Old April 15th, 2014, 01:38 PM   #1
ninjagaiden09
ninjagaiden09's Avatar
Motorcycle(s): 2011 Ninja 250r
Front brake master cylinder
Just have a question about this master cylinder Does anyone know if this will work on a Ninja 250. Thanks
ninjagaiden09 is offline   Reply With Quote
Old April 15th, 2014, 02:30 PM   #2
cuong-nutz
cuong-nutz's Avatar
Ebay link is not working for me. I don't know the specifics of the stock brake master to compare. You have to make sure your brake master piston is the matched to the brake caliper/s you are using. Too small of brake master piston = not enough pressure. Too big of piston = too sensitive of braking.
HalfFast Racing Team
Old April 15th, 2014, 03:01 PM   #3
dino74
dino74's Avatar
http://www.ebay.com/itm/7-8-22mm-Lef...-/291088629795
From the description:
Package includes: 1 x LEFT Hydraulic Brake Master Cylinder
Bore / Piston Size: 17mm
Wrong side plus the piston is too large. The 250's is 13mm.
Also, I won't trust my life to cheap no-name master cylinders.
CVMA #55
Old April 15th, 2014, 03:20 PM   #4
chugs
Schönen Tag noch
chugs's Avatar
Motorcycle(s): 08 ninja 250 race bike, 02 gixxer 600 telefonica
+2 get an accossato or brembo but definitely overkill for a street bike, the oem mc seems to work quite well with ss lines and good pads.
chugs is offline   Reply With Quote
Old April 15th, 2014, 07:32 PM   #5
ninjagaiden09
Thanks. I appreciate all the input.
Old April 16th, 2014, 05:38 AM   #6
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
+3
Piston size is way way to big for what the ninja has going on. The stock 13mm is good for even larger calipers than what come standard on the ninja250 so a 17mm on OEM ninja calipers would be bad news, all or nothing kind of feeling
Last futzed with by subxero; April 22nd, 2014 at 05:26 AM.
Old April 22nd, 2014, 05:07 AM   #7
g21-30
g21-30's Avatar
Check out this link:
https://www.ninjette.org/forums/showthread.php?t=10678
You won't need to be concerned with the piston size, etc. It works great!
Old April 22nd, 2014, 08:51 AM   #8
dino74
dino74's Avatar
General guide line for piston sizes on the 250s.
Axial Master Cylinder 12 to 13 mm
Radial Master Cylinder 16mm
CVMA #55
Front brake master cylinder piston size old3 General Motorcycling Discussion 3 November 16th, 2012 03:39 PM
front brake issues. master cylinder? Solunatic 1986 - 2007 Ninja 250R Tech Talk 13 June 25th, 2012 11:34 AM
