June 27th, 2010, 12:48 PM | #41 |
Join Date: Jun 2010 Motorcycle(s): '09 Kawasaki Ninja 250R, '09 Suzuki SV650SA Posts: 3
Thanks for the replies guys. She's short...barely 5 feet tall and weighs about 115 lb. Her inseam is probably 28" or less. Even with it lowered to the 4th hole, she can't quite flatfoot the bike. There is currently only about 3-4 finger gap between the rear tire and the fender. The shop that lowered it told me it would be no problem, however, after a couple of rides I checked the fender and I could see rub marks. The shop has offered to adjust pre-load, but I'm not sure this is the best solution. I think I will keep it at this setting until she becomes more confident on the bike, and then raise it up one notch. I'm using some masking tape on the fender now as a temporary solution, but one of the strips of tape came off and became stuck to the tire!!! Any way to remove it? Or am I best to just let it wear off on it's own?
Subiegy2010 --> After raising back up to the 3rd hole with stock suspension setting, did you experience any rubbing issues? Also, what is your approximate weight if you don't mind me asking? |
June 27th, 2010, 11:37 PM | #42 |
noob in training
Join Date: Aug 2009 Motorcycle(s): '08 Ninja 250R (sold) '05 SV650S Posts: 175
No rubbing, I'm about 130lbs.
July 7th, 2010, 05:24 PM | #43 |
Join Date: Jun 2010 Motorcycle(s): '09 Ninja 250r Posts: 63
Okay so my bike was lowered 2 inches by the previous owner and I'm ready to raise the rear. My question is what exactly will happen once the tie rods are removed? will the bike fall apart? I kno it says swingarm pivot but I don't want to cause problems I won't be able to fix. What do the tie rods connect exactly?
July 7th, 2010, 05:32 PM | #44 |
what is it that you don't understand from this thread?
http://www.ninjette.org/forums/showthread.php?t=47461 |
July 7th, 2010, 07:00 PM | #45 | |
July 7th, 2010, 07:10 PM | #46 |
You should support the bike securely as Kim has shown in her first post. Once you take off the links, there is nothing supporting the back end of the bike from the swingarm pivot on back.
If you lack the tools shown that are needed to do this job safely/properly, perhaps it would be a wise decision to have a shop do the work. |
July 7th, 2010, 07:23 PM | #47 | |
Okay thanks, I have the tools needed. Thanks for clearing this up for me. |
July 7th, 2010, 07:40 PM | #48 |
If you have more questions, don't hesitate to ask. It's always better to ask before you do something if you have any doubts. Members are great on this forum and are always willing to help.
July 26th, 2010, 12:15 PM | #49 |
Join Date: Jul 2010 Motorcycle(s): VFR/250r/Gsxr 750 Posts: 74
Thanks for the write up on this Noche! I just did the lowering on my friends bike and she's so happy now! I used the same kit and at first I lowered to the lowest setting.
That was too low as the tire would rub the rear fender while sitting still. I raised it to the same setting as you had in the photo (middle hole of top 3) It only rubs the rear fender if she hits a big bump. I'll raise it another notch once she gets comfortable with everything. If you have a paypal accout, I'd send you a few bucks just for say thanks for the DIY. |
July 26th, 2010, 12:22 PM | #50 |
glad to be of service
Roaring Toyz lowering links/dogbones hole layout (pic) | dullers | 2008 - 2012 Ninja 250R Tech Talk | 1 | June 1st, 2013 11:11 AM |
Roaring Toyz Lowering Links + Blocks | zomgcake | Motorcycle-related | 1 | October 27th, 2010 06:12 AM |
Roaring Toyz Lowering Links - settings heights? | azia | 2008 - 2012 Ninja 250R Tech Talk | 11 | September 8th, 2010 01:18 PM |
added: shogun frame sliders, roaring toyz lowering links and blocks! | BIGT94z | Pictures | 7 | July 26th, 2010 02:21 PM |
