Old January 21st, 2013, 09:37 PM   #1
cuong-nutz
cuong-nutz's Avatar
oil temp vs coolant temp
Which of the two is more important in regards to our motor? I flog my motor and keep the revs relatively high for extended periods of time (it's pinned for a long time). Would the coolant temp be a good indicator of oil temp?
HalfFast Racing Team
Old January 21st, 2013, 09:41 PM   #2
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
I have both on my gauge and will say if the bike it running long enough(30+ mins) the oil will catch up to the water. Water changes faster so the oil will play catchup in both directions. Just worry about your water and you'll be fine.
Curious on why the sudden interest?
Old January 21st, 2013, 09:46 PM   #3
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Look here http://www.ninjette.org/forums/showthread.php?t=122370
All reading are max for like the last 2 months
Speed 223mph(new 250cc world record)
Water 201.2
Oil 192.2
Old January 22nd, 2013, 04:45 PM   #4
lgk
they are both important.
if was forced to pick one gauge over the other i would probably pick the water gauge. with an idiot light oil temp set at 250f
Old January 22nd, 2013, 05:03 PM   #5
setup a two way flop trigger to send whichever the lower resistance (higher heat) of the two thermistors is used.
Old January 22nd, 2013, 05:56 PM   #6
tooblekain
tooblekain's Avatar
Motorcycle(s): 2007 Triumph Bonneville; 2008 Ninja 250r (trackbike)
They are both important, but to answer your question and to add a suggestion, I would be more concerned about oil pressure over oil temperature.
Here's how I would rank importance from first to last IMO:
Oil pressure
Water/Coolant temperature
Oil Temperature
*CVMA #312*SoCal Trackdays*BigHeadz Racing*Motion Pro*Factory Effex*Leatt Brace* Racetech *Bell * Woodcraft CFM*Vortex*Hotbodies*Surface Sun Systems*Braking*LiveWire Energy*Freegun Underwear
tooblekain is offline   Reply With Quote
Old January 22nd, 2013, 06:06 PM   #7
why not just get one of those fancy gauges that has trigger zones so you can set it to monitor all of them and only tell you something is wrong when its outside the normal zone
Old January 23rd, 2013, 05:39 AM   #8
lgk
I haven't messed with my koso gauge much but i believe that how it works.
you set limits for the idiot lights and they light and display at what ever your limit is.
i dont think it has an oil pressure input though.
Old January 23rd, 2013, 06:39 AM   #9
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Oil pressure
Oil Temperature
+1
Worlds fastest 250 ninja
Old January 23rd, 2013, 10:54 AM   #10
tooblekain
tooblekain's Avatar
I rigged up an oil pressure gauge for my Bonneville. If interested I can show you the DIY thread I posted on TriumphRAT and NewBonnevilleriders. It should give you an idea of how to route the stainless steel line and what not.
So far I am just relying on my oil pressure light that is part of my Trailtech gauge
Old January 23rd, 2013, 03:45 PM   #11
lgk
I'm interested.
please post link
Old January 23rd, 2013, 05:44 PM   #12
tooblekain
tooblekain's Avatar
http://www.newbonnevilleriders.com/f...80&postcount=1
http://www.triumphrat.net/twins-tech...ml#post2128684
Koso Oil Temp Sensor Adapter & Water Temp Sensor Adapter StaylorT 2008 - 2012 Ninja 250R Tech Talk 10 January 24th, 2014 12:38 AM
Oil and Water Temp Agger 2008 - 2012 Ninja 250R Tech Talk 2 March 18th, 2012 07:12 PM
My temp and oil light came on?? Kevin2109 2008 - 2012 Ninja 250R Tech Talk 11 July 17th, 2011 01:07 AM
Oil and Temp light on after low side dznuts 2008 - 2012 Ninja 250R Tech Talk 2 May 2nd, 2011 05:57 AM
How to test coolant temp sensor? Togglehead 1986 - 2007 Ninja 250R Tech Talk 1 July 21st, 2010 03:50 PM
