Old February 10th, 2024, 12:24 PM   #1
Fred659
Fred659's Avatar
Motorcycle(s): 08 Race Prepped ZX-10r, 09 Race Prepped Ninja 250 (300 motor). 74 Norton Commando 850 (Project)
Looking for a 335cc Power Commander FC map
Hi, I was wondering if any of you guys have a map that could bring me close / safe (I will still do dyno tuning) to around 13:1 afr?
If not, I also bought a AFR. Can somebody help me with what the map should look like, I have a Power Commander FC.
335 / 296 = +/- 13.2%so, is there a quick way for me to add that value overall in the table?
I just want the bike to be safe to run on the dyno for the fine tuning.
Thanks
Fred659 is offline   Reply With Quote
Old February 11th, 2024, 09:29 AM   #2
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
To get the % increase for the extra air volume, you need to know the current duty cycle for the injectors. The FC has manual adjust settings, just add 10% at all 3 areas & take it from there. Note that Kawasaki injector harnesses don't have defined polarity, so if they don't work, just reverse the cables in the connector. I had a single when I first fitted mine, before I learned this trick!
Last futzed with by Mohawk; February 11th, 2024 at 01:33 PM.
Old February 11th, 2024, 09:51 AM   #3
Fred659
Fred659's Avatar
Originally Posted by Mohawk View Post
To get the % increase for the extra air volume, you meed to know the current duty cycle for the injectors. The FC has manual adjust settings, just add 10% at all 3 areas & take it from there. Mite that Kawasaki injector harnesses don't have defined polarity, so if they don't work, just reverse the cables in the connector. I had a single when I first fitted mine, before I learned this trick!
Thanks for the reply.
My ECU is flashed and well calibrated for my exhaust and air filter. So, if I correctly understood what you said, I could build a base map that has 10 in each cells? I want my tune to be on a map and not on the 3 adjusters.
I will check that with my AFR Gauge (roughly) to make sure i'm not way too lean or rich.
Thanks again.
Old February 11th, 2024, 01:31 PM   #4
Mohawk
Mohawk's Avatar
I thought you were just worried about running the engine before dyno tuning & I was referring to the manual dials on the FC. If you have an external AFR meter then just ride it & adjust as you go.
All piggyback fuel modules use ECU cycle +/- x% Add/remove from whatever the ECU duty cycle is. So say ECU sends 75@x/rpm then you add x% to increase fuel. As you have no way to know what numbers a flashed ECU is sending then you can only add x% and measure the result on AFR meter.
If you have flashed ECU why not just get that setup on dyno again ?
Remember engines will NOT self destruct if AFR is off unless you keep running it like that & they take time to warm up too, so a minute or two with no coolant won't damage a water cooled engine, think how air cooling works !
Old February 11th, 2024, 01:37 PM   #5
Fred659
Fred659's Avatar
I sent the ecu to the US to get it flashed and I asked the guy and he won't adjust it that far without having the bike on hang.
Also, it is a track only bike so "riding" is more complicated.
I would like to get close before the dyno tuning, not perfect.
Old February 11th, 2024, 02:16 PM   #6
Mohawk
Mohawk's Avatar
I can understand if it wad a remote reflash. Can't you find a local place to do it ?
If you have an AFR meter just work from that, I did that on one of my other bikes, just made mental note when riding what the AFR was showing & adjusted fuelling until it was where I wanted it.
Old February 27th, 2024, 04:37 PM   #7
Fred659
Fred659's Avatar
While I was searching for E85 injectors, I found that 07-12 zx-6r injectors are almost exactly the right fit for the 66mm 335cc kit for regular fuel. I also have a set of 08 zx-10r injectors if I decide to go E85. It should put me close to the right values. I also have a ex650 fuel pump already (fits the efi 250 tank). I just bought a set of 4 on eBay.
EAT-811 = 175cc/min @ 43psi
EAT-288 = 200cc/min @ 43psi (2008 ZX-6R)
*** Thanks @DannoXYZ ***
EAT-287 = 330cc/min @ 43psi (2008 ZX-10R)
*** Thanks @garth285 ***
335cc / 296cc = +13.2%
200cc / 175cc = +14.3%
Is the Power commander what I'm looking for? JA-Moo 2013 - 2017 Ninja 300 Tech Talk 9 May 14th, 2018 12:40 AM
Power commander 5 joecool 2013 - 2017 Ninja 300 Tech Talk 27 October 17th, 2014 05:03 AM
I need a Power Commander MAP, R-77 full system Silly 2013 - 2017 Ninja 300 Tech Talk 5 April 17th, 2013 01:41 PM
power commander? bandit_fosky 2008 - 2012 Ninja 250R Tech Talk 14 January 16th, 2013 02:05 PM
Power Commander Map Needed tuktukracer 2008 - 2012 Ninja 250R Tech Talk 8 April 28th, 2011 01:20 PM
