Old July 18th, 2012, 09:21 PM   #1
theob
Motorcycle(s): 636, SV650, '08 ninjette race bike
Adjusting Throttle Cable - Barrel adjusters and Throttle body adjusters are maxed out
Does anyone know how to adjust (tighten up) the throttle cable when the barrel adjusters on the bars is maxed out and the adjuster on the side of the carburator is similarly maxed out? I thought that I would be able to reclamp the throttle wire somewhere and start afresh, but there are knobs on each end of the wire so that is not the way it works.
Any ideas? My throttle is fairly loose.
theob is offline   Reply With Quote
Old July 19th, 2012, 04:19 AM   #2
Try taking up some of the slack with the adjustment nuts on the bracket on the carbs.
Posted via Mobile Device
Old July 19th, 2012, 05:50 AM   #3
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
New cable
Old July 19th, 2012, 08:51 AM   #4
theob
All of the available slack has been taken up on both the carbs side as well as the throttle side.
Do they make throttle cables in different lengths?
Old July 19th, 2012, 09:24 AM   #5
Magz
Magz's Avatar
Motorcycle(s): '06 Ninja 250
Yes, they do. But throttle cables can stretch over time, so unless the bike has been modified somehow to need a shorter one, chances are you just need a new one of the stock length.
Behind every great man is a woman rolling her eyes.
- Jim Carrey
Magz is offline   Reply With Quote
Old July 19th, 2012, 09:50 AM   #6
Is that happening to a Ninjette or to one of your other bikes?
It was better before?
If the cables are original, one of them may be breaking up, which is sometimes a slow process that produces some elongation before final rupture.
Check the portions were each cable is bent because it is there where they normally fail.
Old July 19th, 2012, 12:28 PM   #7
theob
Sorry, yes, this is happening to an '08 ninjette race bike. My guess is that the cables are original. I didn't see any major kinks in the housing, but I can look again.
Is it possible that I routed the wire incorrectly and that is either pulling on the housing too much or, most likely, not enough?
I haven't had the bike for very long so I do not know it's past history. I've only ridden it on the track once.
Last futzed with by theob; July 19th, 2012 at 12:29 PM. Reason: More information
Old July 19th, 2012, 12:54 PM   #8
The damage doesn't happen to the housing normally, but to the strands of steel wires.
It starts with a few wires breaking, and it progress until the remaining strands start elongating under the stress.
You can learn more here:
http://en.wikipedia.org/wiki/Bowden_cable
I would take both cables out for a clean up and full inspection.
If they are OK, then they may not be original.
Old July 19th, 2012, 01:00 PM   #9
theob
You know, I just realized that my 08 only has 1 throttle cable.
Maybe that's part of the problem?
Old July 19th, 2012, 04:58 PM   #10
Yes, indeed.
These bikes have a a secondary (closing / Part # 54012-0211) cable that forces the carburetor's butterfly valve (throttle) to return to the closed position.
It is a safety feature, in case the return spring in the carburetors fail.
Do you have a user's or service manual?
I suspect that the primary cable (opening / Part # 54012-0210) was replaced by the secondary cable, which is slightly different and doesn't work with the adjustable guides of the primary.
Old July 19th, 2012, 05:01 PM   #11
Gurk
Done here.
Motorcycle(s): -
If your throttle cable isn't snapping back quickly (aka feels sticky) the problem could be the routing. I don't know if you're running stock but I've run in the same problem in after market throttle cables. I had to find the perfect position for my throttle / throttle cables so that the cable doesn't have much kink in it limiting is free movement. try rotating the whole throttle tube around your handle bar and see if there's a point where it moves freely and snaps back firmly.
Gurk is offline   Reply With Quote
please help with throttle cable on carbs gantt 2008 - 2012 Ninja 250R Tech Talk 4 March 28th, 2015 06:58 PM
How to replace the throttle cable? MrAtom 1986 - 2007 Ninja 250R Tech Talk 6 February 9th, 2015 08:15 PM
Broken throttle cable Ninja Rob 1986 - 2007 Ninja 250R Tech Talk 12 January 23rd, 2015 10:07 AM
Throttle went while riding -> need new throttle cable? AndrewMack 2008 - 2012 Ninja 250R Tech Talk 13 September 8th, 2013 06:17 PM
Throttle & Throttle Cable Smoothness paterick4o8 2008 - 2012 Ninja 250R Tech Talk 3 December 1st, 2009 01:50 PM
