Old September 22nd, 2013, 10:32 AM   #1
caineroad
caineroad's Avatar
Motorcycle(s): 2010 Ninja SE
Anyone using heated grips?
Autumn is already here and winter is coming, anyone installed heated grips before??
I saw some ebay ones for $5-7 just for the heating elements under the original grips. There are also some already made heated grips that will replace the the original grips.
I am fancying the below, it has variable heat adjustable (the switch looks very oem)
http://www.ebay.com/itm/22mm-ATVs-Mo...item2a30a39eac
Does it look like it will work for our ninja 250s?
caineroad is offline   Reply With Quote
Old September 22nd, 2013, 11:13 AM   #2
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Here's an older thread on those $5 grips...
http://www.ninjette.org/forums/showthread.php?t=90501
<-- Linky
Old September 23rd, 2013, 06:50 AM   #3
TonyKZ1
TonyKZ1's Avatar
Motorcycle(s): 1975 Kawasaki KZ400D (Sold), 1989 Kawasaki Ninja 250 (sold), 1997 Yamaha XJ600s Seca II
I use the Oxford heated grips, sport model, and they work great. They come as a complete kit, wiring, controller, and even grip adhesive.
Tony
1997 Yamaha Seca II - mostly stock, Racetech upgraded forks, FZ6R rear shock, Oxford Heated Grips, Barkbusters Blizzard Handguards, a Scottoiler vSystem chain oiler. My Mileage Tracker Page.
TonyKZ1 is offline   Reply With Quote
Old September 23rd, 2013, 10:45 PM   #4
Fly'in Ninja
Motorcycle(s): C-250R-ST
No heated grips over here...I'm using heated gloves and jacket liner. Works great, extends the riding season.
Fly'in Ninja is offline   Reply With Quote
Old September 24th, 2013, 05:49 AM   #5
caineroad
caineroad's Avatar
Which jacket liner you using? I like to buy one as well
Old September 24th, 2013, 06:05 AM   #6
dfox
dfox's Avatar
Motorcycle(s): 08 250R
I have HotGrips and have been using them for the past few weeks (low 40's in the am).
Last year I rode in temps in the low 20's with the heated grips and insulated motorcycle gloves and had no issues.
I definitely recommend the HotGrips ones. I enjoy the thicker grips compared to stock, and they heat up quick and get HOT on full power. They're well made.
I did not want to spend hours running the wiring, soldering connections, hiding wires, installing fuses/relays, etc. to install a piece of garbage $5 set of heaters that I wouldn't appreciate. If you're going to do it, do it the right way.
I also got a factory looking slide switch to replace the cheap ass toggle switch. I've gotta remember to take a picture of it at some point.
dfox is offline   Reply With Quote
DIY - Hot Grips Heated Grips Install NathanF 2008 - 2012 Ninja 250R Farkles 26 January 23rd, 2014 03:37 PM
tried these heated grips? smackenz 2008 - 2012 Ninja 250R Farkles 7 October 17th, 2012 03:11 PM
heated grips bhalv 1986 - 2007 Ninja 250R Farkles 10 January 17th, 2011 09:39 PM
Heated Grips sudadoda 2008 - 2012 Ninja 250R Farkles 7 May 4th, 2010 07:15 AM
