Old November 6th, 2023, 07:50 AM   #1
Usually_charmingkno3
Winter project
Hi I just got my 2009 250 this week just before winter. I got a chance to ride it around the neighborhood for a couple hours though. Over the winter I plan to tear the fairings off and get a good look at everything as well as tidy it up and address any other issues. It will be in my garage, but it's not heated all the time. If I plan to do a minimal tear down could someone give me basic guidance on winterizing. Ive seen dozens of different opinions with empty vs full tank etc
Usually_charmingkno3 is offline   Reply With Quote
Old November 6th, 2023, 11:07 AM   #2
I stored mine for years with a full tank of Ethanol Free fuel and stabilizer and I will NEVER do that again. Total disaster. It seems like the stabilizer ate away at the brand new petcock and all of the fuel drained through the carbs/cylinders and into the crank. The tank totally rusted.
Old November 10th, 2023, 01:20 AM   #3
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Welcome!
Old November 10th, 2023, 05:37 AM   #4
Welcome, Nicholas!
I've certainly never had stabilizer cause a problem here, and I use it regularly. If I had to guess, I'd say that moisture got in somehow, maybe before you filled the tank, and it caused the problems you had. You could always put some scrap parts in a jar of fuel and the stabilizer you used, and see what happens over the following weeks. Was this Sta-Bil, or something else?
Old November 10th, 2023, 01:27 PM   #5
Originally Posted by Triple Jim View Post
Welcome, Nicholas!
Sea Foam. When used as a stabilizer it only claims to stabilize E10 for an extra two years but since I was using E0 (Ethanol free) I thought I’d be good for much more.
I wish I had my Ethanol testing kit back then to verify E0 but the station had a whole separate pump so I assumed it would be the real deal. The original petcock was leaking so after the first couple years I drained the fuel and replaced it along with a full tank of fresh E0. It sat several more years before I found it completely empty.
Perhaps the stabilizers promoting that as their primary use work better. I definitely shouldn’t have let it go that long but people using E0 with no stabilizer seem to have better long term results so I still blame the stabilizer. Regardless, I’m draining the tank if I ever have to do this again!
Old November 10th, 2023, 02:47 PM   #6
Sea Foam.
Oh, that explains it. That stuff contains a fairly high amount of isopropyl alcohol, as listed in its MSDS. I'd never put it in my fuel.
Old November 10th, 2023, 04:18 PM   #7
By going ethanol free and then adding Sea Foam, it looks like I replaced one kind of alcohol for another. :/
Winter boredom project rubber side down 1986 - 2007 Ninja 250R Farkles 8 March 28th, 2018 04:22 PM
winter project almost complete justopelt 1986 - 2007 Ninja 250R Farkles 10 May 5th, 2014 02:00 AM
2009 r6 winter project TnNinjaGirl The Ex-Ninjetters Lair 85 February 24th, 2014 12:45 PM
Winter project; 250 engine enko11 2008 - 2012 Ninja 250R Tech Talk 8 March 29th, 2013 01:43 PM
My Winter Project maxedpenny 2008 - 2012 Ninja 250R Farkles 51 March 11th, 2009 05:09 PM
