Old July 25th, 2013, 03:56 PM   #1
dvldog0121
Motorcycle(s): 09 Ninja 250R
Fixed the idle, but rev it and it dies
I've used the wiki to do some of the things listed below, but haven't been able to find a fix to this in there (probably user error). So, I submit this to all of you.
Long story short – son had my Ninjette for several months, it sat outside uncovered at an apt. complex where people messed with the bike. He brought it back to me, after he bought a new motorcycle & had let it sit for a few months. When he drove it over, it was revving high, and was very hot. Here’s what we (my DH & I) did to it.
- Changed oil & oil filter
- Replaced air filter
- Replaced spark plugs
- Checked & filled coolant to proper level
- Cleaned the carbs
- Drained gas tank & put in non-ethanol 91 octane fuel
Just before lending this bike to my son, I had shimmed the carb needles with one washer each on the carbs & removed the snorkel. I undid this when we cleaned the carbs (per my DH suggestion).
Now, we have the idle set, and it’ll idle just fine. However, when revved, it’ll die, and seems flooded. Suggestions?
dvldog0121 is offline   Reply With Quote
Old July 25th, 2013, 04:20 PM   #2
Driddle
Driddle's Avatar
I can't help you with the dying, but I must ask why you are running 91
2008 Kawasaki Ninja 250r | Yoshimura Stainless Full Exhaust | Pazzo Levers | Puig Double Bubble | DynoJet Stage 2 | K&N Intake |
Driddle is offline   Reply With Quote
Old July 25th, 2013, 04:25 PM   #3
dvldog0121
It was suggested by the tech where I buy parts from. Normally, I'll just run the 87.
Last futzed with by dvldog0121; July 25th, 2013 at 04:29 PM. Reason: clarification
Old July 25th, 2013, 04:43 PM   #4
Driddle
Driddle's Avatar
There are plenty of threads arguing this on here that you can go look for, but the gist of it is that you only need to run 87.
Running 91 can actually lead to less gas being burned in the combustion part of the cycle. It also will give you less in gas mileage.
But good luck with the rest of the fix
Old July 25th, 2013, 05:04 PM   #5
Flying
Motorcycle(s): 2010 Ninja 250
Just throwing out a guess. I would look over the carb float assemblies and confirm float heights.
Examining all of the inlet/vacuum lines and main jets wouldn't hurt either.
6000 RPM Idle Dies with Throttle garman 1986 - 2007 Ninja 250R Tech Talk 3 August 9th, 2014 01:29 PM
Sluggish rev, erratic idle, dies with throttle Fappy 2008 - 2012 Ninja 250R Tech Talk 12 October 8th, 2012 06:20 AM
Idle jumps to 9000 rpm on choke then wont stay idle after off Shawn250 2008 - 2012 Ninja 250R Tech Talk 1 June 19th, 2012 06:45 AM
Idle hangs when rev'ing engine. fixture 1986 - 2007 Ninja 250R Tech Talk 30 December 28th, 2009 12:12 PM
08 dies on idle now, is the carb cleaning covered in warranty? novak2k9 2008 - 2012 Ninja 250R Tech Talk 7 September 6th, 2009 08:33 PM
