Old May 5th, 2009, 03:58 PM   #1
Apex
Livin' the Minimoto Life
Apex's Avatar
Valve adjustment
Just curious how long this takes. I've done V8 motors before, but I was needing to know how long it takes you to do the whole thing. I want to make sure I set aside enough time to get it done during a weekend. I also plan on getting some stands so I can easily do the whole swingarm maintenance and tire changes on my own.
I think a trip to Sears is in order for a jack and to the dealer for a rear/front stand.
Once I get those, I'll be kissing the centerstand goodbye.
Old May 5th, 2009, 04:19 PM   #2
I'd PM dotsony; from this thread it seems he learned some things that he'd do differently the next time he adjusts the valves.
Old May 6th, 2009, 08:10 AM   #3
beowuff
beowuff's Avatar
The first time I did the valves, I took 2 days. The first day, I took the bike apart. The second day I did the valves and then synced the carbs.
I could do it in a day, but I like being fresh when doing the valves.
Since you've done valves before on a V8, you'll probably breeze right through them.
If you have the whole weekend, you should have more then enough time. Don't forget to sync the carbs afterward!
beowuff is offline   Reply With Quote
Old May 7th, 2009, 07:14 AM   #4
Apex
Apex's Avatar
I need to get the kit to sync them. Maybe I'll head to the dealer later on this week to pick it up.
Old May 7th, 2009, 07:29 AM   #5
beowuff
beowuff's Avatar
I made my own sync tool from the directions at:
http://faq.ninja250.org/wiki/How_do_...carburetors%3F
It's called the "Two Bottle Method".
It's real easy to make. The only hard part for me to find were the hard rubber stoppers, but I finally found them here:
http://www.mclendons.com/
There should be a place similar to that around you if your not near one.
Old May 9th, 2009, 05:15 PM   #6
squishedworm
Motorcycle(s): 2007 Kawasaki Ninja 250
You should be able to take everything apart, check/adjust the valves, and put everything back together in less than 2 hours. If you have the valve adjustment tool, don't take a lot of breaks, and don't drop anything in the engine, expect it to take considerably less amount of time.
squishedworm is offline   Reply With Quote
Old September 1st, 2009, 07:53 AM   #7
RichJ
RichJ's Avatar
Motorcycle(s): 92 250 ninja, 77 KZ650 modded. 89 650 Hawk, 03 Honda 919
Here's a shot of the valve adj tool I threw together when I realized that I couldn't do it with out one. a 1/4 dr socket a piece of flat stock and a little heat.
I also took some 8-32 thumb screws filed them till they fit in the air adj screws and soldered them together. Can't find the completed pic but I can adj them with out the need for a screwdiver.
Later
Rich
RichJ is offline   Reply With Quote
Old September 1st, 2009, 05:53 PM   #8
nate-bama
North Alabama Mtn. ryder
nate-bama's Avatar
Motorcycle(s): 2006
good work
QTRltrPWR
nate-bama is offline   Reply With Quote
Valve Adjustment quarterliter 1986 - 2007 Ninja 250R Tech Talk 7 June 25th, 2013 05:32 PM
Valve adjustment ?s Jewtoys 2008 - 2012 Ninja 250R Tech Talk 5 August 1st, 2012 08:47 PM
valve adjustment little fish 1986 - 2007 Ninja 250R Tech Talk 8 November 4th, 2011 10:10 AM
Valve Adjustment-Really Tight adjustment screw? mikesova 1986 - 2007 Ninja 250R Tech Talk 5 May 2nd, 2010 04:57 AM
anyone want to help with a valve adjustment? diablo250 Group Rides and Local Events 2 March 28th, 2010 02:00 AM
