Old September 17th, 2011, 12:59 PM   #1
kingkang204
Motorcycle(s): Bike-less, Can I ride yours?
Carburetor / Valve Problem?
Hey Guys.
Original Problem: Puffing sound coming from the engine/Lack of Problem
Story: So as stated in a previous thread I made about a broken carb and the problems that could be associated with it. So I ordered a new Carb from Ztrack and got it last week but wasn't able to put it in my bike. Yesterday my brother and I found time and put it in, all the cables and hoses matched up. I wasn't able to test ride it last night because it was too dark but just now I went for a ride. The same problems are still there, there is a little bit more power but it seems as if the puffing sound has been amplified.
Possible Causes: The bike has 10300 miles on it and hasn't had a valve adjustment yet, could this be it? The puffing sound comes from the front end of the bike could it be an exhaust leak?
Plan for now: I plan on synching the carbs because that hasn't been done since the 500 mile service. I will try and find time to do the valve adjustment, I have service manual and plan on using the videos Ninja250r made (Thanks Man!).
The sound I hear when riding is around 0:20-0:30 in the video but its much louder when the bike is under load?
Does Anyone Have Any Thoughts Of What It Might Be?
*Alex feel free to merge this with my "Broken Carb" thread, I made a new one because the carb isn't really broken anymore*
RR stands for Responsible Riding... Right?
kingkang204 is offline   Reply With Quote
Old September 17th, 2011, 01:28 PM   #2
Boom King
So, where's the reverse?
Boom King's Avatar
Your video is marked as "private".
Old September 17th, 2011, 01:39 PM   #3
kingkang204
Sorry about that, I fixed it.
Thanks for the heads up
Old September 17th, 2011, 02:44 PM   #4
reaperw
reaperw's Avatar
Motorcycle(s): ninja 250
Looks like one of the headers is mising a bolt on the left side
Posted via Mobile Device
reaperw is offline   Reply With Quote
Old September 17th, 2011, 03:02 PM   #5
Socal5646
Socal5646's Avatar
Motorcycle(s): 2011 150cc chinaman scooter
Lol....good eye!
Socal5646 is offline   Reply With Quote
Old September 17th, 2011, 03:44 PM   #6
kingkang204
I didn't see that! So exhaust leak is a possibility? Do you think I could just take a screw out and take it to a local screw shop to get a similar one, or should I get the exact screw!
Old September 17th, 2011, 03:50 PM   #7
Skippii
Milkshake Drinker
Skippii's Avatar
I can't see the video, but I gather I have the exact same problem as you, missing a header bolt. I replaced all of the studs on my engine with stronger bolts from Home Depot, except for one, which is still broken off in the engine, and looks like it will remain that way until I have a chance to remove the engine from the bike and tear it apart.
Mine's a pregen, though. Don't know if yours uses studs or bolts.
"What a sweetheart."- ninja_sleeper to me
Old September 17th, 2011, 04:21 PM   #8
kingkang204
Mine Makes like a "Puffing" sound when the engine is under load. I didnt know that one of my headers was missing a bolt but an exhaust leak was one of the things I had in mind.
I'll try and replace that tomorrow and give an update.
Thank's for the ideas guys!
Last futzed with by kingkang204; September 17th, 2011 at 05:36 PM.
Old September 17th, 2011, 04:28 PM   #9
dubojr1
dubojr1's Avatar
Believe it or not those nuts are hard to find. I had this same problem and only after searching a dozen hardware store and part supplier... O'reilly's was the only place that had them in grade #8. They are metric nuts which no one seemed to keep on hand.
Old September 17th, 2011, 04:36 PM   #10
kingkang204
Theres a place where I live called "Tacoma Screw" and they have tons of fasteners and screws an washers and such do you think that they would carry these?
I plan on just taking another one out and seeing if they can match it.
Old September 17th, 2011, 06:42 PM   #11
Skippii
Milkshake Drinker
Skippii's Avatar
I can't believe the trouble some people seem to have finding nuts and bolts on this forum. Ace Hardward, True Value hardware, Lowes and Home Depot always seem to have what I need.
I'm sure any fastening store will have what you need.
Old September 17th, 2011, 07:05 PM   #12
Boom King
Boom King's Avatar
Depending on the screw or nut, finding metric hardware can sometimes be harder at your typical big home hardware store like Lowe's or Home Depot especially if there is no imperial equivalent. Ask me how I know after I was working on the Ninjette. A store specializing in screws like "Tacoma Screw" would be your best bet. If my mechanic is working on an import car and he needs a screw or bolt, he doesn't go to Home Depot.
Old September 19th, 2011, 04:01 PM   #13
kingkang204
So as I am writing this I have the biggest smile on my face, and its been a long time since I've smiled about the ninja.
The problems:
Missing 1 bolt on EACH HEADER
Ripped Diaphragm
The fastener place had the bolts, they're a little bigger on the outside but the inner diameter is the same. My guess is that the bolts rusted and slowly unscrewed themselves due to the vibrations. With the 2 shims under each needle and the snorkle removed its fantastic. When I was reading about the people who said it was like a new bike when they did that I thought they were over exaggerating, but its true.
What Improved:
Power (Torque, maybe horsepower I try not to speed so I may never know)
Throttle Response
Sound, it has a deep growl/wallow at small opening
Thank you all for the help! I would of never noticed that I was missing bolts on my headers.
Old September 19th, 2011, 07:15 PM   #14
reaperw
reaperw's Avatar
That will be $5 for the help right guys
As soon as i notcie your bolt missing i went outside to make sure my was still there as well
Old September 20th, 2011, 06:44 AM   #15
Skippii
Milkshake Drinker
Skippii's Avatar
torque isn't power, it's force. Horsepower is power, as are watts. You can't say the bike has more power but not more horsepower...that's like saying the temperature is hotter, but not in degrees.
Old August 15th, 2012, 01:04 PM   #16
Ninjettepgh
Motorcycle(s): 06 Ninja 250
The problems:
Ripped Diaphragm
Wow! I've been searching high and low about what this could be and alas, i have missing bolts on my 06 ninja
Now...forgive me for being a newb...but what are you all talking about "shims under each needle and the snorkle removed"?
Ninjettepgh is offline   Reply With Quote
Old August 15th, 2012, 01:08 PM   #17
red5
red5's Avatar
Motorcycle(s): 09 ninja 15.256
This is a good place to start but there are lots of other threads on this topic.
Shimming the Carb Needles
"We're not always doing business, but we're always open."
"For me, it is far better to grasp the Universe as it really is than to persist in delusion, however satisfying and reassuring." Carl Sagan
red5 is offline   Reply With Quote
Old August 15th, 2012, 01:34 PM   #18
Ninjettepgh
wow thanks for such a quick reply. I think i will definitely try it but...have two more stupid questions
1) still dont undestand what snorkel is?
2) does it really take 4ish hours to get into the carb and put another washer on?
thanks
Old August 15th, 2012, 06:33 PM   #19
red5
red5's Avatar
thanks
1. On the back side of the air box. Part 14073A in this photo...
2. More like an hour and a half or so. You can get to the needles without removing the carbs.
Old August 15th, 2012, 06:50 PM   #20
Ninjettepgh
Thanks... im in the middle of trying to get to my carb and i can't access the back two screws of each one because of the frame...tell me there's an easy way around this...
Valve adjustment problem! Graugaard 2008 - 2012 Ninja 250R Tech Talk 32 July 8th, 2013 05:03 PM
problem with carburetor maybe? alex.bowles 1986 - 2007 Ninja 250R Tech Talk 40 March 18th, 2013 12:58 PM
Valve Clearance Problem ElJokerr 1986 - 2007 Ninja 250R Tech Talk 9 February 22nd, 2013 12:40 PM
Problem with draining the carburetor! Please help! htsang07 2008 - 2012 Ninja 250R Tech Talk 14 September 5th, 2012 09:43 PM
valve problem dirtyrottenninja 1986 - 2007 Ninja 250R Tech Talk 6 July 23rd, 2011 02:17 PM
