Old March 10th, 2009, 10:58 AM   #1
toku
toku's Avatar
Motorcycle(s): 08 Ninja 250
Sportisi Rear Hugger
I bought a rear hugger and swingarm cover from Indonesia a while back due to school and what not it took me some time to get around to putting it on. Once I started it turned out the hugger didn't quite fit as I expected. With a little bit of modification I was able to get it to a point where I'm ok with the results.
Here's a close up pic of the hugger
Another showing a larger view of the bike
Here's a shot of the reverse side
From a distance the hugger and cover actually look pretty decent, looking at it more closely there are some imperfections that I notice but perhaps someone not familiar with the installation will overlook
Yoshimura CF Full System, Dynojet Jet Kit, Kleen Air System Removed, Woodcraft Clip-Ons, Sato Rear Sets, Galfer SS Brake Lines, 15/44 Sprocket Combo, Home Made Fender Eliminator
toku is offline   Reply With Quote
Old March 10th, 2009, 11:10 AM   #2
ride2max
ride2max's Avatar
Motorcycle(s): Kawasaki ninja250r
Actually it same goes to mine and my friend, the hugger middle point is not exactly on the middle point rear tire. Need to do lot of adjusting and some drilling, then only manage to make it to the point where i like it too. The holes provided is not fit so have to drill bit upper or down.
ride2max is offline   Reply With Quote
Old March 10th, 2009, 08:23 PM   #3
watcanido
watcanido's Avatar
Hey toku, nice hugger man looks really nice. I'm in the process of installing mine as well just a question for you. Where did you get your galfer SS brake Lines from they look sweet. Is it made for the 250Rs or are they universal fit?
watcanido is offline   Reply With Quote
Old March 10th, 2009, 10:37 PM   #4
Sound Wave
Ramen Rider
Sound Wave's Avatar
yuri, looks good! so, would you recommend that kit or not? also, you live is the usa, right? do you mind my asking how much it was with shipping included. couldn't find prices on their website.
thanks!!
Old March 10th, 2009, 10:41 PM   #5
VeX
That's me!
VeX's Avatar
Motorcycle(s): 2008 Ninja 250r (Tis blue), 2008 CBR600RR
Hahah the main thing I couldn't get past was: How the hell did you bleed your brake with the line going up like that? It'd be damn near impossible to get air out of the high point.
VeX is offline   Reply With Quote
Old March 14th, 2009, 12:26 PM   #6
toku
toku's Avatar
I got the brake lines from an online store called calsportbike. They took a little longer to arrive though since they were colored. They are 250 specific.
thanks!!
After everything said and done for the item, shipping and money transfer fees I ended up spending just around 300 USD. Roughly half that price was the shipping. In the end would I recommend it? I would say it honestly depends, 300 USD is a bit of steep price, initially I was a little disappointed with the fit but it can be made to work and in the end it does look very nice. If the item could be had for half the price or basically if shipping wasn't a killer from Indonesia I would definitely say it's a great way to fill the void at the back of the bike.
I have a vacuum pump type thing, I've found that it has been fairly successful at bleeding the brakes and getting the air out. The break pressure is good and the breaks are responsive, it works for me.
Old April 3rd, 2009, 09:17 AM   #7
kirana
kirana's Avatar
Motorcycle(s): Ninja 250R 2008 Model
just for info:
next time please hold the front part of the hugger first then only the two side(so 2person will be better).need some presure,then mark the area to be drill.
yours is off set to the front.
the idea not to make the holes at the arm cover is,to let u ajust at what gap/hight from your tyre.
Max size will fit 160/60/17. but if u use 150/70/17 like me,then u need to add 1 washer under the L/R side of the hugger.
kirana is offline   Reply With Quote
Old April 3rd, 2009, 10:10 AM   #8
bprayogo
Motorcycle(s): N250R
^nicely explained by bro Kirana thanks a lot bro
bprayogo is offline   Reply With Quote
Old April 10th, 2009, 12:38 PM   #9
kirana
kirana's Avatar
the boss is here
Old April 10th, 2009, 04:57 PM   #10
bprayogo
There's already a special version for 150/70 tires, you dont need to put any washer under the hugger
Old April 10th, 2009, 11:10 PM   #11
kirana
kirana's Avatar
why dont u tell me,when i was in your shop last wednesday???
Old April 12th, 2009, 08:06 AM   #12
bprayogo
heee you already knowww :P
Old April 12th, 2009, 09:31 AM   #13
toku
toku's Avatar
Originally Posted by kirana View Post
just for info:
You're right mine is off set to the front however that was done intentionally beacuse I wanted more clearance between the hugger and the tire. If you compare your pictures to mine you'll see that there is a drastic difference in the gap to the tire.
In all honesty that's not what my main concern was with the item. I was expecting the hugger to lie flush on the swingarm, instead it bows out a bit. In general that's not a big issue however I wanted to retain my spools in the rear. With the cover bowing out a bit the spools would press on the cover and bend it akwardly if tightened all the way, and if not I'd be concerned that they would fall out. The solution was fairly simple so it's not a big deal, I was able to keep my spools and still mount the cover. Another issue I had was with clearance of the rear axle on one side the cover would lay on top of the axle, I tried turning and twisting and bending the cover every which way but simply couldn't get it to clear the axle entirely. Again the solution was simple so it not too big a deal, just a hassle really.
Old April 20th, 2009, 11:38 PM   #14
It cost you $300 USD to get it shipped where? I dunno where "Happey Valley" is. Canada?
I've wanted this one because the swingarm looks decidedly plain, diminuitive, and blocky/retangular. Too bad bprayogo hasn't gotten a US distributor yet.
Last futzed with by CZroe; May 3rd, 2009 at 12:41 AM.
Old April 21st, 2009, 07:33 AM   #15
kirana
kirana's Avatar
but he can send it to u man,no problem.
Old April 23rd, 2009, 04:32 AM   #16
I know, but it's just WAY too expensive after shipping. If he could ship in bulk to a distributor, it would be MUCH cheaper.
Old May 3rd, 2009, 12:43 AM   #17
Oh! It looks like you had to cut it to retain your spools without awkwardly clamping down on the bulging cover. Is that right? Was that the "solution" you mention?
Old May 3rd, 2009, 01:23 PM   #18
kirana
kirana's Avatar
no cutting or what so ever bro
Old May 11th, 2009, 11:21 PM   #19
ztrack157
The Sportisi Master
ztrack157's Avatar
Just so you Guys know I am now Bram's US distributor. I will have 11 of these bad boys by the first week of July. All colors available except the CF look. I will have a set price within a week or two. Best of all it will be under $200 shipped. If theres other products he carries that tickles your fancy let me know and I will get them in stock.
ztrack157 is offline   Reply With Quote
Old May 12th, 2009, 12:48 AM   #20
Sound Wave
Ramen Rider
Sound Wave's Avatar
were the fit problems that toku experienced fixed? or is it the same design?
Old May 12th, 2009, 07:50 AM   #21
bprayogo
actually there are no fit problem unless you are using 150/70/17 tires the 70 profile tire (except for the standard tire) wont fit well with our huggers, you need to put a washer under the hugger so the hugger wont touch the tire.
You can ask Kirana from Malaysian forum, how many of our huggers he fitted on his members bike .. every single hugger fit very well no problem whatsoever .
We have fixed the gap issue between the front part of the hugger and the arm cover.
I thanks Matt for his appreciation to our products and we'll absolutely support him in every way and hope that he'll do very well in the near future ..
Old May 12th, 2009, 09:08 AM   #22
Sound Wave
Ramen Rider
Sound Wave's Avatar
thanks for the clarification
Old May 13th, 2009, 06:30 AM   #23
You are my hero! I'm hoping you still have one in CP Blue by the time I pay off my fine (damned State of California) and save <$200.
Just in time too... I really didn't want white hendrix's A-tech copy because it only looks good in CF or Black, which will not go well with my CP Blue. The black/CF A-tech style would be A-OK on either black or white bikes (which I do like) but painting the bike would be way too much trouble just for a good looking hugger. Oh, and I [heart] CP Blue.
Does bprayogo offer an alternative cowl more like the stock cowl? Considering the price /availability, he should! FWIW, I use the helmet lock often so I would want one that closely resembles the second version of the solo seat cowling with a notch to allow it. That's not to say that the GP-style cowl looks bad, but it looks like it only belongs on green/black race replicas or Monster replicas.
Old May 13th, 2009, 12:35 PM   #24
ztrack157
The Sportisi Master
ztrack157's Avatar
If you twist his arm he might make one.
Old May 13th, 2009, 04:03 PM   #25
Jiu Jitsu Player
Live 2 Ride Forced 2 Work
Jiu Jitsu Player's Avatar
Motorcycle(s): 2008 RED 250r
I like the GP style cowl and would definitely scoop one of those up but only if it came in Red and black. The one I saw was black and red.
SAVAGE MODE: [ON] OFF
www.7milesdown.com
Jiu Jitsu Player is offline   Reply With Quote
Old May 13th, 2009, 04:14 PM   #26
ztrack157
The Sportisi Master
ztrack157's Avatar
I'm sure he can adjust colors. Are you going to want a Red hugger? I got two coming.
Sportisimoto USA is born.
Old July 23rd, 2009, 02:56 AM   #27
Zandit
Zandit's Avatar
Motorcycle(s): Red '08 Kawasaki Ninja 250R
Does it matter if I have an 130/80 profile?
Zandit is offline   Reply With Quote
Old July 23rd, 2009, 05:37 PM   #28
ztrack157
The Sportisi Master
ztrack157's Avatar
You may need to add a washer for clearance.
Old July 26th, 2009, 02:26 PM   #29
richierich781
Future Hall of Famer
richierich781's Avatar
Motorcycle(s): 2010 yamaha fz6r raven
Z. What's the word on the candy thunder hugger?
Posted via Mobile Device
richierich781 is offline   Reply With Quote
Old July 26th, 2009, 11:05 PM   #30
ztrack157
The Sportisi Master
ztrack157's Avatar
Candy Thunder next shipment. They didn't get the sample in time for this one. And I have had about 12 people asking for it (easily the most popular) mean while only 2 takers on CPB. I think rocking a black one with the Daytona blue bike looks good too. Endless options.
Old July 30th, 2009, 06:27 AM   #31
I absolutely WILL be buying a CP blue one from you even though I am not even close to having the money ATM, but you can go ahead and count me as one of the "takers."
Old July 30th, 2009, 06:54 PM   #32
ztrack157
The Sportisi Master
ztrack157's Avatar
I only have three coming in. one is claimed and mike sema has the option to buy on another one. So there is one left and three people are asking about it. I may throw it up on ebay and let you three duke it out.
Old November 20th, 2010, 10:13 PM   #33
hmingtea
hmingtea's Avatar
Motorcycle(s): 2010 ninja250r,2009 YZF Yamaha R15,YZF Yamaha R6
The Hugger Rocks!!!!!!!!!
hmingtea is offline   Reply With Quote
FS: Sportisi Rear Hugger V2 Black DJK Motorcycle-related 8 June 8th, 2015 09:05 AM
Sportisi Rear Hugger (2008+) samw Motorcycle-related 29 February 26th, 2013 10:52 PM
Sportisi Hugger GB ztrack157 Motorcycle-related 415 April 26th, 2011 06:25 PM
sportisi carbon rear hugger fastmark63 2008 - 2012 Ninja 250R Tech Talk 5 October 12th, 2010 01:06 PM
sportisi swing arm and rear hugger randomwalk101 2008 - 2012 Ninja 250R Farkles 13 January 7th, 2010 05:36 PM
