Old December 7th, 2010, 06:17 PM   #1
bhalv
Motorcycle(s): 93 ninja 250
heated grips
anyone got recommendations as far as heated grips for my 93 ninja? finally getting cold enough that they are starting to become a necessity.
bhalv is offline   Reply With Quote
Old December 7th, 2010, 07:00 PM   #2
DR1300R
DR1300R's Avatar
Motorcycle(s): 2000 Hayabusa 2009 Ninja 250R
This is what i have on the Busa, they work decent for the money..
http://www.dual-star.com/index2/Ride..._grip_kit1.htm
I have heard that Hot Grips are supposed to be real good, although pricey..
http://www.hotgrips.com/
DR1300R is offline   Reply With Quote
Old December 7th, 2010, 07:26 PM   #3
greg737
Motorcycle(s): -
I've got HotGrips on my 2005. I love them.
I installed them with the standard "Off-Low-High" three position switch. Every once in a while I feel that something between Low and High might feel better so I've considered installing the continuously-variable pulse width modulated power controller so I can fine-tune the heat. Haven't gotten around to that mod yet.
I guess it's because most of the time I'm just insanely happy with them as they are.
Old December 7th, 2010, 07:44 PM   #4
bob706
bob706's Avatar
These are the ones I have - http://www.rockymountainatvmc.com/pr...FamilyId=23097
Old December 7th, 2010, 11:25 PM   #5
bhalv
which model did you get if you remember, trying to figure out exactly which one i need to order
Old December 12th, 2010, 06:08 AM   #6
KTRacing38
2010 250 Cup Champion
KTRacing38's Avatar
Motorcycle(s): 2008 Ninja 250R and 2007 Honda CR150F
I've tried several different brands over the years that I've had bikes. Out of all them, the Hot Grips ones are the best. I LOVE them! They were super easy to install and they have different heat settings - I found that most of the time 30% is enough, but it's nice to have more choice than off or on. I got mine off of ebay. Here's a link to the seller that I bought from. Delivery was quick and I had no problems.
http://cgi.ebay.ca/ws/eBayISAPI.dll?...m=400179016216
KTRacing38 is offline   Reply With Quote
Old December 12th, 2010, 07:16 AM   #7
Foreigner
Foreigner's Avatar
Hey Brent I have a couple of questions. How cold is it out there? How long will you be riding daily?
Reason I ask is that my personal experience with heated grips is that they definitely help, but the outside off my hand still freezes when it gets anywhere below -6 degrees celcius, and I'm riding at speed for any length of time. I switched heated grips for heated glove liners. I use the Gerbing's glove liners with Rev'It! Kelvin gloves. Not a cheap investment, but at least my fingers are nice and toasty all around (sometimes roasting!).
If you'll be riding for long stretches at very cold temps, I'd go for the heated gloves/glove liners. Otherwise, HotGrips are for you
wanderlustonwheels.com
Foreigner is offline   Reply With Quote
Old December 12th, 2010, 09:00 AM   #8
bhalv
worst it gets here is 10 Fahrenheit but part of my commute involves a 70+mph freeway section and that's the part that sucks the most
Old December 14th, 2010, 02:24 AM   #9
Foreigner
Foreigner's Avatar
Wow I just checked and that's pretty cold! Considering the type of riding you do, I'd look into heated gloves. The benefit is you can use them on any bike with a 12v battery with no problem, and you don't have to physically alter the bike to do it (like ungluing and removing the stock grips).
Old December 24th, 2010, 10:07 AM   #10
Firebrick
Motorcycle(s): 2005 ninja 250
I was looking into the aerostich velcro ones that go over your grips so I could move it between bikes. Anyone ever used this type?
Firebrick is offline   Reply With Quote
Old January 17th, 2011, 09:39 PM   #11
SV_Hadder
Motorcycle(s): 2001 Ninja 250
I have a set of heated grips on my bike, just the simple kind that you wrap around the handlebar. I have noticed that the bar end weights get pretty warm, obviously wasting some of the heat from the grip heaters, so that got me to thinking... what if you stuck the adhesive side of the heating element, to the inside of the rubber grip? Would it be more effective? I'm thinking of giving it a shot.
"Nicole" - Pirelli Diablo's front and rear, Two Brother's Exhaust, Apex Custom SS lines , 15 T, UNI Air filter, Fiamm El Grande horns, EX500 fork springs, EX250J rear shock, Fender eliminator.
SV_Hadder is offline   Reply With Quote
DIY - Hot Grips Heated Grips Install NathanF 2008 - 2012 Ninja 250R Farkles 26 January 23rd, 2014 03:37 PM
Anyone using heated grips? caineroad General Motorcycling Discussion 5 September 24th, 2013 06:05 AM
tried these heated grips? smackenz 2008 - 2012 Ninja 250R Farkles 7 October 17th, 2012 03:11 PM
Heated Grips sudadoda 2008 - 2012 Ninja 250R Farkles 7 May 4th, 2010 07:15 AM
