Old November 30th, 2013, 01:44 PM   #1
starhobos
Motorcycle(s): 2012 ninja 250r
need help with cam timing ninja 250
I checked my valves they are in spec. I forgot to check what the timing was before I took them off I cant find it on the internet or other threads that were previously posted. Not sure if the pics are helpful but in the position I have them in one valve hits the piston a nd stops. This is a 2012 250 with 12000 miles first time the valves have been checked.
starhobos is offline   Reply With Quote
Old November 30th, 2013, 02:09 PM   #2
Originally Posted by starhobos View Post
........Not sure if the pics are helpful but in the position I have them in one valve hits the piston and stops................
Welcome to our site, Matt !!!
Position the crankshaft at #2 piston TDC (there are two turns of the crankshaft for each turn of the camshafts).
CAUTION
The crankshaft may be turned while the camshafts are removed.
Always pull the chain taut while turning the crankshaft.
This avoids kinking the chain on the lower (crankshaft) sprocket.
A kinked chain could damage both the chain and the sprocket.
Old December 2nd, 2013, 09:13 AM   #3
TonyKZ1
TonyKZ1's Avatar
Motorcycle(s): 1975 Kawasaki KZ400D (Sold), 1989 Kawasaki Ninja 250 (sold), 1997 Yamaha XJ600s Seca II
One question comes to mind though, why did you remove the cams if the valves were in spec? Anyhow the above diagram should help get it back together correctly.
Tony
1997 Yamaha Seca II - mostly stock, Racetech upgraded forks, FZ6R rear shock, Oxford Heated Grips, Barkbusters Blizzard Handguards, a Scottoiler vSystem chain oiler. My Mileage Tracker Page.
TonyKZ1 is offline   Reply With Quote
Old December 3rd, 2013, 02:33 AM   #4
tubarney
Not good. Take the cams out right away.
Old December 3rd, 2013, 02:33 AM   #5
tubarney
If it ticks on start-up shut it down straight away.
Old December 23rd, 2013, 01:42 PM   #6
OP - did you get this sorted out?
replacing exhaust cam with intake cam subxero 2008 - 2012 Ninja 250R Tech Talk 2 June 1st, 2014 12:19 PM
ninja timing/no start help beenselock 2008 - 2012 Ninja 250R Tech Talk 13 September 22nd, 2012 05:15 PM
cam timing verandaman 2008 - 2012 Ninja 250R Tech Talk 0 October 12th, 2011 01:27 PM
