Old February 13th, 2014, 09:16 AM   #1
redsnapper
redsnapper's Avatar
Name: Red Snapper XXX
Easy no tool Rattling Clutch lever or short fingers fix
Hi Everybody!
Here's an easy fix for rattling clutch lever, and will help a tiny bit if you have short fingers.
What you need:
1 M5 size Lock nut with nylon/rubber in the thread
2 Rubber cement
Steps.
1. Put a tiny amount of rubber cement on the top of the nut, I use this to prevent the clutch banging against it. Let it dry. (Optional) I tried it with out rubber cement and it didn't make the lever noisy.
2. Once the Nut is dry. Pull in Clutch lever with your hand, and place the nut on the switch.
It does not need to be screwed in or feel tight. It should slide in very lightly, it should feel like sliding a cap on a pen.
Notes:
#1 I have a Ninja 250r 2009 model, may work with other models too.
#2 Works for OEM and after market levers (I am using the2wheels stuff)
#3 Makes sure your clutch safety switch still works
#4 Adjust your clutch cable, and test at a very slow speed to make sure it's working 100%
#5 Lock nuts come in different heights, so if it's too tall. it will cause your clutch safety switch to not work.
#6 My pictures are pretty bad, I had to pull the clutch in to take the picture, it's not a very good example how much shorter the clutch gets.
#7 For XS size glove hands, it doesn't help too much.
Please post comments or suggestions on how to improve this mod.
Last futzed with by redsnapper; February 13th, 2014 at 06:17 PM.
redsnapper is offline   Reply With Quote
Old February 13th, 2014, 02:29 PM   #2
Han Solo 1
Motorcycle(s): Had a 2008 Ninja 250, til some low-life stole it. Now riding a 2013 red cbr250.
I don't have a rattling lever, but I would like it to be closer to the handlebar (less of a reach) in its default position. Does this do that?
Han Solo 1 is offline   Reply With Quote
Old February 13th, 2014, 02:48 PM   #3
redsnapper
redsnapper's Avatar
Yes, it would help less of a reach.
I am a size XS gloves size it barely helped me. S-M size riders. It would be more useful
Old February 13th, 2014, 06:16 PM   #4
redsnapper
redsnapper's Avatar
I updated my instructions.
It's a M5 nut.
DIY - Fixing The Buzzing/Rattling Clutch Lever NathanF 2008 - 2012 Ninja 250R Tech Talk 12 May 5th, 2016 05:19 PM
Aftermarket levers clutch safety switch easy fix Old Lemon 2008 - 2012 Ninja 250R Tech Talk 1 September 5th, 2014 10:13 PM
Clutch lever with too much play. how to fix? 5evenz 2008 - 2012 Ninja 250R Tech Talk 11 November 11th, 2011 06:15 AM
Rattling Clutch Lever Archerzz 1986 - 2007 Ninja 250R Farkles 4 June 29th, 2011 12:40 AM
Fitting More Fingers Under Clutch Lever m11 Riding Skills 32 February 22nd, 2011 02:02 PM
