Old May 29th, 2012, 05:26 PM   #1
mxman38
Motorcycle(s): 2012 250
DJ Needles instead of shimming
i just bought a dyno jet kit... but the more i research the more i think i might just shim my bike. it idles and starts off choke.
I was going to try one washer, but can i just swap my stock needle with my DJ needle and put the E clip on the third groove? Or does that mean i have to re jet the mains if i switch needles?
im thinking the 12's might have had some revision, because it has a smooth power band without any hesitation.
mxman38 is offline   Reply With Quote
Old May 29th, 2012, 05:58 PM   #2
stock jetting is pretty smooth. lacks top end power though. you can swap needles just fine, and the clip on those needles is equivalent to adding washers. slight difference would be the needle taper but you're getting into very tiny differences in effect at that point. even with a stock exhaust you can rejet to get better performance, but a full pipe with a proper jetting will get you the best bang
Old May 29th, 2012, 06:22 PM   #3
mxman38
yeah, i have the kit, i really dont want to rip the whole carb out...
stock is 96 correct? so i might just do the third clip and move to a 98 main... idk what the drill bit is for though.
I feel that all i need is a slightly richer setting... i did the 15t front sprocket so i think thats why i feel like my bottom end power is lacking, the bike runs perfect though.
Old May 29th, 2012, 06:54 PM   #4
mkulchar
mkulchar's Avatar
Motorcycle(s): 2010 250r ninja
I believe that stock is 98
mkulchar is offline   Reply With Quote
Old May 29th, 2012, 06:57 PM   #5
Hoodie Ninja
Motorcycle(s): 2011 Ninja 250R Special
I'm all sorts of confused now from reading this thread. Do you still shim even with the DJ kit? Stupid question, but I thought I would ask.
Hoodie Ninja is offline   Reply With Quote
Old May 30th, 2012, 01:41 PM   #6
HKr1
IC2(SW)
HKr1's Avatar
The DJ kit comes with two washers per needle. Thats so you can do fine adjustments of the needle, instead of a large clip change.
Old May 30th, 2012, 07:05 PM   #7
Hoodie Ninja
Got it, that makes more sense.
Old May 30th, 2012, 07:09 PM   #8
EsrTek
EsrTek's Avatar
Motorcycle(s): '13 300
Correct but stock is a Kehlin (or something like that).
However that does equate to a DynoJet 96 main (correct me if wrong, that's what I was told).
Shimming the Carb Needles... Is it for You? kkim 2008 - 2012 Ninja 250R Tech Talk 93 June 10th, 2018 05:25 PM
Shimming the carb needles kfilla General Motorcycling Discussion 2 July 2nd, 2014 06:14 PM
Shimming same with Jetkit Needles? vmax 2008 - 2012 Ninja 250R Tech Talk 4 August 1st, 2013 11:49 PM
Shimming Needles @ NYC keeyu 2008 - 2012 Ninja 250R Tech Talk 25 August 17th, 2010 12:14 PM
Shimming the needles question Tubesock 2008 - 2012 Ninja 250R Tech Talk 20 August 15th, 2009 12:17 PM
