July 27th, 2009, 11:28 AM | #1 |
Join Date: Jun 2009 Motorcycle(s): 2009 ninja 250r Posts: 39
little noise when braking
I hear a slight scraping noise when I apply my brakes. They are definitely NOT worn down. The bike only has 1200 miles. Sounds kinda like there is a piece of paper stuck in between the rotor and pad, but there isn't. Only hear it when brakes are first applied then goes away as bike comes to a stop. Is this normal?
July 27th, 2009, 12:48 PM | #2 |
Join Date: Apr 2009 Motorcycle(s): 2009 Ninja 250r Posts: 379
Try cleaning them. Not sure what it is though, maybe others have some ideas.
Also I don't know if it can happen on our bikes, but you could have a cracked brake pad. |
July 27th, 2009, 01:02 PM | #3 |
sir posts a lot
Join Date: Jul 2009 Motorcycle(s): '09 Black 250R Posts: 267
im a noob to motorcycles but on cars that can be normal. you live in 1 a very humid area and 2 your temp flucuates 20+ degrees a day (meaning it can be upper 70s in the morning and lower 100s in the afternoon.) what the translates is to the brake pads expanding and contracting a lot and consequently allowing moisture in between the space made, which can lead to slight squealing while initially breaking.....i think
ne whoo it doesnt sound like anything to be worried about. you could always check your roters for big grooves and check the brake pads for the indicators showing.
A girl walks into a bar and orders a "double entendre" So the bartender gave it to her "once you go black, you never go back." |
July 27th, 2009, 03:00 PM | #4 |
Join Date: May 2009 Motorcycle(s): 2009 Kawasaki Ninja 650RTE & 2009 Kawasaki Ninja 250R (SOLD) Posts: A lot.
on my bike, ive noticed a slight noise coming from the front brakes, when i apply them! its sounds like a tiny FAN spinning... not a sqeaking noise, no issues with the cooling fan either. front rotors look good, front pads look good. i think my noise is normal, nutin' obliously sounds grinding,scrapping,etc... lol
this kinda sound is yours? it only happens when i apply the front brakes, around low speeds... say under 30mph! its not the front axle bearing Seal sqeak weve all hear b4 |
July 27th, 2009, 07:02 PM | #5 | |
July 27th, 2009, 07:14 PM | #6 |
I get this too on my '03, only at low speeds. My research has indicated it's normal, since modern road brake pads contain metal mixed in as well to help give it some durability, so you're getting a bit of metal-on-metal action and this causes the scraping sound. You can get pure rubber brake pads but they'll wear out before you know it.
Just make sure you're not hearing HARD scraping like when your "brakes" (or what used to be your brakes) are scoring your rotor lol! |
July 27th, 2009, 07:21 PM | #7 |
Mine makes the the same noise but only at low speeds like others have noticed so it sounds like it is a normal thing.
July 29th, 2009, 06:02 PM | #8 |
Join Date: May 2009 Motorcycle(s): 2009 Ninja 250 (sold) Posts: 755
Mine makes the fan noise as well, mine also squeal almost every time I use the front brake, but my pads are not worn down.
September 19th, 2009, 12:06 PM | #9 |
self wrencher
ahhh...i have the same noise...glad it's normal
looking for help - noise | davila | 2008 - 2012 Ninja 250R Tech Talk | 13 | June 30th, 2012 08:54 AM |
Noise when braking? | Moto126 | 2008 - 2012 Ninja 250R Tech Talk | 6 | April 7th, 2012 06:42 AM |
Need help with a noise | TeamGreen | 2008 - 2012 Ninja 250R Tech Talk | 10 | August 28th, 2011 07:17 PM |
Braking issues | peter330 | 2008 - 2012 Ninja 250R Tech Talk | 5 | April 23rd, 2010 06:44 PM |
Noise under braking | randomwalk101 | 2008 - 2012 Ninja 250R Tech Talk | 3 | September 19th, 2009 11:17 AM |
