Old April 27th, 2020, 03:56 PM   #1
bayank
Tachometer sticking to 0 on startup
I've got a 2007 that takes a bit of effort to get the tach working. I'll start it up with choke and have no idea how many RPMs it's at, it's stuck at 0. I'll have to rev it up for the tach to finally move, it will jump up and then it behaves fine and shows me good idle as low as 1300 RPM for the rest of my ride. This happens on every cold start, seems to need a nudge from a stronger signal at higher RPMs to get unstuck. It's gotten worse this year and needs me to really wring it out to like 9k get the tach moving. Don't particularly like doing that when engine is not fully warmed up.
I know my battery is good, I have strong starter cranking and I keep it on a tender most of the time.
I've read several posts about this but no clear solutions were discussed. Not really interested in aftermarket cluster.
Cheers!
bayank is offline   Reply With Quote
Old April 27th, 2020, 06:12 PM   #2
59096
59096's Avatar
Motorcycle(s): GPX250 1989 model and 1990 model
Most of them do this to some extent. I can usually get mine to work by tapping on the tach face.
Perpetua Culpa Alterna Vagus
59096 is offline   Reply With Quote
Old April 27th, 2020, 06:18 PM   #3
There's some stiction in needle shaft. I find dripping little sewing-machine oil down shaft lubricates brass bushing and frees it up for good.
Old April 28th, 2020, 06:52 AM   #4
ssrsupermoto
Motorcycle(s): 2004 Ninja 250
mine does that as well, I will try and put a drop of oil in there.
ssrsupermoto is offline   Reply With Quote
Old April 28th, 2020, 09:40 AM   #5
greg737
Motorcycle(s): -
The Original Poster is talking about a problem with the TACHOMETER not the SPEEDOMETER.
(the Tachometer does not have a "drive shaft" with a brass bushing)
0 out of 1 members found this post helpful.
speedometer sticking motoman 2008 - 2012 Ninja 250R Tech Talk 3 August 2nd, 2015 09:07 PM
Throttle Sticking When Steering Right z0sum 2008 - 2012 Ninja 250R Tech Talk 8 April 25th, 2015 04:56 PM
Carb sticking 102dalz 2008 - 2012 Ninja 250R Tech Talk 3 November 2nd, 2014 02:37 PM
Front Brake is sticking...Help! skilletmo 2008 - 2012 Ninja 250R Tech Talk 19 October 25th, 2014 05:30 PM
Throttle sticking, need help WiffleBiscuit 2008 - 2012 Ninja 250R Tech Talk 4 September 1st, 2014 05:11 PM
