Old July 9th, 2021, 11:54 AM   #1
jjmaine
Motorcycle(s): '05 Ninja 250, '16 Ninja 300
Easy fork oil change without removing forks?
I am wondering if it is possible to change the fork oil without removing the forks from the bike? With my dirtbike that has (I believe) the same style damper rod forks, it is possible to just remove the front wheel and then take out the damper rod bolts and let the oil drain. Once it has drained, put the bolts and everything back, measure the oil you took out and replace the same amount.
Has anyone done it this way and is it possible to do? I'm putting in new Racetech springs and I know that I also need heavier weight oil but do not feel like getting into to much disassembly right now.
Of course the correct way would be to remove the forks but who wants to do that?
jjmaine is offline   Reply With Quote
Old July 9th, 2021, 08:27 PM   #2
SibSerge
If you want to skip cleaning them inside I do not see why cannot you do that. Moreover I think you can suck most of the oil out through the top if you have a pump. This way you can just open the top, take the spacer, washers and the spring out and you should be able to put a tube almost all the way down through the hole in the rod.
Old July 10th, 2021, 05:37 AM   #3
Of course one of the reasons for changing the oil is to get the solidified sludgy stuff out.
Old July 10th, 2021, 08:56 AM   #4
jjmaine
That's a good idea and even easier than removing the damper rod bolts. I can use a large syringe and a length of tubing to remove the old oil. Thanks!
Old July 10th, 2021, 09:00 AM   #5
jjmaine
I get that for sure. Since I'm in Maine and my bikes sit all winter (maybe 5 months), I like to do all of the major maintenance then. I work construction as well so I have much more down time in the winter to get these things done. I just got the bike and it is 5 years old I am betting that the fork oil has never been changed so I'm thinking just do what I can to quickly get some fresh oil in there for the season and this winter I'll take the forks off completely and clean them properly.
Jim, are you familiar with Bruce's Suspension in Salisbury NC? He worked over the damper rods for my dirtbike forks and was thinking about asking him to check out my Ninja 300 damper rods. His damper rods in my dirtbike work much better than the gold valve emulators and I'm betting he could work his magic on these forks as well. If he was willing...
Old July 10th, 2021, 10:49 AM   #6
I'm not familiar with him, but it sounds like he'd be looking into, thanks.
Old July 10th, 2021, 02:45 PM   #7
jjmaine
Yeah, I'm sure he could improve these forks. He does mostly off road suspension but he is a wizard with damper rod forks. To be honest, I like to take it easy and generally do the speed limit so for me some fresh oil and the correct springs will do the trick for now. Maybe this winter I'll see about upgrading my forks and shock.
Old July 11th, 2021, 01:49 PM   #8
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
On the 500, you could drill and tap a hole for a drain bolt without disassembling the forks. http://web.archive.org/web/201804272...rk_Drain_Screw The NewGen/300 forks aren't identical, but should be pretty similar.
Old August 6th, 2021, 08:02 PM   #9
Topaz
Topaz's Avatar
Hey @jjmaine How did the forks oil and springs change go? Did you pull out the forks? Or syringe the oil out?
I tried the syringe and managed to pull out a bit over 200ml of oil from each fork. Not sure if pour the new oil as it is or to pull out the forks and turn them upside down.
Old August 7th, 2021, 05:06 AM   #10
Topaz
Topaz's Avatar
The instructions on the new springs indicate an oil level of 20mm higher than the stock. Why is this oil level change?
Old August 7th, 2021, 07:26 AM   #11
More oil = less air = effectively higher spring rate, because with less air space, the air pressure rises faster as the suspension is compressed. For the same reason, less air also can prevent bottoming of the suspension.
Old August 7th, 2021, 10:33 AM   #12
Topaz
Topaz's Avatar
Thanks Jim!
The syringe method doesn't seem to be very good. After looking at this diagram from RaceTech
https://www.racetech.com/page/title/...%20They%20Work
you can tell that there is a significant space below the rod that cannot be reached with the syringe, so I pulled out the forks.
Damn! A drain plug in the bottom seems like a great idea. Why don't they do it?
I had to remove the clip ons, the caliper, the wheel, the fender and a 6 bolts bracket that squares the forks and holds the fender.
I had been able to pull out 500ml of oil per fork with the syringe. Then I pulled out about 60ml more from each fork by turning the forks upside down. Around 10%, so not sure if it's worth. In this case, the oil was from 2013, 8 years old, so I wanted to pull out as much as possible.
After re installing the forks, wheels, fender, and bracket I realized I had the wires and cables of the right side clip-on on the wrong side of the fork tube, so I had to take it all apart again. What a j#rk! Pay more attention next time.
I brought down the front end 8mm. Pretty much all I could bring it down without having the fairing touching the fender if the forks bottom out. Anyways, at 150 lbs and with stiffer springs, I doubt I will be bottoming out the forks.
Old August 7th, 2021, 03:46 PM   #13
jjmaine
I just decided to replace my springs for now and this winter I figure Ill take the forks off and change the oil completely. I'd say it's up to you whether you want to just replace what you took out or take the forks off all the way and make sure you get it all. I guess the right way would be to do a good job but I was just trying to squeek by until the riding season is over here in Maine...
Old March 19th, 2022, 09:08 AM   #14
jjmaine
I never did get around to replacing the springs but plan on it now since spring is almost here. I am wondering what weight fork oil you guys recommend for me? I have .80kg Racetech springs to put in and was thinking about 12.5w oil? I’m 185lbs with no gear and just average street rider…
Old March 19th, 2022, 11:38 AM   #15
I'm similar, originally was 195-lbs with gear and used 0.90kg/mm springs from Racetech with 15wt oil.
This winter I'm down to 180-lbs with gear and went to 0.80kg/mm springs with same 15wt oil. Used slightly lower oil level since previous setting was slightly "springy" at higher compression amounts.
Both of these on lightened race-bike. For street riding, you'll be fine with what you've got. Can adjust preload and oil-level as needed.
Old March 23rd, 2022, 03:57 PM   #16
jjmaine
Thanks Danny!
Old April 7th, 2022, 06:43 AM   #17
jjmaine
Racetech’s instructions are vague. For those that upgraded fork springs did you start by making the new spring/spacer the same length as the oem spring/spacer to keep the same preload and then adjust with washers as needed?
Old April 7th, 2022, 07:09 AM   #18
Kinda, new spring + new spacer needs about 5mm less total length than stock due to higher rate and less sag. Then I added these nifty pre-load adjusters: https://www.ebay.com/itm/144407494866
Old April 7th, 2022, 07:45 AM   #19
jjmaine
Thanks! I’ll have to adjust my preload with washers because I prefer the stock handlebars. I have a set of woodcraft clip-ons and did not like the hunched over feel and for my everyday riding being more upright is the ticket.
Old May 21st, 2022, 01:56 PM   #20
jjmaine
Hey Danny, good advice on using 5mm less preload than oem. First I tried making the new spring/spacer the same as stock and it was very harsh and not enough sag. I took off 5mm and now have about an inch static sag but when riding at a good pace on the street I am only using another 2” of fork travel. Does this mean I can take a few more mm off the spacer for a plusher ride? For me it os all about comfort and soaking up the bumps as much as possible but want to keep somewhat correct sag as well. I also used 15w oil but think when I have my tires off to change them I will go down to 10w oil.
Old May 21st, 2022, 02:19 PM   #21
jjmaine
I have 44mm of front race/rider sag. That sounds good for a slow street rider like me I think?
Old May 21st, 2022, 05:36 PM   #22
Should be good for now.
[visordown.com] - How to… change your fork oil Ninjette Newsbot Motorcycling News 0 July 19th, 2017 03:41 AM
Can I measure fork oil while the forks are installed? daverdfw Ninjettes At Speed 13 February 8th, 2016 10:30 PM
Front fork oil seal change... ManOfGod 1986 - 2007 Ninja 250R Tech Talk 17 April 20th, 2013 07:54 PM
Fork Oil change, Yay or Nay?? LoneRonin 2008 - 2012 Ninja 250R Tech Talk 6 April 3rd, 2013 08:16 PM
Front fork oil change GregK 2008 - 2012 Ninja 250R Tech Talk 5 June 18th, 2012 11:19 PM
