Old October 7th, 2014, 07:39 PM   #1
eddiekay
eddiekay's Avatar
Motorcycle(s): 300, WeeStrom
3D printed bike parts
So I got the bright idea to 3d print rear turn signal stalks. Has anyone seen 3D objects, perhaps 4" long and are they durable enough to take the constant vibes that thye'd have to as a signal stalk ? Everything I've seen personally has been small...trinkets.
Old October 7th, 2014, 07:41 PM   #2
kdogg2077
kdogg2077's Avatar
Motorcycle(s): 2015 Yamaha FZ07, Ninja 250r 2012 Limited Edition (Sold)
I've seen some pretty durable 3d printed stuff. I could see this working for a lightweight part like a turn signal.
"Take it easy driving. The life you might save might be mine."
kdogg2077 is offline   Reply With Quote
Old October 7th, 2014, 07:45 PM   #3
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
I just bought a 3D printer, the XYZ Da Vinci 1.0, it can print a 7.8 in cube. I've already built some quadcopter parts with it and the parts are surprisingly strong.
Old October 7th, 2014, 09:05 PM   #4
Klondike1020
Intrepid Adventurer
Klondike1020's Avatar
where is a pic of these? and why would it be any better than injection molded plastic?>
LIFE IS NOT FOR REGRETS OR EXCUSES.
Breath deep, seek peace.
Embrace the Madness. Life is good, let it be
Old October 8th, 2014, 02:08 PM   #5
Bubba
Motorcycle(s): 300
You can make your own design in any 3D CAD software, and it's cheap for a small number of units.
However, you will not get the nice finish or strength of injection molded plastic. Those plastic molds are very expensive to make.
I have access to our 3D printers in the engineering school, some next gen titanium and aluminum sintered units can make strong parts, but no near forged metal and CNC.
Bubba is offline   Reply With Quote
Old October 8th, 2014, 02:29 PM   #6
eddiekay
eddiekay's Avatar
Let me get more descriptive and see what you might suggest:
I want 4" lollipop round bright mickey mouse ears turn signals...because i want to be seen.
I can use the chrome stalks they come with pretty easily but...it's really gonna look goofy on the nicely faired ninja tail.
Or maybe build a shroud that houses the 4" light but "grows" out of the existing tail. Used to call it "frenching" the lights in the 60's.
So here's the end goal:
How to put a 4" turn signal on the 300 without making it look like Mickey Mouse.
I'd want a sculpted look that doesnt look bolted on
Old October 8th, 2014, 02:45 PM   #7
BlownWideOpen
BlownWideOpen's Avatar
Motorcycle(s): Stuff
I personally think you've got a losing combination either way. It will look terrible.
Paint side up, rubber side down!
BlownWideOpen is offline   Reply With Quote
Old October 8th, 2014, 03:42 PM   #8
Our SAE Baja team has printed parts for their brake bias linkages. Still using them a year later.
Old October 8th, 2014, 03:57 PM   #9
eddiekay
eddiekay's Avatar
I kinda think it might look pretty bad too but. I dunno. . The 300 rear sigs and tailight are inadequate IMHO. Brake blinker was better, strobes are illegal here. Hmmm...maybe a strip of leds...had them and the rear was very visible.
Old October 10th, 2014, 07:53 PM   #10
Hero Danny
Inline 4!!!
Hero Danny's Avatar
It could happen, but I'd imagine it would be easier/cheaper to just buy an aftermarket one lol
Be careful. Remember you are
invisible
Old October 10th, 2014, 10:24 PM   #11
leed
leed's Avatar
Motorcycle(s): Time will tell
I don't think your average 3D printer will be worth creating a complete part if your blinker will be on a 4 inch stalk. Blinkers not only vibrate, but they flex a ton with every bump and unless you beefed it up I would expect it wouldn't take too long for a printed part to shear at a single layer after riding. If you wanted to make a short stalk signal [like a flush mount], you'd be perfectly fine [except for maybe UV exposure? -- Use some UV rated clear coat/paint]
I'm wondering if your SAE Baja team doesn't use their brakes, or they're using sintered metal and not plastics! Even at full density, I would be very surprised if a part made from an FDM printer would hold up! Well, at least of a reasonable size. Still pretty awesome either way!
3D printers are common for prototyping and one of designs. Extremely useful for many things, though. Depending on complexity, the time and cost to create something you can hold/install is much less.
Old October 11th, 2014, 05:15 AM   #12
No it's definitely plastic. We made it
I think the plan was to use it as a prototype for sizing and testing. So they either have a milled aluminum backup already or one on the easy, not sure. But they were surprised that the plastic one held up so well.
Klondike, 3D printing falls under the category of "rapid prototyping". You can go from doodles on your computer to test fitting a part and tweaking measurements in an afternoon for minimal money, vs injection molding requires a whole set of molds to be made.
Custom printed shirts and stuff eddiekay Off-Topic 6 December 24th, 2013 10:34 AM
Are there any companyies that offer printed parts catalogs? desrik General Motorcycling Discussion 1 March 25th, 2013 08:34 PM
[hell for leather] - When Ural printed its own money Ninjette Newsbot Motorcycling News 0 December 6th, 2011 11:20 PM
98 parts bike bhalv Motorcycle-related 1 March 31st, 2011 09:51 AM
[topix.net] - The Racing Recipe: Two Parts Bike & Rider, Five Parts Perseverance Ninjette Newsbot Motorcycling News 0 October 7th, 2010 06:00 PM
