Old April 2nd, 2010, 09:56 AM   #1
BlueRaven
BlueRaven's Avatar
Motorcycle(s): '09 Ninja 250 Black
Clean and lube chain Help!
I've noticed we do not have a DIY on how to clean and grease the chain. I remember seeing a video last year but can't find anything anymore.
Looking at Noche's 600 mile schedule it mentions that we should use " only kerosene or diesel oil for cleaning o-ring drive chain". Well i guess this mean it's not recommended to use WD-40 then so i figure i can use the Rotella T6 right? This is getting so confusing for such a simple maintenance.
Would someone please clarify things for me before i lose my mind and maybe together we can make a DIY for others. I am willing to take pics when i do this hopefully today so i can ride in 70F temps tomorrow up north of the border
I'm not small, I'm fun sized
BlueRaven is offline   Reply With Quote
Old April 2nd, 2010, 10:09 AM   #2
jonthechron
Motorcycle(s): magHitVE
I used kerosene with a toothbrush and a pan below, (you wouldn't want kerosene to drip on the driveway) I lift my rear end and scrub the chain, link by link, it goes pretty fast, kerosene liquefies the grease on the chain like if it was a simple task.
Old April 2nd, 2010, 10:11 AM   #3
joyinc
joyinc's Avatar
Motorcycle(s): black 2010 ninja250
i used chain cleaner on my last bike... is that ok for this one?
joyinc is offline   Reply With Quote
Old April 2nd, 2010, 10:21 AM   #4
utahninja
Ride Smart, Ride Safe
utahninja's Avatar
Motorcycle(s): 2007 Ninja 250, 2006 Yamati 150cc Scooter
I use kerosene and a toothbrush to clean the chain. If you don't have any kerosene, you can pick up a small bottle from camping section at Walmart.
For lubing the chain, I use Dupont's Teflon Multi-purpose Lubrication. It is a wax for protecting your O-ring chain, and comes highly recommended by other bike forums. You can pick up a can for under $5 from Lowes.
utahninja is offline   Reply With Quote
Old April 2nd, 2010, 10:21 AM   #5
jonthechron
Sure, chain cleaner is probably the safest thing to use anyways... I've never used anything other that kerosene though, since it works so well, and it's so cheap...
Old April 2nd, 2010, 10:56 AM   #6
g21-30
g21-30's Avatar
Check These
http://www.ninjette.org/forums/showthread.php?t=31544
http://www.ninjette.org/forums/showthread.php?t=10182
Old April 2nd, 2010, 11:32 AM   #7
BlueRaven
BlueRaven's Avatar
Thanks sam!
Old April 2nd, 2010, 12:55 PM   #8
QuarterBoreNinja
Motorcycle(s): Why do you care?
Same here, I also use kerosene and a toothbrush to clean chains, I put the bike on a stand and scrub with a pan below to catch the nasties. Once the chain is clean and dry I use Maxima Chain Wax...
QuarterBoreNinja is offline   Reply With Quote
Old June 1st, 2010, 04:46 PM   #9
ScorpionNinja
ScorpionNinja's Avatar
Darryl, when you apply the maxima chain Wax (gold/black can), do you SOAK the hell outta the chain with the lube?
Do you wait 15 mins, then go back and rotate and wipe excess off, or just let it soak in for 15mins then go ride?
Either way, what is your guys exp, with the maxima chain wax FLINGING off?
How much or lil does it?
What amount do you lube your chain with?
Soaked as you spray on, or just alil bit as you spray it on?
Old June 1st, 2010, 04:53 PM   #10
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
I put it on after riding, slowly rotate wheel and coat chain with it. It sets well and doesn't fling much. No need to wipe off.
Old June 2nd, 2010, 08:02 AM   #11
mrlmd
mrlmd's Avatar
The Dupont Teflon spray is much cleaner. Nothing, like sand or dirt sticks to it, there is no fling off on the bike or dripping on the driveway, it's easy, cheap, and works very well. and minimizes cleaning of the chain in between spray-on applications.
Old June 2nd, 2010, 09:10 AM   #12
utahninja
utahninja's Avatar
I love this stuff! Get a can for under $5 at Lowes.
Ride Smart! Ride Safe!
Old June 2nd, 2010, 09:59 AM   #13
2WheelGuy
2WheelGuy's Avatar
I love this stuff. I used to use Maxima Chain Wax but this is clean and seems to lube better.
AFM #278
Old June 3rd, 2010, 01:58 AM   #14
Buffalony
Buffalony's Avatar
thanks guys.ive been looking for a new/cleaner lube to try.im doing my chain maint right now.usually I used a degreaser then wurth hhs 2000 Which I still think is fantastic stuff.but this time around I decided to try something different. I used black magic foam tire cleaner (which I just bought for the first time) as the degreaser then rinsed thoroughly and wow. I'm gonna grab some dupont tom.
Old June 18th, 2010, 10:05 PM   #15
BIGT94z
Motorcycle(s): 2008 ninja 250r
i have a newb question. im picking up some kerosene and dupont teflon spray tomorrow. do i just grab a cheap toothbrush to use with the kerosene?
BIGT94z is offline   Reply With Quote
Old June 18th, 2010, 10:14 PM   #16
Xoulrath
Xoulrath's Avatar
Motorcycle(s): Current: '11 ZX-6R; Previous: '09 Ninjette; '08 ZX-6R (Ex-Wife '09 TU250X)
I use WD-40 sprayed on a cloth at the moment. I need to get a toothbrush. I won't be doing kerosene being that the bike is parked in a forest. I live on five acres so I would prefer it stay five acres. No flash fires wanted.
As far as the chain lubricant, I use Royal Purple Max-Chain. I love everything Royal Purple and have had nothing but greatness out of their products.
Xoulrath is offline   Reply With Quote
Old June 18th, 2010, 10:49 PM   #17
lol... did you know the main ingredient in wd40 is kerosene?
Old June 19th, 2010, 05:40 AM   #18
mrlmd
mrlmd's Avatar
Smile
Use your old toothbrush and buy yourself a new one.
Old June 20th, 2010, 07:10 PM   #19
Xoulrath
Xoulrath's Avatar
I do now!
Well, we've been getting a lot of rain here so I think the trees are safe, LOL!
Plus, I am buying a shed tomorrow and the bikes will be in there by next weekend. Storage and workspace all in one. YES!
How To: Clean/Lube Chain patw Videos 47 July 24th, 2013 10:45 AM
How often should you clean/lube chain? clintalmighty 2008 - 2012 Ninja 250R Tech Talk 11 January 8th, 2011 03:22 PM
[visordown.com] - Free Silkolene chain clean and lube at Cadwell Ninjette Newsbot Motorcycling News 0 June 9th, 2010 11:40 AM
Clean chain & lube interval randomwalk101 2008 - 2012 Ninja 250R Tech Talk 3 July 20th, 2009 10:18 PM
[webbikeworld.com] - DuPont Chain Saver Motorcycle Chain Lube Review Ninjette Newsbot Motorcycling News 0 May 18th, 2009 09:50 PM
