View Poll Results: How long do you warm up your ninjette? | |||
I warm it up longer than 5 minutes | 5 | 3.85% | |
I warm it up between 1 and 5 minutes | 76 | 58.46% | |
I warm it up, but less than 1 minute | 39 | 30.00% | |
It needs no warmup at all, just start it and go | 10 | 7.69% | |
Voters: 130. You may not vote on this poll |
Thread Tools |
August 3rd, 2011, 07:57 PM | #41 |
/merged with a good warmup thread from not long ago
August 3rd, 2011, 09:23 PM | #42 |
Listen to the bike, she'll tell you how she likes it.
August 3rd, 2011, 09:26 PM | #43 |
Join Date: Jan 2011 Motorcycle(s): 2009 Ninja 250r Posts: 72
I've ridden without using the choke and i've been fine. Maybe a little bogging here an there but never a problem. I normally turn the bike on, choke it, put my gear on, hop on, choke off and ride away.
August 3rd, 2011, 11:40 PM | #44 |
Join Date: Aug 2010 Motorcycle(s): GPX250 + many others! Posts: 184
August 3rd, 2011, 11:46 PM | #45 |
Join Date: Jul 2011 Motorcycle(s): 2006 Ninja 250R Posts: A lot.
A guy that worked for me last summer works at his dads cycle shop and he said he would go over the whole bike for$10 and see if it need valve or carb job etc.
She runs good once I let her warm up. Just used to how my ATV's do. |
August 4th, 2011, 12:18 AM | #46 |
The idea behind warming a vehicle up is to get the oil flowing and up to operating temperature. Well with modern synthetic oils, this is not needed. Almost immediately, the oil will be lubricating and protecting everything as well as it's able to at any temperature.
CN: Anything over 30 seconds is unnecessary. Hooray for advancements in oil technology. Along the same lines, people who drive their car hard and then let it idle to "cool off" before shutting down are morons too.
Ç¥ñ頻| ßÿ Ñâ7µ®é. Äñt¡~§º¢Ïä| ßý Çhøî©è. |
August 4th, 2011, 12:26 AM | #47 |
August 4th, 2011, 06:07 AM | #48 |
Unless it's a turbo. Even now, car manuals still say to let the engine run for a minute or two if you just finished high speed driving and had no time where the turbo wasn't up to speed. The water-cooled turbo designs now don't need the 5+ minutes that the older designs used to, but it's still not a great idea to have it up to max operating speed and temp, and shut it off immediately afterwards.
August 5th, 2011, 12:37 AM | #49 | ||
Hardly enough to be any kind of proof, but I put over 50k HARD miles on my last turbo, and it had no cracks or shaft play at all when it came off. Just my personal experience.
August 5th, 2011, 06:16 AM | #50 |
I don't think turbo timers are necessary anymore. But - there is wording in the manual for our Mazdaspeed3 like what I posted above, basically advising that if you just came off the highway or any other environment where the turbo was at speed, to not shut the car off immediately without a short delay or a few miles of normal use. I do think that production turbos have gotten phenomenally reliable compared to a few years back.
You can edit the poll results. But in this case, the prior poll options were a little limiting, and when I added more options the original few votes no longer made sense.
August 5th, 2011, 08:53 AM | #51 | |
n00b
Join Date: Jul 2011 Motorcycle(s): Blue 2010 Ninja 250 Posts: 581
If it's the first time starting the bike that day I do the following... 1) Start the bike with as little choke as possible if needed 2) Move wife's car because I use her car as a way to block the bike in and prevent theft 3) Put on all gear (all the time) 4) Get on drive If I've driven it already I just turn it on and put my gear on then get on and go. |
August 6th, 2011, 04:39 AM | #52 |
I drive mine nice and easy as soon as I start it up. From the ninja 250 faq, this has me convinced:
"Engines warm drastically faster when under load than when under no load (idling). The evils of idling are ultra low oil pressure at a time when the oil is at its thickest and doesn't flow very well. That means that right after starting is the point where you have the worst lubrication. By riding you're forcing the oil to move more and provide lubrication to the points that aren't bathed in oil (think heads)." - http://faq.ninja250.org/wiki/Warming_up_your_engine |
August 6th, 2011, 06:17 AM | #53 |
Join Date: Jan 2010 Motorcycle(s): 2005 Suzuki S50, 2006 Kawasaki Ninja EX250F, 1990 Honda PC800, 2000 Yamaha TW200 Posts: 848
I had the same advice from Detroit Diesel on a turbocharged engine for my boat, about running it for a minute or two at idle speed before you turn it off. But in all reality, how many degrees is the turbo, or the engine, going to cool off in another minute? Seems the fastest way to cool it is to shut it off. It probably has more to do with making sure it is properly lubricated with oil than dropping the temp a few degrees.
August 6th, 2011, 08:22 AM | #54 |
I usually walk out to my bike with all my gear on except helmet and gloves. I'll usually stick the key in, turn the engine on then let it idle while I put my gloves and helmet on and zip up my jacket. Then I'll get on and pull the clutch lever in for a sec to wet it up, maybe one or two lil throttle blips. Then I'm off
'09 Ninja 250R SE TB Slip-On l Puig DB l Pazzos l Pro-Grips |
August 6th, 2011, 08:24 AM | #55 |
They cool off a tremendous amount in just a minute or two; it's the water-cooling that is circulating while the turbo is idle that pulls away a ton of heat. The turbo is relatively small, and the cooling system for it is large enough to be a very significant heat sink. The goal is to get the turbo and all of its parts cool enough that it won't coke the oil that lubricates it. Once it's below a certain temp, it's fine.
August 6th, 2011, 08:48 AM | #56 |
Join Date: May 2010 Motorcycle(s): Current: '11 ZX-6R; Previous: '09 Ninjette; '08 ZX-6R (Ex-Wife '09 TU250X) Posts: 981
R.I.P EthioKnight (Alex) |
August 6th, 2011, 09:24 AM | #57 |
I only choke/warmup when it's dead cold. other than that it's just hit the starter and go, then take it easy on the rpms until it's fully up to temp
I usually set the choke so it idles around 2000-2500 rpm and put my gear on. This gives it about a minute, maybe 2 while I futz around with my helmet and ear plugs etc. then I ride away with the choke on and it usually doesn't need the choke any more after about a mile, so I turn it off. Untill the temp guage reads up to the second white line, I keep my rpm's below about 6k. then it's happy normal riding |
August 6th, 2011, 12:05 PM | #58 |
Are you saying that when the turbo is not spinning, the engine is cooling it off using the engine's own cooling system? The turbo gets hotter than 180-210 degrees and the engine cools it off?
By and large, the quickest way to cool off an engine would be to turn it off and stop generating heat. The cooling system actually maintains proper operating temperature, allowing the engine to warm up to it's designed parameters, and to remove excess heat to keep it from overheating. The thermostat controls that by regulating coolant flow. The cooling system doesn't cool it off. The cooling system doesn't change the temp of the exhaust gas going through the turbo either. Turbos that has their own interccoolers are to cool the temp of the air blown into the engine to make it more dense = more air. |
August 6th, 2011, 05:31 PM | #59 |
You're right, in that the quickest way to cool off a normally aspirated engine whose cooling system is working normally, is to just turn if off. But a turbo engine is a bit different. The operating temp of the turbo itself can be many hundreds of degrees warmer than the oil temp or the water temp. That's why just about all modern ones are now water-cooled directly. Running that water-cooling system for a short while cools the turbo much more than it would by just shutting off the engine immediately after running the turbo hard. The cooling system for the turbo is different than the intercooler. The intercooler is for a denser charge. The water-cooled functionality of the turbo is to keep the turbo itself cool.
Keeping your ears warm | Hero Danny | General Motorcycling Discussion | 10 | September 18th, 2014 08:39 AM |
Should i let my bike warm up? | jack_bm | 2008 - 2012 Ninja 250R Tech Talk | 54 | April 16th, 2013 12:31 PM |
Warm Greetings From Indonesia | autopilot | New Members | 8 | September 26th, 2010 06:38 PM |
Little Warm Today | HKr1 | Off-Topic | 8 | June 20th, 2009 06:00 PM |
How do you warm up your ninjette? | 00v_Lucky | General Motorcycling Discussion | 31 | April 3rd, 2009 06:03 PM |
