September 7th, 2014, 02:38 AM | #1 |
Down Under
Join Date: Jun 2014 Motorcycle(s): Kawasaki ZXR250C Ninja Posts: 296
Undertail LED's
Get on it! Super easy to wire up as it just plugs into the tail light wiring (easy to tap) no messing about with the battery or ignition, or a switch to manually turn them on/off.
This should make you more visible at night, with the light projecting down onto the wheel and the road beside. Looks much better in person as well |
September 7th, 2014, 06:45 AM | #2 |
sammich maker
MOTM - Apr '15
That is bad @as!!
Hot Bodies LED Undertail | dyeclan | 2008 - 2012 Ninja 250R Farkles | 0 | April 1st, 2009 03:53 PM |
