Old February 7th, 2012, 06:22 PM   #1
Little_Ghost
Little_Ghost's Avatar
Motorcycle(s): 2009 SE Green/Black/White Ninja 250R
Exhaust hanger needed?
I'm planning to order the MGP Growler Slip-on Exhaust and I wondered if I would need a new exhaust hanger or will the stock one work? Searched the site for a while and couldn't come up with an answer, although it's probably out there...
Little_Ghost is offline   Reply With Quote
Old February 7th, 2012, 06:51 PM   #2
massacremasses
Avid Kitteh Poster
massacremasses's Avatar
Motorcycle(s): 2006 Yamaha TTR 50 SUCK IT
Why a Growler?
I powdercoat stuff Help me pay for my addiction
I say funny stuff. http://twitter.com/JustinPWNSyou sometimes...
I write like a 12 year old too, http://justinpwnsyou.wordpress.com/
massacremasses is offline   Reply With Quote
Old February 7th, 2012, 07:51 PM   #3
Little_Ghost
Originally Posted by massacremasses View Post
Why a Growler?
Why not?
Old February 7th, 2012, 07:53 PM   #4
saxnbass
saxnbass's Avatar
Motorcycle(s): 2009 CBR600rr
saxnbass is offline   Reply With Quote
Old February 7th, 2012, 08:10 PM   #5
you shoould make it yourself buy some sheet metal, trace a template with cardboard, then cut the sheet metal with snips or a dremel or grinder or something. sand/file edges smooth and paint it to match your color scheme. cost: $10, satisfaction: priceless.
Old February 7th, 2012, 08:28 PM   #6
massacremasses
Avid Kitteh Poster
Originally Posted by Little_Ghost View Post
Why not?
Originally Posted by saxnbass View Post
thats why.
its $130 shipped.
Old February 7th, 2012, 10:17 PM   #7
walty87
walty87's Avatar
Motorcycle(s): 2012 ninja 250
i have a mgp growler. You do not need anything else, the stock hanger will attach to it just fine.
Though if you do take off your passanger rear pegs you will need a new hanger obviously
walty87 is offline   Reply With Quote
Old February 8th, 2012, 06:17 PM   #8
Little_Ghost
thats why.
its $130 shipped.
That is a pretty good price for the Danmoto, obiviously. I didn't like the look of it before, but it is growing on me...
Another Question: Everyone that says they have installed a new exhaust slip-on says they needed to shim the needles after. Is that really necessary? Shimming the needles is meant to increase gas mileage, correct? Seems like the bike gets such amazing mileage I would never even notice!
Old February 8th, 2012, 07:54 PM   #9
massacremasses
Avid Kitteh Poster
na itll work opposite. Shimming richens the mixture. So you will get worse gas millage.
Old February 8th, 2012, 08:22 PM   #10
walty87
walty87's Avatar
I rode around with my mgp growler for about 2 weeks w/o shimming the needles. It rode rough at low speeds, and would gurgle and pop and make horrible cracking noises when I let off the throttle or rode at slow speeds.
After I shimmed 2x 3mm washers on each needle the bike ran way more smoother and sounds way better.
You will lose mpg though. By shimming the needles youre allowing more gas to go through the carbs.
edit: imo the mgp growler looks way cooler then the dan moto
Old February 8th, 2012, 09:06 PM   #11
Little_Ghost
Ohhh I see how it works. So, wouldn't having your bike re-jetted really be a better solution?
Old February 8th, 2012, 09:11 PM   #12
saxnbass
saxnbass's Avatar
Yes, but shimming costs like $0.20
Old February 9th, 2012, 06:00 AM   #13
Little_Ghost
I see. I was planning on having the bike re-jetted before Spring this year anyhow so I will probably just stick with that, but I'm glad I understand the whole shimming thing now!
Thank you guys!
Old February 9th, 2012, 09:41 AM   #14
Gorilla25
Dakine...
Gorilla25's Avatar
Motorcycle(s): 2009 Ninja 250R (Sold) | 636 (hopefully soon)
..but the MPG doesn't worsen too much...i still avg around 60-70 MPG...with a slip on, shim,klen delete, and snorkel delete
Gorilla25 is offline   Reply With Quote
Old February 9th, 2012, 09:54 AM   #15
Making any changes to the amount of fuel the carburetors deliver is jetting. People seem to think it's only re-jetting if they physically change the main jets.
Not to mention the only difference between buying a jet kit vs buying new main jets and then shimming the needles is a) price and b) the taper of the needles, which is under debate as to the actual effectiveness and if that, where the effectiveness is in the rpm band/throttle input range.
The reason most of us can get by with just shimming our needles out a little is because the oem main jets are huge, and the top end is rich, but the midrange (under control of the needles) is lean. Soooo when you make intake/exhaust changes, the main jets are still ok, and the needles need to be shimmed out because the changes we just made caused the whole range to be a little more lean than it was, which means the midrange is also more lean than it was. Shimming richens the mixture in the midrange.
Make sense?
Old February 9th, 2012, 11:41 AM   #16
GlassAnkles
GlassAnkles's Avatar
Motorcycle(s): 02 zx-12r, 13 zx-10r abs
the yoshimura passenger peg delete bracket looks the best IMO
http://www.amazon.com/Yoshimura-Muff...8812791&sr=8-3
GlassAnkles is offline   Reply With Quote
Old February 9th, 2012, 06:53 PM   #17
Little_Ghost
Make sense?
Ah ha. Okay. Good to know. Maybe I'll just shim the needles then. I was going to get new jets, but maybe now I wont. Something to chew on anyway... Thank you for further educating me.
I don't think I'll be getting rid of my passenger pegs, but I'll keep that in mind in case I change my mind. Thanks!
Old February 9th, 2012, 06:55 PM   #18
But let me also be clear, if you make any huge changes, like full exhaust and a airbox delete, you need to get different main jets.
For a slip-on, you'll be fine with just shimming.
Old February 11th, 2012, 06:14 PM   #19
Little_Ghost
Okay, good. Thank you!
Old February 11th, 2012, 08:27 PM   #20
massacremasses
Avid Kitteh Poster
So far I feel like I dont need to shim yet... just sayin.
Old February 11th, 2012, 08:28 PM   #21
Justin, when you get them, humor me and add a washer. You'll notice a difference.
Old February 11th, 2012, 08:31 PM   #22
massacremasses
Avid Kitteh Poster
got them in today. I might do it next weekend. I just got it back together and I need to take if for a real ride before I can really decide.. I might remove the snorkel too.
Also Mo. check out my pics with the Danmoto it looks pretty good for being so much cheaper...
Old February 11th, 2012, 08:35 PM   #23
do it
Exhaust hanger ator 2008 - 2012 Ninja 250R Farkles 11 January 16th, 2012 02:55 PM
Exhaust hanger ride2max 2008 - 2012 Ninja 250R Farkles 61 June 29th, 2011 11:51 AM
DIY- AP Exhaust Hanger kkim 2008 - 2012 Ninja 250R Farkles 12 June 18th, 2010 12:39 PM
Exhaust Hanger kevsninja 2008 - 2012 Ninja 250R Farkles 13 March 7th, 2010 10:42 PM
exhaust hanger mista350z 2008 - 2012 Ninja 250R Farkles 5 April 13th, 2009 10:41 AM
