Old January 25th, 2010, 06:23 AM   #1
QtrLitre
Motorcycle(s): 2009 Ninja 650R
What are you using for track tires
Thinking of doing a some track days, I would like to get an 08 250R but from a light search on motorcycle superstore and at the pirelli website they do not have the good rubber in the size for the 250. What are you guys that track your 250s using?
QtrLitre is offline   Reply With Quote
Old January 25th, 2010, 07:58 AM   #2
RaceBikeRentals
Pimpin
RaceBikeRentals's Avatar
Motorcycle(s): Bunch of em
Some people are going very fast on Pirellis, using the 150 rear. I personally love Bridgestones. The 090 and 003RS are very good tires. 140 or 150 rear both work fine. You won't use all the tire on the 150 rear, however.
I have recently switched to Michelin Power One race tires and they are incredibly fast and sticky, but the rear is lasting me less than one day.
-Richard
MotoList.com <<<List your stuff!
RaceBikeRentals is offline   Reply With Quote
Old January 25th, 2010, 09:34 AM   #3
2WheelGuy
2WheelGuy's Avatar
I've gone with Bridgestone and am quite happy so far. Currently I have a BT-090 on the front in a 110 and a BT-003r in the rear in a 140.
AFM #278
Old January 25th, 2010, 04:52 PM   #4
Bulldog
Motorcycle(s): 2009 Ducati 848; 2009 Kawasaki 250r
RaceBike, what size are you using with the Power Ones?
Bulldog is offline   Reply With Quote
Old January 25th, 2010, 05:05 PM   #5
RaceBikeRentals
Pimpin
110 front, 150 rear
-Richard
Old January 25th, 2010, 05:08 PM   #6
Bulldog
On stock rims with no clearance issues, RaceBike? If so, does Michelin make a 140? I'd like to stay as close to stock size as possible. Ride Power Ones and Power race on the Ducati at the track, and love them.
Old January 25th, 2010, 05:12 PM   #7
RaceBikeRentals
Pimpin
Yes, everything is stock. No clearance issues. They don't make a 140, unfortunately.
-Richard
Old January 25th, 2010, 05:22 PM   #8
Bulldog
Can I get them over the internet? I'm in Florida and the site I normally purchase the Michelins from doesn't carry those sizes. Thanks much for the info, RaceBike.
Old January 25th, 2010, 05:33 PM   #9
RaceBikeRentals
Pimpin
I'll bet you can find them if you search around a little bit. I get mine at the track.
-Richard
Old January 25th, 2010, 06:32 PM   #10
QtrLitre
Thanks guys for the info
Old January 26th, 2010, 06:14 AM   #11
mike_sema
mike_sema's Avatar
Motorcycle(s): ninja 250r
hey QTRLITER are you going down to Inde to race
08 250R: sportisi VR full exhaust, Dynojet, custom seat, kleen air rmvd, rim tape, grips, fender chop,zg db windscreen,k&n air filter,15t front sprocket,sportisi-usa clipons,solo seat cowl
mike_sema is offline   Reply With Quote
Old January 26th, 2010, 07:32 AM   #12
tristatejames
Motorcycle(s): 2006 Ninja ZX6R (636)
Can I use a 150 on the rear of a pre-gen? Will I need a new wheel because I read somewhere that the 130 that came stock may already too big?
tristatejames is offline   Reply With Quote
Old January 26th, 2010, 10:14 AM   #13
2WheelGuy
2WheelGuy's Avatar
The pre-gen has 16" wheels instead of the 17" wheels on the new model. 16" wheels are limited to old school bias-ply tires. A 130 width tire is the widest you would want to fit to a pre-gen.
AFM #278
Old January 26th, 2010, 11:33 AM   #14
esi7esi7
212
esi7esi7's Avatar
Motorcycle(s): 09 250R, 09 ZX6R
I just got a pair of Pirelli Dragon Supercorsas from John over at South Central Race Center. I'm hoping to try them out this Sunday.
Lisa
www.212decals.com Custom Decals for your bike! Support a fellow racer!
esi7esi7 is offline   Reply With Quote
Old January 26th, 2010, 11:35 AM   #15
Betlog
Betlog's Avatar
Motorcycle(s): 2009 250r
Is this the case for all 150 tires, specifically, the BT016? Is it because the tire is pinched? Are you scraping pegs?
Old January 26th, 2010, 11:44 AM   #16
2WheelGuy
2WheelGuy's Avatar
I've run the Dragon's and now have the Diablo Supercorsas on my '02 250 with very wide 17" wheels. Awesome tires. The bike feels like it is on rails with them.
I haven't tried to fit them to the narrower '08 wheels yet.
AFM #278
Old January 26th, 2010, 11:53 AM   #17
Betlog
Betlog's Avatar
BTW, are the stock tires on the '09s (IRC) really bad to the point that they are dangerous? I have not pushed them yet. I'm going to upgrade but I'm not sure if I should upgrade now or wear the stockies first.
Old January 26th, 2010, 04:43 PM   #18
RaceBikeRentals
Pimpin
Yes, they are dangerous. Don't even think of using them on the track.
-Richard
Old January 26th, 2010, 04:45 PM   #19
RaceBikeRentals
Pimpin
Correct. All 150 sized rear tires will have a chicken strip on the sides. Worst I've seen are the Pirellis. They are so pinched, the side of the tire is parallel with the bike.
Yes, definitely scraping pegs. And boots. And legs. And toes. And the pipe. And the bodywork. Well, you get the idea. Everything scrapes on these things.
-Richard
Old January 26th, 2010, 04:59 PM   #20
mike_sema
mike_sema's Avatar
So Richard do you think that the bt-003rs or the bt-16 will be a better track tire since you have used them both just want to know as I will be doing my 1st track day in march and would like to get the most out of the bike thanks
Old January 26th, 2010, 05:03 PM   #21
RaceBikeRentals
Pimpin
Both are awesome tires. I feel the BT016 is adequate for high speed tracks, but falls short in tight corners. The BT003RS is better, because its softer. Now, this is from a racer's perspective. Either tire will be just great for track days and even novice to intermediate racers.
-Richard
Old January 26th, 2010, 05:04 PM   #22
RaceBikeRentals
Pimpin
BTW, I should have Bridgestones in my store pretty quick here. Working on it now
-Richard
Old January 26th, 2010, 05:05 PM   #23
mike_sema
mike_sema's Avatar
Great your input is much appreciated
Old January 26th, 2010, 05:13 PM   #24
mike_sema
mike_sema's Avatar
one more ??? are you using the 110 or 120 up front
Old January 26th, 2010, 05:34 PM   #25
Betlog
Betlog's Avatar
Thanks Richard.
The BT-003 comes in a 140 size, I think I'll stick with that one as it should fit our rims and not pinched, correct? Any experience with that size by any chance?
Old January 26th, 2010, 06:16 PM   #26
RaceBikeRentals
Pimpin
110 front. Yes, the 003RS in the 140 is a great choice. You'll use the entire tire.
-Richard
Old February 26th, 2010, 06:55 PM   #27
mike_sema
mike_sema's Avatar
Hey Richard I just had the 03rs put on my bike and we had to take them off I noticed when they were mounted and the guy was rolling my bike out side that the rear tire had a wave look to it so we all took a good took at it and found that all the way around the tire it looked wavy have you seen this before they told me they will order a new set and that it is a manufacture defect this was the 150/60 rear tire
Old February 26th, 2010, 07:33 PM   #28
RaceBikeRentals
Pimpin
Yeah, that doesn't sound right. You will see a straight line between the 3 compounds after many miles, but you shouldn't see anything when its new. Wavy doesn't sound good, either. Can you get a 140 rear?
-Richard
Old February 26th, 2010, 07:53 PM   #29
mike_sema
mike_sema's Avatar
i could get the 140 but i want the 150, i know that it works, i just have never seen somthing like it i wish i had been able to take a pic
Old March 2nd, 2010, 05:54 PM   #30
mike_sema
mike_sema's Avatar
ok the bt-003rs in the 150/60 is not working on the bike we put 2 diff rear tires on and they were both wavy on the edge of the tire the specs say only for a 4.5 in wheel so i ordered aa 140 so lets see what happends
Old March 8th, 2010, 08:24 PM   #31
mike_sema
mike_sema's Avatar
the 140 fits great and what a great tire cant wait for the 20th to come
Old March 29th, 2010, 06:24 PM   #32
Manimal
Manimal's Avatar
Motorcycle(s): 2013 Ninja 300 SE
I sse a lot of talk of the Pirelli's and Bridgestones, what about Dunlop?
Fwiw, when I bought my 09 Ninja (used) it came with a set of Dunlop's 130/70/17 & 110/70/17. I may be finally doing a track day and am wondering if these tires will work better than the factory tires or not. Otherwise, I may have to I bite the bullet and buy a new set of Bt's.......the preferred choice for the new gen Ninja's.
Manimal is offline   Reply With Quote
Old March 31st, 2010, 06:17 PM   #33
Manimal
Manimal's Avatar
got no reponses, so I bit the bullet and have a set of Bt's on order for delivery. Doing my first BIG track day April 13th at BW, finally
Old April 14th, 2010, 10:29 AM   #34
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
So does anybody think they could spout a definitive full part number for the Bridgestone tires?
I need to order them and be sure it's right the first time so I don't waste money messing around.
Like, tire number and tire size all together instead of just saying "110 front and 150 rear" because that doesn't help me too much.
I have BT-016 and BT-003?
where do the BT 090 come in?
I'm afraid I need much more of an explanation before I purchase track tires. I find this thread rather confusing.
What numbers am I missing before I can finally decide on tire brand, type and size? I still feel like a 60 or a 70 is missing somewhere. Maybe someone can clear this up for everybody once and for all?
I'm sure this is not right, but for example..
If someone could type out the full part number and size all together I think it would help a lot of people.
BT-016 110/60 front? BT-016 150/???
http://www.ninjette.org/forums/signaturepics/sigpic2121_4.gif <Yeah, it's a 250.
LMFAO!
Weaksauce
ninja250 is offline   Reply With Quote
Old April 14th, 2010, 10:36 AM   #35
2WheelGuy
2WheelGuy's Avatar
@Ninja250 You should find your answers here:
http://mc.bridgestone.co.jp/en/produ...ry/onroad.html
AFM #278
Old April 14th, 2010, 10:46 AM   #36
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
agh,
that link and reviewing stock tire sized helped a lot.
Thanks..
signed,
-village idiot
LMFAO!
Weaksauce
Old April 14th, 2010, 10:57 AM   #37
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
crap so still confused a bit.
If I go with bt-016 the rear tire size will be 150/60/17? Isn't stock 130/70/17? How about with the front? 110/70/17 stock replaced by 110/70/17 bt-016?
LMFAO!
Weaksauce
Old April 14th, 2010, 11:06 AM   #38
2WheelGuy
2WheelGuy's Avatar
Go with the 003 or 090. I would choose the 003
110/70R17 front
140/70R17 rear
These sizes fit the new-gen perfectly.
The 150/60ZR17 016 rear will fit but will be slightly pinched so that you will never use the extreme edges of the tire.
AFM #278
Old April 14th, 2010, 11:10 AM   #39
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Thanks for clearing that up. Very helpful.
I've been trying to figure this out for a few weeks now for some reason.
I used to be a tire man (for cars) and still couldn't see what I was missing with this.
I think I was pretty confused when I did the tires each time on my old bikes too.
Local shop quoted me $280 on a set of the 16's installed. I'll call back and see if they have the 003's and 090's.
Tire width doesn't mean much to me really if I'm getting the most from the tires. (will try for 140's)
LMFAO!
Weaksauce
Old April 14th, 2010, 08:57 PM   #40
Manimal
Manimal's Avatar
110/70R17 front
140/70R17 rear
I bought a set (003 & 090) through Motorcycle Superstore for $200 (and change) shipped and delivered to my door within a week. Just in time for my track day. Tires worked great
Stock Tires for Track Funhole Ninjettes At Speed 3 May 26th, 2013 06:53 AM
Stock tires vs. the track beazy411 2013 - 2017 Ninja 300 General Discussion 27 March 18th, 2013 07:42 AM
tires for track days cbinker Ninjettes At Speed 28 January 24th, 2013 02:45 PM
Track Tires for 300 JBinSD 2013 - 2017 Ninja 300 Tech Talk 57 October 19th, 2012 05:40 PM
What tires to run at the track? esi7esi7 Ninjettes At Speed 8 January 2nd, 2010 04:37 PM
