Old February 28th, 2012, 07:13 PM   #1
StaylorT
Motorcycle(s): Cbr 125, Ninja 250
Koso Oil Temp Sensor Adapter & Water Temp Sensor Adapter
Hi everyone.
This is my first post on Ninjette, although Ive been creeping the threads for a while now.
Ive looked around for the answer to this, but Ive seen a couple different answers...And i really need the RIGHT and FINAL answer to my question as im going to install my gauge soon.
WHAT ARE THE CORRECT SIZES FOR;
Koso Water Temp Sensor Adapter and
for 2011 ninja 250
THANK YOU ALL
StaylorT is offline   Reply With Quote
Old March 3rd, 2012, 10:37 AM   #2
I'm not sure (I don't have a Koso), but have you looked through the Koso DIY's here, and the information isn't there? If not, I hope this thread gets some views and the right answers soon.
Old March 3rd, 2012, 10:41 AM   #3
StaylorT
Yeah, I checked the DIY and some other places. No one had an exact answer. So I just got a whole new P&P kit off ebay that includes the sensor adapters for the 250. The whole Kit costs less then the individual sensors from the koso site anyways... im planning on just trying to resell the digital gauge harness after, hopefully ill make some money back.
Old January 22nd, 2014, 09:28 PM   #4
chugs
Schönen Tag noch
chugs's Avatar
Motorcycle(s): 08 ninja 250 race bike, 02 gixxer 600 telefonica
Any updates to determing the correct size adaptors?
chugs is offline   Reply With Quote
Old January 22nd, 2014, 10:16 PM   #5
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
I had to replace the oil temp sensor (aluminum breaks too easy) and this is the part I got that fits my 2012. Hope this helps.
M12 x P1.5 Oil Temperature Sensor - BF120125 Part #408517
<-- Linky
Old January 22nd, 2014, 10:50 PM   #6
linkinpark9812
Motorcycle(s): Black 2012 Ninja 250R
What gauges? I have this water temp gauge: http://www.ebay.com/itm/like/380774278868?lpid=82
The sensor that comes with, IIRC, directly fit into the stock port of the Ninja's Stock temp sensor.
BTW, I am doing a custom gauge set up. NevadaWolf, are you saying that is the thread size for where the stock oil pressure sensor goes? I am unsure of that size thread.
linkinpark9812 is offline   Reply With Quote
Old January 22nd, 2014, 11:24 PM   #7
NevadaWolf
NevadaWolf's Avatar
@linkinpark9812 that's the sensor that takes the place of the stock oil drain plug on the bottom of the bike. Unfortunately, i don't know where the stock oil pressure sensor is.
The original one i had came with the Koso RX-2 that i have. Koso sells the blue bolt that has a hole in it to screw the copper sensor into.
The replacement I got was all one piece.
<-- Linky
Old January 22nd, 2014, 11:43 PM   #8
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
The sensor that comes with the RX2 is the BF030125 (Size: PT1/8x28) and the best way to mount it to your Ninja is to buy the bolt from the oil pressure switch (Kawasaki oem-no. 92002-1427). So you can put it in the main oil line (sorry don't know the right word in english) and never have to take it off for oil changes. When you mount it don't forget the teflon tape because otherwise it's leaking and water and oil is the same sensor.
Old January 23rd, 2014, 04:16 PM   #9
chugs
Schönen Tag noch
chugs's Avatar
Thanks for the replies, I found all the info needed via this pdf install file.
https://www.denniskirk.com/dk/pdf/in...0/dk408817.pdf
water temp adpator: size 22mm
http://www.kosonorthamerica.com/koso...ensor-adaptor/
oil temp sensor adaptor: size m12 x p1.5 x 15L
http://www.kosonorthamerica.com/koso...re-adapter-22/
sensors are the same for both: size p1/8 x 28
http://www.kosonorthamerica.com/koso...ure-sensor-50/
Old January 23rd, 2014, 11:39 PM   #10
linkinpark9812
That oil temp sensor adapter, is "m12 x p1.5" the size of the threads on the bike?
If so, is that one of the 2 oil drain plugs on the bottom of the ninja or is that the size for where the stock oil pressure switch goes?
Old January 24th, 2014, 12:38 AM   #11
chugs
Schönen Tag noch
chugs's Avatar
The adaptor plug replaces the drain plug so they are the same size.
Oil and Water Temp Agger 2008 - 2012 Ninja 250R Tech Talk 2 March 18th, 2012 07:12 PM
WTB: Pre-Gen Water Temp Sensor!! bluebr65 Items Wanted 3 January 5th, 2012 09:45 AM
WTB 08+ Water Temp Sensor charri Items Wanted 0 July 26th, 2011 07:05 PM
Where is the water temp sensor? wild-bill 2008 - 2012 Ninja 250R Tech Talk 2 December 24th, 2010 10:32 PM
How to test coolant temp sensor? Togglehead 1986 - 2007 Ninja 250R Tech Talk 1 July 21st, 2010 03:50 PM
