Go Back   ninjette.org > Marketplace > Motorcycle-related
Old July 18th, 2011, 08:04 AM   #1
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
No-cut Diode kit
I just finished my first no-cut Diode kit. I couldn't make it fully plug and play without adding to the cost. Wiring up a 9 pin harness would take a lot more time and the way I do it, if you can remove your front fairing, you shouldn't have any trouble removing a pin and reinserting it into another harness. Please read my DIY for more info.
Price is $15 shipped in the US, $16 shipped to Canada. All others, please pm me for shipping quotes. I'm still working on my new website, so I can only take orders thru pm at this time.
Thanks!
Tri
The www.ModMy250.com guy
Old July 18th, 2011, 10:41 AM   #2
caps
Sexy Beast
caps's Avatar
Motorcycle(s): 2010 Ninja 250R, 2006 ZX-14, 2012 Ducati Monster
I don't have ANY led's on my bike right know, but plan to go flush mount in the front and integrated in the tail. If I installed this now would it have any effect?
2010 Ninja 250
2006 Ninja ZX-14
^Both Links
caps is offline   Reply With Quote
Old July 18th, 2011, 11:13 AM   #3
CThunder-blue
ModMy250.com
No, it shouldn't affect operation of stock lights. The way the kit works is that it takes both incoming signals and applies power to the indicator. The reason the stock wiring causes the 4 LED blinkers to flash at the same time is because the circuit is in a loop and there's no terminating ground at the indicator. The bike relies on the turn signals and indicator to draw enough power to keep the opposite side from blinking. This creates a ground at the indicator so that power isn't fed back thru.
Old July 18th, 2011, 11:16 AM   #4
caps
Sexy Beast
caps's Avatar
In that case I'll take one. I'm gonna take a look around and see what else you. Have that I would be interested in, and then I will PM you
2010 Ninja 250
2006 Ninja ZX-14
^Both Links
Old July 18th, 2011, 11:22 AM   #5
CThunder-blue
ModMy250.com
No problem.
Old July 18th, 2011, 11:28 AM   #6
caps
Sexy Beast
caps's Avatar
pm sent
2010 Ninja 250
2006 Ninja ZX-14
^Both Links
Old July 20th, 2011, 01:12 PM   #7
ws6lt4
Motorcycle(s): 2005 zx6r, 2009 250R
I have the LED front blinkers and tridon relay you offered as a group purchase and also a hot bodies undertail.
When I installed the front blinkers with the stock rears along with the tridon relay, it worked perfectly. Then I installed the hotbodies LED undertail and I had 4-way flashers.
So... I purchased a LED flasher relay from SuperBright LED's (CF12ANL-01), figured this would fix my 4-way LED flasher problem, yet it did not. I still have 4-way flashers.
Would what you are offering fix my issue?
I'm at a loss here.
ws6lt4 is offline   Reply With Quote
Old July 20th, 2011, 02:50 PM   #8
CThunder-blue
ModMy250.com
I'm at a loss here.
Yes, it will solve the problem for you. The flasher relay is a separate issue from the power backflow issue.
Old July 22nd, 2011, 10:15 AM   #9
caps
Sexy Beast
caps's Avatar
I received mine, and am very pleased
I will install it this weekend.
2010 Ninja 250
2006 Ninja ZX-14
^Both Links
Old July 27th, 2011, 07:45 PM   #10
BlackNinja
Motorcycle(s): '09 2fiddy
I have your flush mount kit up front, and a HotBodies undertail on the rear. He's not kidding when he says the install takes 15 minutes - it took me longer to remove and install the fairing than the actual install itself. This is a very slick, very cool way of solving the blinker issue - without hacking your bike's harness at all. It would be no problem to go 100% back to stock later on down the road if you wished.
This kit rocks, and is a must have. Talk about making life easy!!
:thumbsup:
BlackNinja is offline   Reply With Quote
Old July 28th, 2011, 12:44 AM   #11
CThunder-blue
ModMy250.com
Thanks J! Glad it worked out for you. Not having to remove both fairings and the front cowl makes it all worth it to me.
Old May 24th, 2012, 11:26 PM   #12
lancer3vo
Motorcycle(s): 2010 Kawasaki Ninja 250R
Hey
So if I install 4 LED's in 4 of the signals, do I still need a relay after using this method? (Your invention on the no-cut diodes)
lancer3vo is offline   Reply With Quote
Old May 26th, 2012, 07:11 PM   #13
CThunder-blue
ModMy250.com
Yes, the Relay is still necessary unless you install some resistors. I don't recommend that because the resistors required dissipate a good amount of heat and can be dangerous if not mounted correctly.
Old May 26th, 2012, 09:32 PM   #14
lancer3vo
sorry im still new, so if i got the relay from 250mod, would that one go where the stock relay is currently? under the seat/trunk area?
Old May 27th, 2012, 07:45 PM   #15
CThunder-blue
ModMy250.com
Yes, the new relay replaces the old one. Although its not under the seat. You will see it when you remove the rear left fairing.
Old July 24th, 2012, 08:00 PM   #16
larson38
Motorcycle(s): yes
Solid front turn signals
I installed the intergrated tail from custom LED, the flasher relay they said I needed, and the diode that was also said to be needed... the tail works great but my stock front signals just stay solid (no flash). Anyone have any suggestions?
larson38 is offline   Reply With Quote
Old July 24th, 2012, 09:37 PM   #17
CThunder-blue
ModMy250.com
Sounds like a relay problem. Unplug the tail light and see if the front blinkers flash again. If they do, you need a better relay.
DIY: Installing No-Cut Diode kit from modmy250.com CThunder-blue 2008 - 2012 Ninja 250R Farkles 76 October 29th, 2022 03:33 AM
Does my pre-gen need the diode mod? mayonaise_invasion 1986 - 2007 Ninja 250R Tech Talk 16 August 22nd, 2014 11:31 AM
Bad Diode red5 2008 - 2012 Ninja 250R Tech Talk 3 July 26th, 2012 04:27 PM
Diode Mod. RedRider715 2008 - 2012 Ninja 250R Tech Talk 4 March 12th, 2011 08:40 AM
LED/DIODE question. Seattle_Chris 2008 - 2012 Ninja 250R Tech Talk 8 June 23rd, 2010 08:48 AM
