April 15th, 2010, 06:50 PM | #41 |
Join Date: Dec 2008 Motorcycle(s): 08 Ninja 250 Posts: 256
Currently BT090s, but thinking of getting 003s once these are done.
The 090s have been great. Richard, is there a noticeable difference from the 090 to the 003s? Thanks. -Joel |
April 16th, 2010, 07:42 AM | #42 |
Pimpin
Join Date: Nov 2008 Motorcycle(s): Bunch of em Posts: 973
Yes, definitely. 003s feel softer, not as rigid as the 090s. 003s seem to last a bit longer. For me personally, the 003s are very "twitchy" due to the multi-compound. I don't like that, but could probably get used to it if I had to. Maybe I'm too heavy with the controls on the bike, but they really move the bike around and cause me to make mistakes.
I really hate running 090s, so the 003s, even with their twitching, are a big improvement for me. 016s are much better. |
April 16th, 2010, 11:00 AM | #43 |
2010 250 Cup Champion
Join Date: Jan 2010 Motorcycle(s): 2008 Ninja 250R and 2007 Honda CR150F Posts: 168
Bridgestone is going to be the spec tire for the ninja 250 series here in Ontario. We'll be riding on BT-003s. Looking forward to trying them out!
April 17th, 2010, 07:59 PM | #44 |
Join Date: Jan 2010 Motorcycle(s): 2008 Honda 1000RR, 2008 Ninja 250R Posts: 105
Just tracked at Buttonwillow the other weekend with a BT016 150 width rear. Granted, you'll never use the entire surface of the 150 width. I was grinding kickstand and my custom tucked away exhaust (which I was positive could never hit) and still had some chicken strips. Anyway, the tire is pretty dope. Very predictable. Only times the rear slid was under hard braking and downshifting, but I think that's normal.
Recommended! |
April 18th, 2010, 12:49 PM | #45 | |
April 18th, 2010, 12:52 PM | #46 |
April 21st, 2010, 09:47 AM | #47 |
Join Date: Apr 2010 Motorcycle(s): 900cc's worth Posts: 24
BT003 pro soft front
BT003 RS rear
CMRA #250 Brought to you by: Lockhart Phillips USA-Sam's Cycles-South Central Race Center-HPC Decals-Highperformancecrew.com-and my amazing friends! |
September 16th, 2010, 05:24 AM | #48 |
Join Date: Jul 2009 Motorcycle(s): 09 ninja250, 03 sv650 Posts: 47
Where do you get the BT003 race front? How long do your tires last?
After reading this thread, I'm decided on getting a BT003RS 140 rear. I'm debating what to run on the front. This is for track days. I have been VERY happy with a Metzeler K1 front tire...I might stick with that in the front. (I run 120 front because I've got a GSXR fork swap) Last futzed with by blong; September 16th, 2010 at 10:10 AM. |
September 16th, 2010, 05:39 AM | #49 |
September 16th, 2010, 10:08 AM | #50 |
You guys out west love your 110 fronts from what I gather. Why is that?
I just ordered 120/130 GT501's for my old gen, even though everybody says that the 110 front is the way to go. I'm thinking about upgrading to 17" wheels, and when I asked the fast guys over here what they run, it's 120 front and 140 rear. |
September 16th, 2010, 10:26 AM | #51 | |
Join Date: May 2009 Motorcycle(s): '98 EX250, '02 EX250, '08 250r, '03 SV650, '98 GSXR750 '03 Hayabusa, '87 YSR50, '84 ZX900, +MORE Posts: A lot.
CraigHarris.org Pacific Track Time CraigsWeb See you at 2014 MotoGP Laguna Seca! We'll be camping on Fox Hill. AFM #278 |
September 17th, 2010, 01:22 AM | #52 | ||
Join Date: May 2009 Motorcycle(s): 2007 EX250 (street), 1994 EX250 (Race), 2008 250R (Race), 2000 250 (project), 1991 EL250 (a cruiser!) Posts: 287
September 23rd, 2010, 06:05 PM | #53 |
Any old gen racers know the circumference of the Gt501 110/90 front tire?
Also, what's the difference between the GT501 and the GT501F, if any? I've seen a GT501G for sale, but never an F, but that's what the sticker says on my new tire. What's the difference between the 501 and the 501G for that matter? thanks! |
September 25th, 2010, 05:19 PM | #54 |
Also, when you old gen guys put the Dunlops on, did you modify the front fender brace to accomodate the larger tire, or did you just junk the brace and drill holes lower in the fender?
September 26th, 2010, 08:36 PM | #55 |
I tossed the brace and drilled new holes in the fender. I don't know anyone who tried to keep the stock type brace.
September 28th, 2010, 06:49 AM | #56 |
Join Date: Aug 2010 Motorcycle(s): EX250x2, GS450ES, EX500, FZ600x2, SV650, GS850L, ST1100, GSX1300R Posts: 13
September 28th, 2010, 07:28 AM | #57 |
September 28th, 2010, 07:34 AM | #58 |
Stock Tires for Track | Funhole | Ninjettes At Speed | 3 | May 26th, 2013 06:53 AM |
Stock tires vs. the track | beazy411 | 2013 - 2017 Ninja 300 General Discussion | 27 | March 18th, 2013 07:42 AM |
tires for track days | cbinker | Ninjettes At Speed | 28 | January 24th, 2013 02:45 PM |
Track Tires for 300 | JBinSD | 2013 - 2017 Ninja 300 Tech Talk | 57 | October 19th, 2012 05:40 PM |
What tires to run at the track? | esi7esi7 | Ninjettes At Speed | 8 | January 2nd, 2010 04:37 PM |
