Old March 6th, 2014, 08:13 AM   #41
skeelo221
Motorcycle(s): Ninja 250R (race), Aprilia Tuono 1000R, CRF250X, DR650
The motion pro is not as "quick" as the 06+
skeelo221 is offline   Reply With Quote
Old March 6th, 2014, 09:19 AM   #42
psych0hans
psych0hans's Avatar
What are you talking about? Motion pro comes with 4 different diameter inserts... All the way up to 50mm, if that isn't quick, I don't know what is...
Old March 6th, 2014, 09:20 AM   #43
skeelo221
Did you click on his link? He's not talking about the $130+ revolver kit...
Old March 6th, 2014, 09:22 AM   #44
psych0hans
psych0hans's Avatar
Nope, that I did not do...
Old March 6th, 2014, 09:47 AM   #45
Ausoi
Motorcycle(s): 2008 (Black) Kawasaki Ninja 250R
I'm not sure which mine is but it's quick enough, believe me. It's 2x quicker then stock.
Ausoi is offline   Reply With Quote
Old March 6th, 2014, 10:24 AM   #46
skeelo221
Should be same as 05 R6
Old April 7th, 2014, 06:39 PM   #47
stubshaft
Rode with the Dinosaurs..
stubshaft's Avatar
Motorcycle(s): '08 Ninja 250
I got the '05 R6 barrel from flea-bay for $11.21 shipped and installed it Saturday. Definitely a plug and play mod. The part of the conversion that took me the longest was getting the old grip off of the original barrel.
Fortune favors the brave!
stubshaft is offline   Reply With Quote
Old April 25th, 2014, 09:34 PM   #48
abhijitz
Motorcycle(s): Many Two Wheels ..
06+ R6 throttle tube sticks, 05 R6 throttle tube doesnt .. 06+ needs trimming for sure. I currently have 05 R6 which is plug n play.
[ex-AFM #828 | SMUSA #828 |
Sponsors : MotionPro | LeoVince | Insurrection Racing Gloves | QstarZ Laptimers
+ OEM Parts @ 30-40% OFF : Harry @ 1-877-437-1631,17 harry@hondaeasttoledo.com
abhijitz is offline   Reply With Quote
Old June 11th, 2014, 10:30 PM   #49
Olie
New Old Guy
Olie's Avatar
Motorcycle(s): 2011 250R SE
I just put in an 06+ throttle and I did have to trim the tube approx. 1/4" but otherwise it was a simple install. Definitely recommend it.
Olie is offline   Reply With Quote
Old June 11th, 2014, 11:43 PM   #50
psych0hans
psych0hans's Avatar
You need one of these and one of these and you have everything you need to make your own Quick action throttle at half the cost of a motion pro... I use that and I've even zip tied my R6 tube for that additional bite... I'm planning on buying another set of housing and throttle just to see how far I can go.
Old June 19th, 2014, 06:38 AM   #51
soonerbillz
Motorcycle(s): 2003 Ex250
I have a 2003 that I'm setting up for track duty.
I bought the 06 R6 tube and it fit the housing fine. The cables fit the housing like they should and are smooth operating... but... when attaching the cables to the carb everything went together ok after I loosened up the adjusters all the way top and bottom . The problem is that now the throttle will not close all the way. It's smooth and snaps shut but not all the way.. there is almost a 1/4" gap between the idle adjust stop and the tang on the carb...
any ideas?
soonerbillz is offline   Reply With Quote
Old June 19th, 2014, 08:56 PM   #52
soonerbillz
So it turned out the pull cable was too short. Well really it was the cable housing the was too long... I went and peeled the vinyl back, unwound the housing to where I figured was about right and cut it. After much fumbling and cussing I was able to get the cable back into the r6 tube and switch housing and on the clip on. I was pretty lucky and got the cut right on the money and now the throttle works perfect!
Definitely I can say that on the pre gen at least this mod is not a plug and play thing...
Old June 20th, 2014, 06:22 AM   #53
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
so obviously conflicting reports - does the R6 (and if so what year) throttle tube drop in to any of our bikes without modification?
Old June 20th, 2014, 06:39 AM   #54
soonerbillz
And to be honest the 06 r6 tube did not shorten the throttle travel as much as I was hoping.. may end up doing the zip later.. we'll see
Old June 20th, 2014, 01:46 PM   #55
This is my setup... Just buy a Yamaha R6 throttle assembly + Switch gear and a universal throttle kit... Jerry rig the switch gear to work with the current setup and make your custom throttle cable using the kit... Voila...
my latest crash has taught me something important that i really didn't think was that important before: make sure your kill switch is extremely easy to get to with your thumb.
Old June 20th, 2014, 09:10 PM   #56
psych0hans
psych0hans's Avatar
Yeah, this is an issue I genuinely need to address... Will do ASAP. Thank you
Old June 21st, 2014, 12:50 AM   #57
mania
mania's Avatar
Motorcycle(s): 2013 250
The R6 mod works fine on my 2013
I get full throttle without any hand reposition/ re-grab which is all I wanted
pic1- Stock tube
pic 2- R6 tube
pic 3 - Part Number on bag in pic
mania is offline   Reply With Quote
Old June 26th, 2014, 12:52 AM   #58
psych0hans
psych0hans's Avatar
Found this on ebay today... who wants to bite?
Old August 21st, 2014, 06:50 AM   #59
MirinNinja
Motorcycle(s): Ninja 300
When you guys are talking about needing to trim the housing what exactly are you talking about? I just tried installing the 06 tube and can't the throttle doesn't snap back at all.
MirinNinja is offline   Reply With Quote
Old September 6th, 2014, 12:55 PM   #60
redsnapper
redsnapper's Avatar
Name: Red Snapper XXX
Clicking Noise, The source of it.
Did the mod, and spend hours trying to track the clicking noise when I pulled the throttle.
The return throttle cable hole on the R6 tube is bigger than the throttle pull hole.
Just makes a little clicking noise, because it's loose and bangs in the hole when you twist the throttle.
The clicking is annoying, because I can feel it when I twist the throttle. You won't hear it when the bike is on.
If you have any suggestions, please let me know.
redsnapper is offline   Reply With Quote
Motion Pro quick turn throttle rojoracing53 2008 - 2012 Ninja 250R Tech Talk 43 May 28th, 2013 07:18 AM
[sportrider - latest stories] - Yoyodyne Quick-Turn Adjustable Throttle Ninjette Newsbot Motorcycling News 0 December 30th, 2010 01:11 AM
[roadracingworld.com] - Tuesday Video: Installing A Revolver Quick-turn Throttle Kit Ninjette Newsbot Motorcycling News 0 February 23rd, 2010 02:20 PM
[roadracingworld.com] - Monday Video: Installing A Revolver Quick-turn Throttle Kit F Ninjette Newsbot Motorcycling News 0 February 22nd, 2010 02:10 PM
Dan Kyle's Quick turn throttle question Gregular 2008 - 2012 Ninja 250R Tech Talk 7 February 28th, 2009 03:14 AM
