November 2nd, 2009, 08:38 PM | #1 |
Akira
Blinker problem at speed
Hi all
Maybe someone here can help me out, a strange thing started happening on my 250, the blinkers (turn signals) go crazy at speeds above 110 km/h. If the bike is stopped or at slow speed they work fine, but when i hit the freeway and get some speed they dont work and go all crazy. Blink rapidly, out of sync or don't blink at all. I've checked all the wires and made suer everything is connected correctly, i can only think that the relay is gone or is affected by the vibration. Any ideas? |
November 2nd, 2009, 08:42 PM | #2 |
You need more blinker fluid Have you inspected the bulbs and does speed affect all four lights?
November 2nd, 2009, 08:48 PM | #3 | |
Akira
Nah i'm going off the blinker light on the dash and the clicking sound, the relay clicking goes haywire and the light on the dash doesnt flick in sync. Am i making sense? |
November 2nd, 2009, 09:13 PM | #4 | |
November 3rd, 2009, 12:18 AM | #5 | |
Akira
Posted via Mobile Device |
November 3rd, 2009, 06:11 AM | #6 |
IC2(SW)
November 3rd, 2009, 06:26 AM | #7 |
Maybe a bad relay. Have you done have any electrical mods?
November 3rd, 2009, 07:34 AM | #8 |
old git
Join Date: Mar 2009 Motorcycle(s): BMW K1300S Posts: 479
Measure the voltage across the battery terminals and rev the motor the max voltage should be around 14 to 15 volts if it goes higher then the regulator is faulty, or the battery is faulty and the regulator can’t regulate.
Steve
Some mistakes are too much fun to make only once. |
November 3rd, 2009, 08:51 AM | #9 |
do the other lights get brighter as the revs increase? that would be in line with Steve's measuring the voltage. I had a bike with a bad rectifier (6Volt system) and at low rpm you couldn't beep the horn and use the blinkers, but at higher rpm you could.
November 4th, 2009, 11:29 PM | #10 |
Akira
Thanks for all the replies, i need to take it one step at a time.
Electrical mods: - LED turn signals at the back - After market turn signals at the front. - After market turn signal relay - 12VDC plug with switch and inline fuze. Everything worked fine for about 1 month, so i'm guessing the relay has gone. Step 1 I've removed all the turnsignals and relay. Converted everything back to stock. Haven't tried it yet because it was late and didn't want to wake the neighbours. I'll let you know how it goes. Thanks |
November 5th, 2009, 12:22 PM | #11 |
Join Date: Apr 2009 Motorcycle(s): '09 Ninja 250R Posts: 171
Stop approching the speed of light and maybe your blinkers will work properly . To me it might have something to do with the battery and generator. Only at speed is the bike recharging and maybe there's a bad connection.
Back on the road again Season 2010 Dam it feels good! |
November 5th, 2009, 09:12 PM | #12 | |
Akira
BTW - Source of the problem was a faulty relay. Couldn't handle the pressure. Thanks to all for the feedback. |
Blinker Problem | ChrisCusi | 2013 - 2017 Ninja 300 Tech Talk | 7 | February 21st, 2013 11:14 AM |
Blinker problem | Churchryan55 | 2008 - 2012 Ninja 250R Tech Talk | 4 | January 28th, 2013 10:00 PM |
Double Blinker Speed? | caps | 2008 - 2012 Ninja 250R Tech Talk | 12 | August 6th, 2011 05:25 PM |
solved the weird blinker bulb problem | jax | 2008 - 2012 Ninja 250R Tech Talk | 1 | December 11th, 2010 04:05 PM |
DIY Double Blinker Speed | ninja250 | 2008 - 2012 Ninja 250R Tech Talk | 38 | February 18th, 2010 12:39 PM |
