Go Back   ninjette.org > General > Cargo Space
Old July 5th, 2011, 06:07 PM   #1
setasai
setasai's Avatar
DIY: Another Hardlocking Saddlebags w/ Quicklock
As per slolane's thread, using his inspiration, I came up with this bracket system. I used 1inch square aluminum tubing with steel hex bolts and steel T-braces to mount the bracket to the undertail of the bike.
I think overall, with the hardcase on the bike, it looks pretty good. Once removed, those brackets are ugly as hell. I have yet to paint them because I think I want to make a few tweaks to the height and width of the brackets so that it holds the cases closer to the bike. After I paint them black or maybe, just maybe, wrap them in carbon fiber cloth, it'll hopefully look less out of place.
I went this route because it would allow for passengers with the location of the cases farther back, and because it is easily removable as givi has intended. This also allows me to move the givi cases to another bike if I so choose.
Here is the most comprehensive list I can come up with:
From Homedepot:
*5/16in Hex bolts w/ washers + nylon locknuts -- should have used 1/4in hex bolts
*1in square aluminum tubing -- might try something thinner or round tubing
*1/2in round aluminum tubing -- used as spacers in the undertail mount around the M6 screws for support
*T-brace to connect the square tubing -- I really wish I could weld the joints instead.
From Lowes:
*M6 x 75mm Hex bolts -- Lowes is the most local place I could find M6 bolts in that length. At other locations the max length is 50mm and that makes it slightly too short. I think I could have also gotten away with 65mm length bolts so that it'll be a shorter distance and thus a stronger mount.
From Twisted-Throttle:
*SW-Motech Quicklock assembly that works with all Givi monokey cases. Just needs to find a way to set them up.
Some caveats of this method:
*without a welder or some way to join pieces of metal it becomes a major pain - I ended up using a hacksaw most of the time just because I could go slow and take my time.
*also because I had to use T-braces and bolts, the whole bracket is heavier than I would like it.
If I were to do it again... I would change the type of tubing I used. Square aluminum tubing is super strong but it looks ugly and doesnt really flow with the style of the bike. I'm thinking about some kind of steel or aluminum tubing and a welder. The bolts also causes it to have a very clunky look. Despite this, I like the location of the cases since it does allow for passengers and makes the bike look a little longer and less compact.
Thanks slolane especially for the inspiration in turning our little ninjas into a more practical bike and possibly a touring bike for me. If anybody has any easy ideas to modify this "prototype" bracket into something sturdier and lighter, please feel free to comment.
Update: To test it's weight limit, I filled the E21's with water and there was little to no sagging anywhere. Looks like those mounts under the tail are pretty strong. I'm impressed.
Last futzed with by setasai; July 5th, 2011 at 08:23 PM.
Old July 5th, 2011, 06:41 PM   #2
Jerkson
Motorcycle(s): Blue 2010 Kawasaki Ninja 250r
Damn you. Looks good bro. I just ran outta daylight but I'm 90% done my build. I opted for 1/8" cold-rolled steel bar using the attach to seat method. Im guessing you bolted it to the frame using those 4 mount points just behind the tail light, correct?
Is it really sturdy? What bits did you use for the fingers on the bottom that slide into the slots on the sidecases? I was just about to weld the heads of carriage bolts to the bottom bar but yours looks nicer.
Well done
AreaP Quiet Core CF | 8000k HID | FP Jet Kit | Puig db | A&L rearsets | hotbodies undertail | airbox delete + k&n pod filter | Pazzo blue shorty levers | solo seat cowl
Jerkson is offline   Reply With Quote
Old July 5th, 2011, 07:04 PM   #3
setasai
setasai's Avatar
Well done
Haha thanks. Honestly as far as being sturdy goes, I can rock the entire bike using those mounts. When I mount the hardcase, the entire bike shakes but the bracket itself is stable. I was skeptical at first but I saw that in this thread where Shalev bought the official GIVI bracket and it was designed to hold both top and side cases. The only difference is that they have another mount point on the passenger peg bolts.
The quicklock from sw-motech is totally worth it. For $26 it saves you alot of trouble. Btw, damn you too for having a welder. It truely would make this build easier and cleaner.
Also, yes, I mounted it on the 4 bolts. It's only an M6 bolt so you need to make sure you use good bolts and washers to spread the load out onto the frame inside the tail piece.
Btw, it looks massive but I just went out to measure it and the widest part is 32in and the mirrors are 32in. I'm surprised but it's good to know that if the mirrors fit with no problems, the hardcases will too.
Old July 5th, 2011, 07:18 PM   #4
bob706
bob706's Avatar
Awesome!
Old July 5th, 2011, 07:21 PM   #5
Jerkson
Nice. I ordered the quicklock....it comes with latching points for the top and those nubs for the bottom?
It makes it hard for me being in Canada as I can only go to the PO box in the US once per week to get my packages. Also, having a welder != knowing how to weld. My welds look atrocious; I'm so sick of grinding.
Im going to build a reinforcing bracket on the seat portion both top and bottom to stiffen it up. The upper passenger foot peg bolt is my backup plan to add rigidity. I plan on painting mine flat-black with rattle can and then if I like how that looks keep it that way while I field test and eventually ..powdercoat it flat black.
I will try to have some pics up and a quick build thread like this when I'm done.
Paint it black and I guarantee it will look smaller
Old July 5th, 2011, 07:31 PM   #6
setasai
setasai's Avatar
Yes it comes with the latch at the top, the nubs at the bottom, and rubber stubs to keep it stable. Basically everything you would need if you wanted to mount it to a flat piece of metal. It's just tough because we're being minimalistic.
Haha you and me both. I spent alot of time cutting and filing those metal edges.
That's what I'm hoping for. Use a semi-gloss black. Flat black will look too cheap. I think if it doesnt have that silver reflection, it'd be less noticable and I'll like it more. Still have a few small things to iron out before that.
Goodluck, looking forward to seeing it.
Old July 5th, 2011, 09:22 PM   #7
slolane
Motorcyclist
slolane's Avatar
Motorcycle(s): 2014 Ninja 300 ABS
Hey Brian, great job!!
Very well thought out, your project turned out really nice. I think once the brackets are black they will appear much smaller, I'm interested to see how often you take the cases off once you start using them. Nice job on being able to keep the rear seat functional and I agree, the bike looks longer with them mounted back a little.
slolane is offline   Reply With Quote
Old July 5th, 2011, 09:27 PM   #8
NathanF
NathanF's Avatar
Motorcycle(s): 2009 V-Strom 650 ABS
Great work! I'm excited to see more people working on this.
Some ramblings: Before redoing entire project due to looks, get some plugs for the ends and paint it black. I bet that will make it down right disappear. Remember, because you painstakingly built it, you will focus on it and see every flaw there is. This is also why food tastes better when someone else makes it.
Another thought - what about making the side rack brackets easily removable? I see that you have two bolts that connect a T bracket from the bike mounted bar to the bag-holding bars. Instead of two predrilled holes, you could cut a channel such that you could slide in and tighten down some captive knob nuts for easy removal, rather than having carefully thread and wrench down two separate bolts. The question of stability (especially over a long ride) would be an issue, but it's something worth considering.
Keep us posted as you tinker with this. This is quite the engieering challenge, sinces it seems Kawasaki has done everything in their power to make adding saddle bags awkard and difficult. That's the cost of pretty I suppose.
Thanks for taking the time to take pics, it really contributes a lot!
NathanF is offline   Reply With Quote
Old July 5th, 2011, 09:46 PM   #9
setasai
setasai's Avatar
Yeah, I'll see what happens. Taking them off is moreso for when I get to a destination. Call it CarryIn Luggage if you will. I imagine the scenario of me riding to a hotel or friend's place and just bring the cases in holding all my clothes and toiletries. I'm also super excited to bring home my first chinese takeout meal using these sidecases. I swear, I work a lot for food. =)
Thanks for the suggestions. I actually have plastic plugs already purchased ready to go in but before I put them in, I want to be able to remove the bolts and paint it nicely. Not having to remove the plugs just to do that is a lazy move on my part.
As for the removal of the side brackets, I was thinking the main cross bar running under the tail would be an easier one to take off. It's just 2-5/16in bolts straight up connecting to another bracket. I built this whole thing to be modular just in case something messes up and also so that others that might be trying to do something similar can get some ideas. The undertail mount was SUPER easy to put together, it was the cross bar and the brackets to connect to the quicklocks that took alot of precision cutting and drilling.
Btw, If anybody wants to attempt something similar, I can give measurements for every part which would get you close.
Old July 6th, 2011, 12:23 AM   #10
/linked from main diy sticky
Old July 6th, 2011, 06:10 AM   #11
bob706
bob706's Avatar
Just a thought but could something like http://www.twistedthrottle.com/trade...view/6805/704/ work as an alternative starting point for side bags?
Old July 6th, 2011, 06:13 AM   #12
Jerkson
You could...but that involves welding/bolting onto a $140 bracket. That's almost the cost of both sidecases. I believe the idea here was to keep costs at a minimum.
Old July 6th, 2011, 09:12 AM   #13
setasai
setasai's Avatar
He's right. Givi makes brackets for both top and side case in I think from another thread but it costs around $425 shipped from overseas just for the brackets.
http://www.ninjette.org/forums/showt...highlight=givi
I probably spent $200 for the side cases, $26 on the quicklock mechanism, and around another $30-$40 on aluminum and bolts. The kicker is I spent probably around 3 full days working on it. Mainly because of measurements and drilling and cutting the metal. I dont have very metal tools so I used hacksaws and handheld drills with hand files the whole time.
Old July 8th, 2011, 01:13 PM   #14
setasai
setasai's Avatar
Update
Ok So I spent all day yesterday priming and painting the brackets. I also trimmed a little off the crossbar to get the bags slighly closer to the bike, about 1/2in closer. I am much happier with the result but my paint job kind of sucks so I have some chipping here and there from banging the tools against it. Not sure if spray paint is just that weak or maybe I need to give it more time to cure.
Since I'm impatient, I put it together anyways despite that. Here are some photos of the finished product. Like all of you said, paint it black and it'll look better. You were all once again so right. Fits very well. I also put those plastic plugs on the end of the tube.
Goodluck to all those wanting to attempt this project. I have to say that personally, every other maintenance work is easier to do than this. Dont get me wrong, it's totally worth it but dont expect to just walk into the hardware store once and be done with it. So many different things came up as I was working. For one thing, the brackets were in the way of the rear turn signals and so I moved them back more but to get to the connections, I had to take the entire tail piece off and reroute the wiring. Worked out better though because now the sidecases dont obscure them.
Apologies for the sideways pictures. Not sure why it's like that. Looks fine on my computer.
Old July 8th, 2011, 01:28 PM   #15
slolane
Motorcyclist
slolane's Avatar
Great work Brian!! Looks great and very functional. Based on your project mine seems to be much easier... adding the quick removal brackets and mounting the cases back a bit further made it more of a chore. Again, looks great!!!
Old July 8th, 2011, 01:42 PM   #16
setasai
setasai's Avatar
Haha, Yea definitely. I think alot of it has to do with the fact that I used the undertail bolts instead of resting the unit on the seat pan. Weight distribution becomes very different when that happens. Cant wait to see what Jerkson comes up with. While currently it's sturdy, I dont know if the undertail bolts can handle a topcase along with it. One day we'll find out. Thanks again for the inspiration. I doubt I'd have attempted it without seeing how it turned out on yours.
Old July 8th, 2011, 07:28 PM   #17
slolane
Motorcyclist
slolane's Avatar
Glad I could help, this mod really turned my bike into primary transportation for me allowing me to ride A LOT more. Yours really looks great, as said above we are our own worse critic so no worries about a little paint chip or whatever. On mine when I made a little exhaust hanger I had to shorten/cut down the right sidecase bracket support and rebend it... doing so after all painted and all left a small little crinkle but I can live with it for now.
So did you get any take-out on the bike yet? I have several times for dinner, lunch and brought home "doggy-bags" from restaurants...
Old July 8th, 2011, 11:06 PM   #18
setasai
setasai's Avatar
Haha no not yet but that's because I just finished today and went out for drinks instead with some friends. I'll be preping it up for a 900mile roundtrip from NorCal to SoCal in about a week so it will get used very soon.
Old July 8th, 2011, 11:09 PM   #19
NathanF
NathanF's Avatar
Be sure to get at least one fairly decent ride in before then. You don't want to find some unexpected issue half way through your trip. And make sure you're bringing the tools necessary to tighten / adjust any of the bolts on the mount if the need should arrise. I think you know where you can store said tools!
Old August 6th, 2011, 01:56 AM   #20
NathanF
NathanF's Avatar
Any chance you can post another pic or two of the mounting point underneath the seat? Also, one looking down with the rear seat removed if there is anything visibly different in there.
Thanks!
Old August 6th, 2011, 08:31 AM   #21
setasai
setasai's Avatar
Thanks!
Yea sure. I'll get to that tonight after our group ride. Wont be till atleast 6-7pm tonight though. The picture looking down with the seat removed might be tough to see anything because I have other things mounted blocking the view but i'll give it a shot.
Old August 7th, 2011, 09:58 PM   #22
Guitarman823
The Invisible Ninja
Guitarman823's Avatar
Motorcycle(s): 04 Ninja EX250, 09 Ninja ZX250R
Great Job! Looks like the finished product will be very useful.
Do your side cases click on and off? Or are the bolted on?
Maybe that is what the quick-lock attachments do? ;0)
Anyway Looks Great! Oh, and Enjoy your Trip!
Guitarman823 is offline   Reply With Quote
Old August 7th, 2011, 10:57 PM   #23
setasai
setasai's Avatar
Yea they come on and off exactly like how givi intended them to.
Sorry Nathan, havent gotten to the pictures yet. Been quite busy.
Old August 7th, 2011, 10:59 PM   #24
They look great on the bike!
Old August 7th, 2011, 11:03 PM   #25
setasai
setasai's Avatar
Thanks Alex. Surprisingly, It didnt feel much different in the handling department on our ride. Might have felt just a hair more stable with the extra weight. Cant be sure since I wasnt really paying attention to it.
Old August 7th, 2011, 11:26 PM   #26
NathanF
NathanF's Avatar
No worries! I may actually be just fine without them, if you can answer a few questions:
1) Did you put a metal flatbar cross bar on top of the rear frame, like what is provided with the genuine Givi rack? Or did you just use the four existing bolt holes as is?
2) Is the frame mounted totally perpendicular to the four bolt holes, or did you build a slant in somewhere to make the bags sit more level?
3) Are the trapezoidal brackets you made 1 inch square tube as well, or something else?
Thanks.
By the way...right about now I'm dreaming of T-brackets. Welding is a lot more difficult than it looks.. I've already wasted $10 of metal just practicing, and I'm still not able to reliability produce good clean welds.
Old August 7th, 2011, 11:40 PM   #27
setasai
setasai's Avatar
Thanks.
1) There is no metal flatbar. I thought it might be a concern/problem but I figured that the welds are factory made and most welds will probably be able to handle any weight I can throw at it. I do not have a topcase though. If I ever add a topcase to the same mount, I may add that flatbar cross bar. Be sure to use loctite on the nuts.
2) For sake of simplicity, I mounted them totally perpendicular. It kind of flows with the bike leaving them on an angle.
3) Yes, they are 1inch square tubing as well. Just cut so that the long side is 3inches and the short side is 1inch. Angle it so that you lose an even amount on each side. I should also mention that at the time, I was going to use steel so the trapazoidal brackets are steel but the rest are all aluminum. You will also want to use aluminum tubing as spacers to keep the brackets snug. Unless you have a better idea, let me know.
The T-brackets are actually very secure. I only have one complaint about it and that's the bolts. Had I known how to weld, i'd have done the T-brackets anyway but without bolts. Welds dont need to be super pretty. You can also use an angle grinder or dremel to clean up your welds and once you paint it, you wont see alot of the blemeshes. Goodluck and let me know if you have anymore questions.
Old August 8th, 2011, 11:08 AM   #28
setasai
setasai's Avatar
Here is a picture of the trapezoidal bracket for the undertail. I tried to put a piece of paper in the back for contrast but couldnt get it to fit any higher up. Hope this helps.
Old August 13th, 2011, 09:20 PM   #29
NathanF
NathanF's Avatar
Thanks for the additional pic, and all the answers above. (Incidentally, those are all the answers I wanted to hear, since they are the path of least resistance. )
A few more questions:
1) What does the purpose of the rubber between the joints serve?
2) Have you noticed any instability or rattling with the case due to the T nature of the main rack, especially when it's not very full or empty? I was thinking it could be a H on its side rather than an upside down T to fix that, but it would be more weight.
3) Do the trapezoidal brackets need to be notched out to wrench down the main four bolts, or could I get away with just the 45 degree cut without any notching?
(By the way, you're going to hate me...I bought this from Amazon for $199 shipped: http://www.youtube.com/watch?v=Y5k5tJvjygQ It is absolutely amazing for the price. Just cut the trapezoidal brackets, minus the notch. About 5 seconds per cut. No sparks, no heat, no hacksaw .)
Old August 13th, 2011, 10:13 PM   #30
setasai
setasai's Avatar
1) rubber was for vibrational dampening between the body and the case. Not sure if it's necessary. I just thought it'd be nice so that it gives the mount a little flexibility.
2) zero instability or rattling with the case even with the nature. I did put a rubber stopper on the lower T area to keep the case tensioned.
3) No notching is necessary. The notching was because initially i used shorter bolts and the trapazoidal piece was interfering with the turn signal/hooks. Since I used longer bolts, I was able to extend it lower but I was lazy so I didnt bother making new brackets.
That tool looks amazing. Kinda like a miter saw with different blade on it. I wonder if they sell the blades so that i can just put it on my miter saw and be done with it.
Goodluck. I'm glad you're learning from all of our builds. I love my mount. It could be cleaner but it's definitely holding up just fine. I do have one modification that I plan on adding. I want to get longer bolts from mcmaster and put a flatbar crossbar for extra strength but i figured it can be done later.
Awaiting your finished product.
Old August 14th, 2011, 02:08 AM   #31
NathanF
NathanF's Avatar
Good to know about the notch, that will save some time. I think I might try the rubber idea as well.
As for Evolution, they do sell blades. Unfortunately, chop saws run much faster than metal cutting saws, so it's considered a Bad Idea to use them on steel. Also, they're not sealed against the metal chips that go flying, which is not ideal. I know all this because I had the same idea as you.
I've decided I am definitely going to do a flat bar across the top for extra support. The factory threads are obviously not intended or designed to hold this kind of downward weight. They might do it just fine in perpetuity, but I don't want to worry about it.
Getting the proper sized bolt has me a bit concerned though. Most of the longer bolts out there are not threaded all the way. For this application, the threads need to be longer than the distance from the top of the flatbar to the bottom of the pre-existed threaded hole in the frame. Too short, and the bolt won't reach, since the non-threaded portion will not pass through the existing threaded hole.
That also means the length of the bolt has to be just right. That shouldn't be too difficult to figure out, but it seems most places that sell bolts don't list the length of the threaded portion. I don't really want to shell out $10-20 for bolts shipped only to find out they don't work.
Buying M6 threaded rod solves this whole problem, but I haven't found any M6 threaded rod that is class 12.9, where as the socket bolts in the 90mm+ variety are all 12.9.
Any thoughts? Also, how long are your spacers? I'm thinking about offsetting the main bar as to decrease the length of mine, since those bolts are probably the weakest part of the whole thing. I might not bother though, especially if I can get class 12.9 for the four main bolts.
Old August 14th, 2011, 08:55 AM   #32
setasai
setasai's Avatar
The bolts were my main issue as well. Which is why i had the notches originally because the bolts were from home depot and those were the longest that they had. I also used a trapazoidal shape for that same reason. I needed extra length to clear the undertail. All this was solved when I found longer bolts from lowes except like you said, they are not threaded all the way. You could try threading your own if you have the tools. Otherwise, this is the same limitations that I've encountered.
This also leads me to my next statement about the spacers. The spacers are just a hair longer than all the thicknesses of the washer and trapazoidal piece plus whatever non-threaded part of the bolt is. I wanted that section to have some tension on it. FYI, the frame is not threaded. The undertail threaded portion is completely seperate from the rest of the bike so the only thing holding that apparatus up are the 4 nuts that you'll be using on the top side. Hence the great idea for the crossbar. If you solve my bolt issue, let me know as i'd like to swap those out as well.
Old August 17th, 2011, 11:32 PM   #33
NathanF
NathanF's Avatar
Thanks for the additional info.
Finally got a few minutes to work on this. Got the two trapezoidal brackets cut, and the two main holes on each drilled. I determined spacers that were 1 7/8" long allowed me to a) have clearance for the main bar not to hit fender, b) not prematurely bottom out the unthreaded portion of the bolt in the undertail bracket, and c) allow enough room on top to get a nut on. This is with a 65mm bolt.
It's tight though; I don't really have any additional room for washers.
Anyway, I put a piece of cardboard across the top of the frame and measured the difference. Looks like 100mm bolts would do the job. Going to see if a friend of mine has an metric tap and die set. Not sure how feasible it is though to thread the smooth shank of a 12.9 grade steel bolt.
I can see why you said to hell with the cross bar. It really seems nice and solid without it.
Old August 18th, 2011, 09:51 AM   #34
setasai
setasai's Avatar
Sweet. Thanks for the update. Glad to help. If you can find a way to easily make those longer bolts or purchase them, let me know. I'd like a pair as well for security and piece of mind purposes.
Old August 18th, 2011, 06:27 PM   #35
NathanF
NathanF's Avatar
Alright, here's what I have to report:
1) I found a local place that, unbelievably, sells M6 x 1.00 socket bolts up to 110mm in grade 12.9 steel. About $1 a piece, much better than the huge costs online with shipping. I bought 110mm and 70mm lengths. The 70mm fit my two rear mount points without bottoming out or leaving too short of bolt left to get a nut on.
2) Using an M6 die, I was able to add threads to a standard Lowes 8.8 partially threaded bolt with relative ease. Trying the same with a 12.9 grade bolt == fail. Not a chance in hell, at least not with my friend's Craftsmen made-in-the-USA somewhat decent quality tap and die set.
That leaves us three options:
a) Get a coupler nut, and use two bolts to bridge the distance. Main bolt would go up into the coupler nut, then short bolt goes through cross bar from top into same coupler below. Downsides is lack of continuous bolt holding the whole thing together, and unlikelihood of finding rated coupler nut.
b) Drill the undertail threads out. Lets us use one continuous high grade bolt without any breaks. Downside is that it modifies the bike in a non-fixable way.
c) Forget the crossbar entirely and hope for the best. (Keeping in mind that the whole mount breaking loose could very well result in death.)
I'm leaning towards option B. Even though it is a permanent mod to the bike (which I have never done, and don't normally do if I can help it) undoing it would simply mean a nut and a slightly longer socket bolt. Should be invisible / unnoticeable both functionally and aesthetically in terms of selling the bike in the future.
What do you think?
(By the way, let me know if you need any of the aforementioned bolts. I will be going back to that local place, and could buy and ship them at cost to you.)
Old August 18th, 2011, 07:50 PM   #36
setasai
setasai's Avatar
Thats a tough one. I think I would lean towards option C until I decide to add the topcase and then i'll switch to option B... maybe. I'm sure there's a way to get those bolts somewhere fully threaded. Will have to keep looking.
Let me know what you decide to do. I dont plan on adding the crossbar until I get the funds to possibly add a topcase mount to it.
Old August 23rd, 2011, 06:54 PM   #37
NathanF
NathanF's Avatar
Progress!
The welds are ass ugly and probably totally amateur and wrong in every way, but it doesn't budge if I try and use all my might to break it.
By the way, how far apart are your cases? The measurement I'm most interested in is the outside of the metal T bars on one side to the outside on the other side.
Old August 23rd, 2011, 07:20 PM   #38
setasai
setasai's Avatar
It's about 16-3/8" from outside of the bar to the outside on the other bar. I recommend you cut a slightly longer piece and mount it to the undertail first. Then trim the metal bar on each side until the cases are where you want them then weld it together. This way if your undertail bolt holes are a little off, you wont be lopsided.
Old August 23rd, 2011, 09:04 PM   #39
NathanF
NathanF's Avatar
Good advice, I will do exactly that. My real worry is not messing up the weld, since it will mean redoing one or both of the T brackets if I screw it up.
I noticed in one of your pics that you have two holes drilled on the bottom part of the T bar that are empty. Were these for rubber nubs that you decided shouldn't be there? Or were they just not installed yet in the pic?
Seemed to me like a good place to put them in addition to the main vertical bar, but if you found out later it was not, I'd like to know why.
Old August 23rd, 2011, 09:20 PM   #40
setasai
setasai's Avatar
Haha, funny you should mention that. Yes, they were initially intended for rubber nubs but you know what I found out? They got in the way of installing the case because the case needed to slide down into the slots and the sliding would push the nubs downwards. So, best place to put it is somewhere above so that it's not in the way of the sliding motion of the case and when you snap the case it keeps everything tight.
In the photo where I circled, I ended up putting chair bumpers there screwed in place. The thickness of the bumper was perfect because it provided tension against the case so it didnt bounce.
http://www.acehardware.com/product/i...ductId=1286055
I couldnt find black ones so I used white ones anyway. They're the perfect thickness so use that as a guide I guess.
PJD Saddlebags LittleRedNinjette Free stuff! 5 January 24th, 2015 07:42 AM
DIY - Yet Another, Another Hardlocking Saddlebag Mount NathanF Cargo Space 36 May 28th, 2013 10:11 AM
Yet ANOTHER Givi saddlebag w/quicklock setup Jerkson Cargo Space 31 March 1st, 2013 09:39 AM
DIY: Hard locking saddlebags (luggage) slolane Cargo Space 90 March 1st, 2013 08:54 AM
Saddlebags Yasko Items Wanted 0 December 21st, 2010 09:56 PM
