September 8th, 2011, 07:07 PM | #1 |
ninjette.org Tengu
Join Date: Jun 2011 Motorcycle(s): Kawasaki Ninja ZX6R Posts: 256
Set Me Straight on 13T Front Sprockets
Okay, here's the skinny:
I want to run some combination of aftermarket sprockets for my '11. I can't seem to get any answers on whether or not shimming for a 13T front is either: 1) Mandatory 2) Highly recommended Can someone please set me straight. I should note that this bike is intended for the track.
Outlander Systems YouTube Channel Outlander Systems Facebook Page |
September 8th, 2011, 07:18 PM | #2 |
Ridin Dirty
Join Date: Jun 2011 Motorcycle(s): 2011 white se 250r , 2008 zx6R Posts: 921
when i attempted to do 13t the info i got is yes.. because they dont make a 13t for the 08+ so you need to buy one for a pre gen and they require a shim supposedly.. dont go off amazon 13t either, when i googled 13t sprocket for the 250 the main one to buy is through amazon, well it doesnt even fit the 250..it was for a honda or something, part #'s are all mixed up. go to jt sprockets site and get the part# there.. only place i found to get one was the dealer had to order it from jt.
#1 |
September 8th, 2011, 07:37 PM | #3 |
ninjette.org Tengu
Thanks for the info. Below is what I've got lined up. I just need to find a source for the shim.
http://www.sprocketcenter.com/p/8515...aki-ex250.html
September 8th, 2011, 07:40 PM | #4 |
Ridin Dirty
If you search I just had a thread on 13 t sprockets. The shim I was told to use is in that thread. It's a inner transmission washer that fits the shaft the sprocket goes on. Believe you can get from bike bandit.
#1 |
September 8th, 2011, 07:51 PM | #5 |
Ridin Dirty
Here's the thread the info is in. http://www.ninjette.org/forums/showt...front+sprocket
#1 |
September 8th, 2011, 08:03 PM | #6 |
ninjette.org Tengu
And you, Sir, are most awesome. Thanks, dude!
September 8th, 2011, 08:04 PM | #7 |
Ridin Dirty
Np.. let me know how it works out cause I still may try a 13t out.
#1 |
NEW PitBull 13T Front Sprocket for 250r / Ninja 300 | 1ER6F | Motorcycle-related | 6 | July 11th, 2014 11:16 PM |
New front and rear sprockets for 1990 2007 Ninja 250 | Agustin | Motorcycle-related | 1 | June 5th, 2012 08:40 AM |
13t front sprocket | greatwhiteninja | 2008 - 2012 Ninja 250R Tech Talk | 14 | August 3rd, 2011 09:35 AM |
Front & Rear Sprockets Q! | ScorpionNinja | 2008 - 2012 Ninja 250R Tech Talk | 0 | May 21st, 2010 01:08 PM |
In the market for sprockets to increase fuel economy. 15T front, ?? rear? | CZroe | 2008 - 2012 Ninja 250R Tech Talk | 40 | March 11th, 2010 01:30 PM |
