobile Device
Old June 21st, 2010, 05:52 PM   #6
crankinaway
Did it slide out easily or did it take alot of force?
Old June 22nd, 2010, 12:55 AM   #7
00v_Lucky
00v_Lucky's Avatar
Motorcycle(s): '09 Candy Thunder Blue Ninja 250R
I am also thinking about getting higher grade bolts too. Care to share which dimensions you chose afterwards? (the length of the rods for the top and bottom)
I think last time i checked the bolt has a number 6 on it (perhaps 9 but I doubt it). however I do not know if it corresponds to the grade level.
00v_Lucky is offline   Reply With Quote
Old June 22nd, 2010, 06:46 PM   #8
crankinaway
What you want to get is an alloy rod usually available at home depot, normally yellow plated and personally I would go either with a nylon or stover lock nut of equivalent grade. Alloy rod is very close to a grade 5 strength as opposed to the Shoguns included grade 2 material stud. I have not yet cut mine to length.
Here is the thing though....the instructions say the rod is a 9/16 thread diameter, when actually it is 3/8-16 thread. I hope they have included the appropriate size rod for the kit.
Can anyone confirm what size came out of the motor? Chances are it is metric tho.
Shogun frame slider - 08-12 Bigballsofpaint Motorcycle-related 17 May 10th, 2015 08:11 PM
Shogun frame slider differences Bob2010 2008 - 2012 Ninja 250R Farkles 6 July 20th, 2014 08:17 AM
Shogun S5 Frame Slider Bolts MyronGanes 2008 - 2012 Ninja 250R Tech Talk 10 February 20th, 2013 09:53 PM
Shogun Frame Slider Bolt currentsea 2008 - 2012 Ninja 250R Farkles 5 January 10th, 2010 08:12 PM
Shogun Frame Slider Replacements paterick4o8 2008 - 2012 Ninja 250R Farkles 2 August 13th, 2009 05:57 PM
