Old August 7th, 2014, 04:22 PM   #1
mmiles19
Motorcycle(s): 2006 Kawasaki Ninja 500
Another stuck gas cap! HELP! :)
Yep guys, another post about a stuck gas cap. I feel like I've tried everything and I just cannot get it open. I've taken it to two locksmiths and consulted my local Kawasaki dealer with nothing! I've BATHED this thing in lubricants and it will just not go. The key goes about halfway around until gets to the little dot in the middle of the arrow but won't go any further. I'm on the verge of just drilling the thing out. Any ideas?
I've looked at other posts and tried to do what they recommend but nothing is working.
This is as far as it will turn:
http://imgur.com/EQLSGvl
http://imgur.com/imo0Og7
http://imgur.com/J8B5H9W
Sorry if the quality is bad :/ I can upload more later if you want.
TIA
mmiles19 is offline   Reply With Quote
Old August 7th, 2014, 05:22 PM   #2
Ninjinsky
Ninjinsky's Avatar
Be sure to press the cap down as you turn the key, The corroded sticking point is down in the latch part not the key. And, animal as it sounds, whack the cap with the ball of your fist a few times before trying again.
When you do get it open (you will eventually ) take out the last screw which is under the cap and throw it away. That way you can always remove a stuck cap with the allen screws if it sticks again
Last resort: If you have another bike to compare it to you could drill the cap right above the "security screw" and undo it through the hole (hand drill obviously to avoid sparks)
Last futzed with by Ninjinsky; August 9th, 2014 at 01:57 AM.
Old August 8th, 2014, 09:39 PM   #3
jschorr
jschorr's Avatar
Motorcycle(s): 1995 ninja 250r
and if...when you get it open strip down the cap and grease it up good so it doesnt happen again.
the instructions are on here somewhere.
jschorr is offline   Reply With Quote
Gas Tank Lock stuck? Maintenance for gas cap with pics! Skippii 1986 - 2007 Ninja 250R Tech Talk 35 May 6th, 2021 09:03 PM
Stuck at the gas station. Dies when giving throttle spc2125 1986 - 2007 Ninja 250R Tech Talk 29 May 19th, 2016 08:23 PM
Best Keyless gas cap? Indetrucks 2008 - 2012 Ninja 250R Tech Talk 8 May 22nd, 2014 09:06 PM
Gas cap massacremasses General Motorcycling Discussion 19 January 6th, 2012 01:08 PM
