April 10th, 2013, 04:14 PM | #1 |
Join Date: Apr 2013 Motorcycle(s): 2004 Ninja 250 Posts: 465
Hayabusa Lowering Links?
I found some info on using busa links to raise the rear of the bike up. Has anyone actually done this? The links are actually really cheap like 20 bucks but just wanted to see if this was a direct bolt on in the stock location before I purchased them.
April 11th, 2013, 10:21 AM | #2 |
I don't know. But I'm about to research the hell out of it. I'm 6'2" and I can't get my ass high enough to get my foot position right when I'm tucked down, so this would be good. It's to my understanding that an sv650 shock might raise the tail but I haven't done it myself yet, so don't take that as truthfact.
April 11th, 2013, 10:26 AM | #3 |
http://item.mobileweb.ebay.com/viewi...id=97778773394
There's a thread around here somewhere that has all the part sources to build some links like these, but I can't find it. When I do I'll post the link up. http://www.ninjette.org/forums/showt...=Shorter+links Or you could buy these from Rexbo? I think I might |
April 11th, 2013, 10:41 AM | #4 |
sail away
Join Date: Jul 2012 Motorcycle(s): gixxer (sold), ninjette (upgrade!) Posts: 964
@!!(0_o)!! If you raise the rear of the bike don't the foot pegs come up with it? I think what you are looking for are adjustable rearsets.
Unregistered found this post helpful. Track Day Preparation Checklist 1. Financial 2. Mental 3. Physical 4. Gear / Bike |
April 11th, 2013, 10:49 AM | #5 |
Hmm.. Now that I think think about it, you're right.. Ah well I could still use the raised seat height. I doubled up the foam when I recovered the seat and I still have my feet flat and my knees bent at stop lights. I've also been riding liter bikes my whole cycling career so I might just need to adapt to that.
April 11th, 2013, 10:57 AM | #6 | |
sail away
April 11th, 2013, 11:05 AM | #7 |
Que Buenos Son!!!
MOTM - Nov '14
Just to let you know. I've got a shock from an '08 250 on my pre-gen. It did raise the rear some, though I'm not sure exactly how much, plus it's a nice upgrade. I did have to raise the forks as much as I could, because the raised rear end was hurting my wrists.
And yes if you raise the bike you also raise the footpegs, but that just means you can lean over further without scraping.
April 11th, 2013, 11:06 AM | #8 | |
Jigglin' your Jiglets
MOTM - Apr '13
April 11th, 2013, 11:14 AM | #9 |
Nah. I'm only 5'9" and have long legs. I raised my tail about 2.5 inches, and I still have a little bend in the knee when I flat-foot.
To add to the thread: I'm not sure if Rexbo's links or busa links will work on a pregen or not. I use custom length adjustable links from Soupy's Performance that allow me to go everywhere from stock height to 4 inches up. They're pricey, but well worth it. The adjust-ability is a very good thing because then I can adjust to keep the geometry the same with any tires that I use. I also can lower if if I go too high and start getting speed wobbles. So far, no issues; not on the street, not on the track. Just don't forget, when you raise the tail, the bike carries more weight on the nose. You'll notice bad front suspension more. You'll also notice that more roll-on through corners is need to get the same squat on the rear. |
April 11th, 2013, 11:20 AM | #10 |
April 11th, 2013, 11:24 AM | #11 |
It just has preload adjustment. But the shock has more damping because they redid the valving. If you're heavy, this would be a good thing.
Remember that a balanced suspension handles best. If you improve the rear, plan on spending some money to improve the front also. |
April 11th, 2013, 11:26 AM | #12 |
April 11th, 2013, 11:31 AM | #13 | |
April 11th, 2013, 02:35 PM | #14 |
Do you have a measurement from eye to eye on the soupys links that you have installed?
April 11th, 2013, 03:19 PM | #15 |
Nope. Sorry. And they're almost 3 hours away from me so I won't be able to measure them.
April 11th, 2013, 05:34 PM | #16 |
Okay I understand. Well if u get a chance sometime it would be well appreciated. I could probably make a set for myself outa steel stock if I had dimensions.
April 11th, 2013, 06:51 PM | #17 |
Will do. I'll be home Mid-May. If you haven't gotten yours made by then, let me know on here and I'll remember to measure them for you.
April 12th, 2013, 08:30 AM | #18 |
Alright thanks will do.
April 12th, 2013, 08:33 AM | #19 |
Info on the stock dogbone length:
http://faq.ninja250.org/wiki/Are_the...ng_the_bike%3F Do some measuring of your bike, then do some trig to find out how much shorter your dogbones should be. Or just ask Rexbo how long his are |
lowering links | ninjoe | 2008 - 2012 Ninja 250R Tech Talk | 0 | March 22nd, 2011 02:46 PM |
DIY: Lowering the back with Roaring Toyz lowering links | noche_caliente | 2008 - 2012 Ninja 250R Tech Talk | 49 | July 26th, 2010 12:22 PM |
hayabusa lowering links for 09 ninja 250 | magic_desi | 2008 - 2012 Ninja 250R Tech Talk | 0 | June 4th, 2010 09:44 PM |
