Old August 30th, 2014, 03:19 PM   #1
james250ninja
james250ninjette.newbie
james250ninja's Avatar
Motorcycle(s): 1986 ninja 250
Smile adjusting idle mixture screws
ok I want o make this is right
which way is more gas counter clock wise or clockwise
left or right turn
bike running a little lean
the idle mix screws are set at stock setting
I cleaned the carbs reall well and cleaned the air filter properly
bike rides great but a little lean
james250ninja is offline   Reply With Quote
Old August 30th, 2014, 04:39 PM   #2
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
CCW.
So how does one determine that it's lean at idle? Too much carbon monoxide emission when idling?
Old August 30th, 2014, 05:02 PM   #3
Ninjinsky
Ninjinsky's Avatar
Set it to the book, and it should be fine. That said book is likely to be fractionally lean because of emissions so add 1/4 turn to be safe
It's not a particularly picky setting.
ps general riding you are on the needle jet more than the idle circuit, If you are saying lean because of plug color raise the needle a tad.
Take a look at this diagram and notice that the idle screw only has any effect at the very bottom of throttle movement
http://www.arcticchat.com/forum/atta...b_circuits.jpg
Old August 30th, 2014, 05:07 PM   #4
dcj13
Participant
dcj13's Avatar
Carburator is a French word meaning "don't mess with it".
Old August 30th, 2014, 05:41 PM   #5
Ninjinsky
Ninjinsky's Avatar
Spoken like a scaredy cat without a degree in fluid dynamics
Old August 30th, 2014, 05:46 PM   #6
left or right turn
To richen the idle mixture with the Ninja, you turn the screws out or counterclockwise. In the Ninja's carbs they are fuel bleeds, so opening them (turning out) adds fuel.
Not all cycle carbs operate the same way though, so you need to know if you are dealing with an fuel bleed or an air bleed.
I have no idea what the "stock" setting is - and it doesn't matter - start at 2 1/2 turns out and go 1/2 turn out after riding a while to see if it makes it better or worse - then readjust until it feels the best. A number of factors affect the adjustments - altitude, temperature, type of fuel, etc.
Make sure the engine is at operating temp before you do any adjustments. Also make sure you are using the fuel that you will be using most of the time.
For example - if you are running E10 (10% ethanol) and go to running non-ethanol you will run richer. Use gas without ethanol any time you can - especially in older engines.
The carbs must be synced in order to get it all right.
Old August 30th, 2014, 05:47 PM   #7
dcj13
Participant
dcj13's Avatar
I am a bit of a scaredy cat around carbs and I only had one 300-level class in fluid dynamics a long time ago (but I did pretty well in it!).
Old August 30th, 2014, 06:14 PM   #8
No reason to sweat working on carbs. Other than taking them off the Ninja, which is a pain (but gets easier after a few times) they are pretty simple.
My son and I recently worked on a leaf blower that never ran right, even when new. It wouldn't idle and when you gave it full throttle it would bog. It only ran OK at mid-throttle and was hard to start.
We took the carb apart and checked it over - looked fine. We took the carb on-and-off and disassembled it about 5 or 6 times before it would start again but we never found an obvious problem. The low and high speed mixture adjustment screws were blocked and had no notches (slots) in them at all. We cut a small cross-slot in each one and made some adjustments, eventually getting it to idle smoothly and take full-throttle without bogging.
My point is - don't judge what is "right" by what is "stock". Take some time, do some tuning and testing, and it will all eventually make sense. Know the fuel you are tuning it with. If there's any question, dump the fuel and add new before continuing. You will never get it to run right if the fuel is bad.
If you don't like working on carbs, keep track of your fuel. Drain the floatbowls if it's going to sit. Run Techron Concentrate fuel system cleaner once a year. Use stabilizer. Keep the tank full. Run ethanol-free gas.
I never take carbs apart on my equipment (except for tuning) - it's always someone else's.
Old August 31st, 2014, 05:34 PM   #9
j98sprint
Motorcycle(s): '02 Ninja 250, '98 Triumph Sprint 900, '69 H-D Sportster XLCH 900
2 1/2 turns out from lightly seated.
j98sprint is offline   Reply With Quote
Old September 1st, 2014, 10:29 AM   #10
agentbad
agentbad's Avatar
Ninja 250 carbs are pretty easy to work on especially if you have pods and can get them off the bike in 5 mins.
DIY - Accessing and adjusting idle mixture screws VeX 2008 - 2012 Ninja 250R Tech Talk 71 December 15th, 2017 03:38 AM
Adjusting the Idle Mixture Screw conrya5 2008 - 2012 Ninja 250R Tech Talk 22 March 18th, 2013 05:03 AM
Air mixture screws J>A>V 1986 - 2007 Ninja 250R Tech Talk 1 August 9th, 2012 07:57 PM
Help on adjusting idle screws silentIm 2008 - 2012 Ninja 250R Tech Talk 3 May 12th, 2012 10:52 PM
Awesome tool for adjusting mixture screws - with both fairings on! headshrink 2008 - 2012 Ninja 250R Tech Talk 6 December 5th, 2011 05:14 PM
