Old July 11th, 2011, 02:03 PM   #1
h0yitsdom
newbie newbie
h0yitsdom's Avatar
Motorcycle(s): 2006 Ninja ex250
leaking a little gas
noticed a distinct smell in my garage today when trying to get something out, looked at my bike and saw dampness from gas which appears to be seeping out of a rubber hose. i'm having trouble finding what this hose is connected to on all of the parts diagrams, not seeing any hose in a similar U-shape. so i took some pictures and hopefully someone can help me with a part number or at least idea on how to replace in terms of size of the hose. there is only 1 clamp on it which is on the bottom where it is actually leaking.
this is the other side of the hose and where it connects
i just filled up and have only ridden about 15 miles on my new tank, normally i leave my petcock on when i park it in my garage for the night could this be part of the problem? I park it straight up on my centerstand however and not on the sidestand if that makes a difference
h0yitsdom is offline   Reply With Quote
Old July 11th, 2011, 02:37 PM   #2
that looks like the crankcase vent hose?? can't really tell from the pics. is your oil level at the proper level in the sight glass or has the bike been on it's side recently?
Old July 11th, 2011, 02:44 PM   #3
h0yitsdom
newbie newbie
h0yitsdom's Avatar
the hose is the same shape, however it isn't connected to a plastic piece like this
its going directly in to another black piece, no clear plastic piece like the picture above
the bike was downed by an old owner but i have had it for almost 2000 miles and it hasn't been downed since then
Old July 11th, 2011, 02:53 PM   #4
how's your oil level in the sight glass. Changed oil recently?
yep, that's your crankcase vent tube. what does it connect to if not that white piece?
Old July 11th, 2011, 02:54 PM   #5
h0yitsdom
newbie newbie
h0yitsdom's Avatar
went and looked at it again, it looks like its going to the air filter box/area on the top
my oil level is midway between half full and full but the bike is cold right now and hasn't been run since yesterday. i changed the oil about 1500 miles ago with rotella t6 synthetic but the oil isn't clear like these pictures, its kind of darker brown
Old July 11th, 2011, 02:55 PM   #6
are you reading the oil level with the bike perfectly vertical and on a flat surface?
Old July 11th, 2011, 02:58 PM   #7
h0yitsdom
newbie newbie
h0yitsdom's Avatar
yeah i took it off the centerstand and stood it up straight, its not all the way full but more then half way if that makes sense
Old July 11th, 2011, 03:03 PM   #8
okay, sounds like your oil level is correct. are you sure it's gas you're seeing and not oil?
If oil, I would take the hose off, clean up that area and check the hose for a split? if the hose looks good, pull the airfilter and check the bottom of the airbox. does it have oil in it? if so, clean it out and see if your problem continues.
Old July 11th, 2011, 03:06 PM   #9
h0yitsdom
newbie newbie
h0yitsdom's Avatar
when i changed the oil i also put some new oil in the air filter, maybe i put too much?
but it smells very strongly like gas and its not dark like oil. i didn't want to pull off the hose and get splashed with gas but i'll take a look at it now
Old July 11th, 2011, 03:07 PM   #10
not if you can see the oil level line in the sight glass.
Old July 11th, 2011, 03:08 PM   #11
h0yitsdom
newbie newbie
h0yitsdom's Avatar
i mean on the air filter, i poured oil onto it like the guide said and wrung it out but maybe not enough
Old July 11th, 2011, 03:09 PM   #12
could it be gas from the carbs that are right above it? if so, you should be able to see the carbs are "wet" from a leak. are they wet?
Old July 11th, 2011, 03:10 PM   #13
did you clean the filter before oiling? what did you use to clean it?
Old July 11th, 2011, 03:22 PM   #14
h0yitsdom
newbie newbie
h0yitsdom's Avatar
i used dish washing soap when i cleaned it. i just looked at the hose again and it was just oil, i think the gas smell is from my tank since it is full
it seems like the brass clip that holds the vent hose down however is really lose and isn't tightening good enough to seal the hose which is why there is seepage.
my carbs aren't leaking but from now on i'm going to turn the petcock to off whenever i'm not riding just in case
Old July 11th, 2011, 03:25 PM   #15
cool.
you can either bend that metal clip a bit tighter by taking it off and pulling it so it makes a smaller diameter circle or use a tie wrap in it's place to hold the tube onto the crankcase vent.
Old July 11th, 2011, 04:57 PM   #16
h0yitsdom
newbie newbie
h0yitsdom's Avatar
i just got some normal hose clamps from my job instead that screw down on it. should work ok
thanks a lot for the quick help
Leaking gas Alisha_Ardella 2008 - 2012 Ninja 250R Tech Talk 23 May 11th, 2015 10:41 AM
Moto leaking gas Qomomoko 1986 - 2007 Ninja 250R Tech Talk 23 April 24th, 2015 11:33 AM
Why is My Gas Cap Still Leaking?! az3200 1986 - 2007 Ninja 250R Tech Talk 9 May 8th, 2013 06:17 AM
Gas Leaking into oil swsh23815 2008 - 2012 Ninja 250R Tech Talk 18 February 4th, 2013 08:53 AM
Gas leaking, carbs out, what to look for? CmichRider 1986 - 2007 Ninja 250R Tech Talk 7 August 12th, 2011 12:45 PM
