July 30th, 2012, 05:07 PM | #1 |
Anyone ever use generic motorcycle controls/switches?
My friend's Katana 600 has "sticky" left-hand controls and I bumped into these things while looking for a replacement:
http://www.ebay.com/itm/Motorcycle-T...4aa623&vxp=mtr http://www.ebay.com/itm/Universal-Mo...item3cc80f7494 http://www.ebay.com/itm/Motorcycle-L...e247a6&vxp=mtr Until last week, I was in the market for LH-side EX250 controls, so I wish I had found that sooner. It looks like cheap stuff made for generic Chinese scooters and the like, but it looks like it could be made to work. The cheaper-looking left-only one seems like it may free up some room on the bars to mount more stuff but the toy-like appearance makes me wonder if it even has push-to-cancel. The left/right set looks much better but, even though his right-side controls have cosmetic damage (PO put holes through the kill switch for some reason), we're on a shoe-string budget. We could probably get used OEM controls for that much. Out of curiosity, I looked for a right-hand generic and could only find that L/R kit. The LH controls are more serious because he can't cancel the signal when turning left even when he forces the switch back to the center and pushes it. The only way to cancel left is to push right, let it recenter (it only sticks left), then push it to cancel, which sends all the wrong signals to the drivers around him and distracts him when he should be riding. Does anyone has any experience with these or other generic controls? Are they typically weather resistant? Difficult or easy to push? Quirky to operate? |
July 30th, 2012, 05:13 PM | #2 |
I just looked again and I do see one problem with the cheaper one: No choke. He needs choke. One of the auction listings does claim that it's weather-proof. I recall that some bikes have the choke cable mounted such that you directly push/pull on a plug in the end. I wonder if we can convert to something like that for cheap.
July 30th, 2012, 05:13 PM | #3 |
did he try lubing the cables first?
a lot of times that all it takes |
July 30th, 2012, 08:45 PM | #4 |
I don't think that would help with the turn signal issue. The other "sticky" control is the hi/lo beam, which works fine except that the dash indicator doesn't light. Strangely, I saw it light once when messing with the turn signal even though the hi-beam was off, so it isn't that the dash indicator bulb is blown or anything.
July 30th, 2012, 08:53 PM | #5 |
I told you bro
Join Date: Jun 2012 Motorcycle(s): 1996 Ninja 250r Posts: 680
Are stock ones even "weatherproof"? I don't ever recall seeing anything showing that it need sealing when I've opened up controls on other bikes. As long as your cables have all their protective skin/cover you wouldn't need to worry about weather ruining them. If you're friend is still worried he could use seal all on non moving parts.
July 31st, 2012, 08:42 PM | #6 | |
i think its either a corroded wire, or a loose connection for the dash indicator. you'll have to test everything down to the relay. i would go with the oem switch instead of scooter parts, the internals are rated for more usage. i dont see any advantage unless your trying to get rid of the choke lever. |
When were motorcycle controls standardized? | Soujyu | General Motorcycling Discussion | 3 | February 15th, 2014 04:04 PM |
[motorcycle-usa.com] - Kuryakyn Launches Kinetic Hand/Foot Controls | Ninjette Newsbot | Motorcycling News | 0 | April 26th, 2013 03:00 PM |
left hand controls 95 bike 05 controls | mapolley07 | 1986 - 2007 Ninja 250R Tech Talk | 12 | December 22nd, 2011 10:05 AM |
[motorcycle.com] - Deep South Choppers Shocker controls | Ninjette Newsbot | Motorcycling News | 0 | October 21st, 2009 04:10 PM |
