Old January 25th, 2014, 04:58 PM   #1
quadcrazy
Motorcycle(s): Ninja 300
DIY chain and sprockets
Hey guys I am trying to decide if I can change the chain and sprockets myself or if I'm going to have to cough up the money to have a shop do it. I was wondering if anyone knows the difficulty of this job? It seems like it should be ok but I dont know if ill need any special tools or anything. The thing I know the least about is the chain. Does the master link require any special tools?
Thanks for any info!
quadcrazy is offline   Reply With Quote
Old January 25th, 2014, 05:14 PM   #2
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
Pretty easy job. You are going to need some kind of cutting tool and an impact gun along with the required sockets (not sure of sizes) and a ratchet. A torque wrench wouldn't be a bad idea if you have access to one or can get one for cheap.
Depends on what kind of master link you have as to how you will put it on.
Old January 25th, 2014, 05:20 PM   #3
quadcrazy
Thanks. I have all of that except for an impact gun, what would that be used for? And are there any types of master links that you would suggest avoiding? The only type I've heard of is some sort of clip on.
Old January 25th, 2014, 05:24 PM   #4
TnNinjaGirl
Ms. Personality
You need an impact to remove the nut holding the front sprocket on. It's usually on there pretty tight (idk the torque spec). I suppose you could get it off with a breaker bar but the bike needs to be IN gear with the chain ON and the rear wheel touching the ground with quite a bit of weight on it. Usually easier to just use an impact.
I've used both kinds of master links and haven't had problems with either. There is a clip on type that some people say you shouldn't use and the other type is just like the factory one. It requires a clamp, vise or a chain tool to install properly.
Old January 25th, 2014, 05:26 PM   #5
TnNinjaGirl
Ms. Personality
and
Old January 25th, 2014, 05:35 PM   #6
quadcrazy
This is a big help, thank you!
Old January 25th, 2014, 05:37 PM   #7
old3
On the 1-10 scale the whole job is about a 3 in difficulty.
Invest in this tool IMO,
http://www.revzilla.com/product/rk-c...d=scsho1531254
if you plan on riding bikes into the future. I didn't shop prices so look around. You will be able to use that for the rest of your life if you take care of it. I use it as a press too crush the master together to get a clip on it if it isn't the rivet style.
old3 is offline   Reply With Quote
Old January 26th, 2014, 09:25 AM   #8
quadcrazy
That tool definitely seems like its worth it. As far as sprockets go are they pretty universal in size? I know the amount of teeth can vary but when I'm shopping online I dont really see any options for different sizes on different bikes.
Old January 26th, 2014, 09:36 AM   #9
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
That chain tool is a beauty! The Harbor Freight version is about $20. I bought an in-between version from Cycle Gear for $40 on sale (regularly around $60).
High-end tools are nice, especially when you're at a point in life where you can afford it.
Old January 26th, 2014, 09:46 AM   #10
old3
I've used and owned cheaper stuff too. That one was worth the investment. It stays in the box on the shelf and is a pleasure to operate. I expect it to last thru my kids lifetime too.
The key to building a nice tool collection is knowing where to save and where to spend. Pliers and screwdrivers, hammers and such, save as much as you can, (Harbor Freight!). Even mid quality wrenches are OK these days, Craftsman or Home Depot stuff. That chain tool is worth the investment. Buy it with the $ you saved in labor doing it yourself.
Ratchet handles are a good place to spend a bit more too, as the mid grade stuff is so failure prone these days. Junk! Craftsman stuff used to have a lifetime warranty that you never used, now I return the damn 3/8" drive things every few months.
Old January 26th, 2014, 07:21 PM   #11
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
if you dont have an impact gun, you can use a 2x4 between the wheel and swing arm to loosen the front sprocket. impact guns make it really easy.
TEAM ALFALFA
www.apexassassins.com
Old January 28th, 2014, 08:32 AM   #12
Xtina
Xtina's Avatar
Motorcycle(s): 2013 Ninja 300, 2007 Gsxr 600, R6-sold :(
Impact gun with the bike in gear seems like a bad idea. I wouldn't put strain on the gearbox like that. A regular breaker bar with a piece of wood between the swingarm and wheel are a safer choice.
Xtina is offline   Reply With Quote
Old January 28th, 2014, 10:08 AM   #13
DaveTheCanuck
Moo
DaveTheCanuck's Avatar
I took the best of both worlds... I wrapped my breaker bar in a towel, jammed it in the rear wheel, put the bike in neutral and used an impact gun to remove the front sprocket :P
DaveTheCanuck is offline   Reply With Quote
new chain and sprockets yogurtpooh 2008 - 2012 Ninja 250R Tech Talk 11 January 31st, 2015 02:11 PM
Chain and Sprockets ChaoSS 2008 - 2012 Ninja 250R Tech Talk 21 March 18th, 2013 03:49 PM
New chain and sprockets. erbarry88 2008 - 2012 Ninja 250R Tech Talk 3 October 15th, 2012 09:59 AM
Chain/Sprockets Lil_Green_Demon 2008 - 2012 Ninja 250R Tech Talk 1 September 9th, 2012 04:40 PM
Sprockets and Chain indr 2008 - 2012 Ninja 250R Tech Talk 8 February 6th, 2011 04:51 PM
